Question about Stamina Products Cycling
Manual for Stamina 450 Air Resistance Bike - Stamina Products Cycling
3 Suggested Answers
SOURCE: i need a manual on my stamina r360 recumbent bike
If this is the same Stamina R360 as I have, you just hold down the orange oval button (labeled: MODE) until you hear a beep. This resets the readings.
Posted on Apr 13, 2009
Joe Onley
  • 363 Answers
SOURCE: I have a Stamina 4700R
This is the main SITE for your unit, yet it appears to be an older unit, you can browse thru and maybe you'll find something similar to what you have and use that manual instead of the one you have. It probably won't be very much different from yours. As for parts, there are links on the page to find what you need.
Hope this is of help, Please rate and comment, Thank You
Joe
Posted on Sep 01, 2011
What is air resistance? how does it work. And how would you explain air resistance. please help me!!! this is for my science experiment and it will help me with my learning. thank you very much, anybody,...
everything in creation has a coefficient of friction including air
when air is moved over a surface that friction comes into action and the part of the air that is touching the surface is affected by that friction and so is actually slowed down in relation to the air above it
This is air resistance and is subject to certain physical laws regarding air pressures and other laws
The faster the air is made to travel over the surface ,the greater the friction and so the greater the heat being generated ( greater the resistance)
Heat generation is a change of energy from air flow over the surface ( dynamic energy) to heat energy
a reason that objects entering the earth atmosphere , glow red then burn up
the air resistance generates the heat through the friction of the resistance to movement
as an object moves through the air , the air is displaced and as air likes to maintain equal pressure that displacement creates low pressures in the air which have to be filled back to normal
If the air is stopped from from equalizing the pressure ,then a resistance to the movement is registered as the object has a low pressure area around it that slows the movement down or moves the object into that low pressure area
examples are sails on a boat, wings of an aircraft, air flowing over the end of an open pipe
basically air resistance is the resistance caused by the physical properties affected by an object moving through the air.
Jun 09, 2015 | Stamina Products Stamina Dual Action Air...
I have a pro tec sports pts windtrainer 800 & can't figure out how to make it pedal harder, please help
There is no way to make a wind trainer harder as it uses fan blades and air for resistance. You could try shifting to a harder gear on the bicycle. If it still isn't hard enough, you will have to go to an adjustable mag resistance or fluid trainer.
Mar 13, 2014 | Stamina Products Cycling
I have a Stamina 4700R magnetic resistance recumbant bike. I'm looking for a place or website to buy plastic caps for the feet, a manual, and possibly the Stamina In touch fitness monitor. Where can I...
Joe
Sep 01, 2011 | Stamina Products Cycling
Ok i got this exercise bike at a yard sale its the stamina R360's and I didn't notice it doesn't contain the petal straps for it i need them for pt at home, tkr so my foot doesn't slide off...
Fixya does not sell replacement pedal straps and would not know of sources.
For a manual, try Googling (stamina)(R360s)(manual) without parens.
Aug 10, 2017 | Cycling
I just tried my Stamina e-1000 eliptical for the first time. The electronic monitor comes on but doesn't do anything. It just reads zero. Any suggestion? Thank you.
Check the upper console to see if you have a loose connections and one of them is the speed sensor connection , if all connections are good then it looks like the sensor itself inside the main casing by the flywheel
May 16, 2010 | Stamina Products Stamina Pro 5300 Silent...
I have the same problem
Whichever way u turned the adjustments, just do the opposite and maybe u will get a comfortable setting for ur workout......sodeep
Jun 17, 2009 | Stamina Products Stamina Pro 5300 Silent...
Stamina R360s UP/DOWN magnetic restistance buttons not working
mine did the same thing.. unhook the plugs that are under the seat running from the handles and touch a screwdriver to two of the prongs on either side of the plug and it will engage the button for you on which ever side you do it.. the up or down side
Apr 21, 2009 | Stamina Products Stamina Pro 5300 Silent...
I need the wheel bearing assembly for a Stamina bike model 890.
If your mechanically incline, Pull out old wheel bearing, if still in half way good condition, take to bike/auto shop see if they can find suitable replacement or rebuild the bearing it self. make sure when putting back in to use very good grease. I have same problem, since I can't find parts, those would be the best possible solutions.
Mar 16, 2009 | Stamina Products Stamina Pro 5300 Silent...
I need a manual on my stamina r360 recumbent bike how to clear the settings on the in touch monitor
Feb 28, 2009 | Stamina Products Stamina Pro 5300 Silent...
Cycling Logo
62 people viewed this question
Top Stamina Products Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Stamina Products Cycling Expert? Answer questions, earn points and help others
