Question about Drills
Im looking for a table top drill press with a 800-1000rpm
    New Friend:
  • 37 Answers
Go to a machinery shop/warehouse who sell to metal trades or metal companies ,,,,pete ...or if you need a cheap one try bunnings ,masters super cheap, repco,auto one also has a good selection etc:
Posted on Jun 16, 2014
5 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: Craftsman Drill Press chuck problem
It is unless there is a tang on the end. What you need to do is thoroughly clean the parts with something like brake clean to remove all the oil and then wipe with a clean paper towel. What I do it put the arbor into the drill press or the chuck onto the arbor and then put a 2x4 on the table and press the parts together or if you have enough room fully retract the jaws and use the block of wood to "tap" the parts to seat them. Let me know if you need more assistance
Posted on Aug 25, 2009
Testimonial: "Thanks rowdy45176. Your solution was spot-on. I cleaned both sides and them , with the chuck jaws fully retracted, tapped it with a plastic mallet"
al_kupchella
  • 843 Answers
SOURCE: Pro-Tech 10" drill press model 10162. Quill travel adjustable?
There is probably a depth stop collar with a thumbscrew on the shaft which has the three handles attached to it. This collar would be about two inches in diameter. All you have to do is loosen the thumbscrew.
Posted on Apr 26, 2010
  • 54 Answers
SOURCE: how can I square the table on my Skil 3320 drill press?
To get rid of the bad boring job on the column you might have to take the swivel adjust apart below the table and rework that. I would try to shim it rather than file all that cast iron. A stainless hemishpere shaped shim of .007" thickness or so would be a good thing to try first. Square with a good 6" square and a dowel pin in the chuck and the Column tensioner at full tightness of course. Keep the shim 1/2" out from the lock bolt and the whole thing should sort of tighten down well enough to use as long as you don't bend the handles with drill pressure. We had one that was actually loose between the Column, the Base and the Drill Head where it was turned too small.
Posted on Dec 16, 2011
Testimonial: "Great! I really appreciate---this is just what I was looking for. Does the shim need to be cemented in place? Thanks Mike!"
  • 54 Answers
SOURCE: Looking for replacement benchtop drill press table.
On a small drill press you could make a 4.5" high riser block. Steel bar would be best. You could roll pin a bunch of 3/4" thick bars together in a stack just big enough to lock to the base T-slots. For tall parts you just then pry some of the bars off the roll pins with a big screw driver. I like to get rid of Universal or Adjustable stuff as it always introduces flex, movement while running and non-scoocum rigidity!
Scoocum Rigidity: Pertains to Harmonics of metal cutting with anything sticking out more than 1" from a fixed support of some kind. And also pertaining to large Cedar Totem Poles of the Pacific West Coastal Indians.
Posted on Dec 17, 2011
How To Assemble A Rigid Bench Top Drill Press?
Rigid bench top drill press comes with an assembled head, but the chuck, handles, and belts need assembly. As the assembly progress, it becomes heavy eventually and may even require two people.
To help you assemble this Rigid bench top drill press, we have attached here step by step guide for you:
Step 1 Your first job is to unpack the drill press. The instructions are given on the top so that you will have no issue unpacking or assembling the tool.
Step 2 After you unpack, take the post and attach it to the base. As the press has too much oil on the post, you should wipe away all the oil and wax it afterward.
Step 3 You should clean the table post as well. So, wipe the oil off the table post using an oil-soaked paper and apply wax to it. If the oil remains, you can use a putty knife and scrape it off. The oil was used for a long boat ride to prevent rust.
Step 4 As the cleaning procedure is done, take the table and install the table in the table arm.
Step 5 The next step is putting drill head on a moving dolly and wheeling it over to the base. Now, tip the base and slide the drill head. Using your legs, lift and stand drill press up. You will not need another person for help if you use your leg doing so.
Step 6 This step requires installing the idler pulley and belts.
Step 7 After pulley and belt, install handles. You can choose the position depending on your habit. Most of the people install it on the right-hand side. But if you are a lefty, you can use left-hand side.
Step 8 Take a thick scrap and put it on the table. Wide open the chuck jaw and clean the mating surface of the shaft and the inner side of the chuck. Make sure to clean it nicely for keeping its stable position. Then, take the handle and press shaft in the chuck very tightly.
Step 9 There must be 60W bulb which is needed to be installed behind the handles in a small recess. If you do not find enough space to fit 60W bulb, you can press a CFL pigtail style up and reinstall the guard.
Step 10 The last step is to square your table to the quill. Combination table can also be taken in this case. It is required to use a bit which is straight and spins true.
More details open the link Efficient Techniques to Assemble Your Rigid Bench Top Drill Press
Apr 10, 2018 | Drills
I just bought a 12in drill press table top the laser light is not working what can i do ??
make a warranty claim ..most power tools come with a 12 month warranty ..or use it without the laser.. pete
Jan 18, 2014 | Craftsman Drills
My spindle slide out of the drill press. I remove spindle to clean , what did I do wrong.?
Please look at this site:
http://www.ebay.com/itm/DELTA-MILWAUKEE-14-Drill-Press-DP-220-Instructions-Parts-Manual-0239-/310388408599
This site has pictures that might help:
http://www.ebay.com/sch/sis.html?_kw=Vintage+Delta+14%22+Drill+Press+DP220+%22Triple+Duty%22+Bench+Model+Tilt+Table
Jan 23, 2013 | Delta Woodworking Vintage Delta Dp 220 14"...
Need a take up spring for old craftsman drill
Hello. Craftsman only stocks parts for their tools for a ten year period. If you want to look and see just go to searsparts.com.
Your best bet may be to take your worn spring to a hardware store and match it up with one that they have in stock.
Nov 19, 2009 | Washing Machines
Aug 25, 2009 | Craftsman 4" Drill Press Vise, Side -...
Need manual for craftsman drill press model 113.213853
In general, craftsman manuals are available for download by going to the Sears manage my home site which you can access by clicking here
You probably have to register to complete the download, but you can opt out of most of their communications...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Apr 06, 2009 | Drills
Delta 8' table top drill press
If the spindle is tapered, and you have a tapered chuck, it is a interference fit. You can move the table out of the way for swinging room and smack it on with a mallet. Or you can block the chuck up on the table and force the spindle into it.
Both spindle should be smooth and clean, sometimes if a drill bit grabs and stops it will twist the chuck off and gall up the taper surfaces. Put some chalk dust on the spindle before assembling if you have some, it will help prevent galling should the chuck come off
Mar 29, 2009 | Drills
Drills Logo
106 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
