Question about Maytag MSD2454G Side by Side Refrigerator
Refridgerator side quit - Maytag MSD2454G Side by Side Refrigerator
Refridgerator will not cool. Freezer works fine. Noticed a pool of water on floor then started to cool again. after a few days quit cooling.
Check the water drain hole in bottom of unit. If plugged water cannot get to catch and pan and evaporate with the heating element.
Aug 25, 2011 | Maytag MZD2766GES Side by Side...
I had the same problem everyone else is having with my samsung model RS2534WW refridgerator. After a power outage the freezer failed but the fridge worked fine. Then another outage and both sides quit...
I had a similar problem also after a power outage, I called best buy for service and 200 bucks later it was a no go, same problem. I found a repair manual on the online auction place E b a y and was able to troubleshoot down to a faulty relay on the PCB, look there for the manual it may help you. I is not the compressor cause then the freezer would not work also.
Jan 25, 2011 | Samsung RS2534 Side by Side Refrigerator
WATER AN ICE STOPED ON WHIRLPOOL REFRIDGERATOR
Its sounds like a bad watervalve or quite possibly a stopped up water filter if equipped
Jan 06, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Lce maker quit working? and Ideas?
The start device on some models of refridgerator for maytag and whirlpool have been recalled. If your appliance was manufactured in the last 5-10 years you may be having an issue with this component
Jun 10, 2010 | Maytag 19.8 Cu. Ft. Side-by-Side...
My Aman side by side quit dispensing water. It
Does your fridge have a small tank inside the food compartment? If so, the water may have frozen in the tank and the problem can be solved if you take a blow dryer and warm the tank. That's what happened to mine and with a temp adjustment to keep the food compartment a bit warmer, the water doesn't freeze.
May 30, 2010 | Amana 22.6 cu. ft. Side-By-Side...
My Refridgerator/freezer is not working
Sounds as if the compressor is not running even tho the fans are. The overload relays on the side of the compressor are usually the source of this problem. They are on the side of the compressor and if you change these out you should be fine. Fairly easy to do as it should just be a plug connecting it. Hope this helps.
Feb 21, 2010 | Maytag MTB1953HE Top Freezer Refrigerator
Compressor hot on my refrigerator
This is quite normal, they usually do get so hot that you can`t hold the compressor for long due to the heat. Does the refridgerator work perfectly OK?? If it does, this is normal. Ian
Aug 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Warranty
WHAT IS THE BRAND AND THE MODEL NUMBER OF THE REF
Apr 16, 2008 | Kenmore 52642 / 52644 / 52649 Side by Side...
Maytag MSD2454G Side by Side Refrigerator Logo
13 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
