Question about Sewing Machines
Janome jfs 1817
Step by step threading instructions needed
3 Suggested Answers
SOURCE: How do I thread a Janome JFS 1817 for double needle function?
you thread it the same as for a single needle
only you add one more spool of thread & thread thru the same
thread guides as the first needle & then thread the second needle
with the thread from the second spool,
also you have to have a spool holder for the second spool
Posted on Aug 30, 2012
SOURCE: instruction manual needed for a Janome Finesse JFS 1817
go to the website of a1sewingmachines.com and call them
about a manual
Posted on Apr 08, 2013
How do I thread my singer 4205
Go to Singer's website, click on 'Customer Support' then 'Instruction Manuals' enter your model and download the manual.
or click the link to download the instruction manual
http://www.singerco.com/uploads/download/498_4205_4210.pdf
Threading is covered on pages 31-41 in the manual, with step by step instructions and pictures.
Jul 14, 2012 | Singer Sewing Machines
Threading the singer 7258
try sewusa.com they have some threading diagrams
Jun 07, 2012 | Singer 7258 Sewing Machine
How t o thread a singer stylist 534
Try this site, it has step by step instructions with pictures for threading a 534.
http://www.instructables.com/id/Threading-the-ITP-Singer-534-Stylist/
Aug 28, 2010 | Sewing Machines
How to thread the machine.
http://www.instructables.com/id/How-to-Thread-a-Sewing-Machine/
check out this link.. it is described clearly with the help of images...
OR
try to do by reading these steps..
Step 1 Raise the needle to its highest position by turning the handwheel toward you.
Step 2 Raise the presser foot. This will allow the thread to easily pass through the threading points and will prevent the machine needle from becoming unthreaded when you begin to stitch.
Step 3 Place a spool of thread on the spool pin located at the top of your sewing machine. If the spool pin runs horizontally, secure the spool of thread with the cap provided.
Step 4 Take hold of the thread end and pass it through the designated threading points on the top of the machine casing, then down toward the tension assembly. The tension assembly is located on the left side of the machine and controls the flow of thread.
Step 5 Take the thread under the tension assembly and back up through the next threading point at the top left of the machine. Make sure the thread has passed between two tension discs as well as the hook that may be attached to the left side of the tension dial.
Step 6 Push the thread end through the lever at the top left of the machine, if applicable, and down through the threading points at bottom left and above the needle.
Step 7 Thread the needle from the front or back of the needle. The threading direction will depend on your machine type.
Step 8 Pull a few inches of thread through the eye of the needle and pull the thread to your left.
Step 9 Insert a wound bobbin into the machine, if necessary, and close the throat plate. A few inches of bobbin thread should be pulled out to the right and sticking out from under the closed throat plate.
Step 10 Take hold of the thread that has been threaded through the machine needle.
Step 11 Rotate the hand wheel toward you until the needle disappears into the bobbin case.
Step 12 Keep holding on to the thread and move the hand wheel so the needle is once again at its highest position. As the needle rises, a loop of bobbin thread will come up as well.
Step 13 Pull the thread out toward your left to draw the bobbin thread loop further out of the bobbin case.
Step 14
Let the top thread go and pull the bobbin thread up until the end comes up. Pull the top and bottom threads under the presser foot and to the back and right of the machine.
please rate this solution...
gkgb.
Jan 13, 2010 | Sewing Machines
Need a manuale for threading sewing machine
give me step by step instructions to thread my machine please and thank you
May 13, 2008 | Euro-Pro 1260DX Mechanical Sewing Machine
Sewing Machines Logo
35 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
