Question about Acer Aspire Computers & Internet
Blind flash bios acer 7551 keyboard don'tn work
Can not blind flash bios keyboard not working so I can not use FN and ESC tried autoexe.bat autorun.inf still can not flash.
SOURCE: locked keyboard and mousepad on acer aspire 6920G
Almost same problem: the mouse froze.
Found a nice solution at another website: switch off the pc, unplug the power supply cable AND remove battery. Press "on" switch for 20 seconds. Now re-install battery, plug back power supply cable, and switch on. Worked for me (what exactly worked for me I don't know but hey)
Good luck.
Posted on Mar 29, 2009
fslahmed
  • 127 Answers
SOURCE: Keyboard locks on startup, mouse pad works, FN & ECS (for Standby) works
your comp is infected for sure.i`ve seen many cases where my customer`s comp is infected and they face the same problem.
make sure you have ethernet cable plugged in to your laptop so we can use safe mode with networking. shutdown your computer.on top of the keyboard you have F8 key.the moment you`ll press the power button to turn on the computer start tapping F8. advance boot up options will appear. select safe mode with networking
try restoring your comp to a previous time when it was working. if it doesn`t work don`t worry just follow the steps below.In any case you have to clean virus out of your computer.
download,install and run this software.after running the scan clean all the infections and restart your comp.
http://www.download.com/Malwarebytes...dlPid=10878968
Good Luck!!
Posted on Jun 01, 2009
durtopian
  • 408 Answers
SOURCE: Acer Aspire 5100-USB, Touchpad, keyboard all quit working.
Bad motherboard or a failed attempt at a bios upgrade/flash
Posted on Jul 28, 2009
parrotheadpc
  • 2600 Answers
SOURCE: Acer Aspire One D250 won't turn on !
Try flashing the netbook with a new BIOS.....
Try this fix….all you need is a flash drive, the BIOS files from Acer support Downloads and 10 minutes of your time.
Acer One Black Screen of Death Repair…..
In most cases the black screen of death for the Acer One is due to a bad update or corrupt BIOS. In 90% of the cases, this black screen can be cured by flashing the BIOS of the Acer One.
The first thing you will need besides the netbook is a flash drive, preferably a 1 GB version so you have plenty of room. Make sure it a flash drive and not a reader or mp3 player.
Go to the Acer support site and go to service and support and go to the drivers download section. Navigate to the exact model of your Acer One, it will be labeled on the bottom of the case. It will be something like AOA150 etc….
Once you choose the model, choose BIOS and download the latest that is listed. Save it to a folder on the desktop so you can find it later. Now find the file and unzip it to that folder. When the files are unzipped they will all be listed.
Now go to “My Computer” in the control panel and find the flash drive listed. Right click on the flash drive and scroll down to “Format”. Choose “FAT” as the format….not fat32 and not ntfs. Run the format, hit apply and accept and the flash drive will be formatted to the “FAT” file system, this will allow it to boot your computer and flash the new BIOS.
Now go to the folder that has the unzipped BIOS files. Now find the folder named…. “Dos_Flash…open this folder and you will find the file that has the version number of the BIOS files needed to flash the BIOS. Right click on this file and scroll down to “Rename”, choose rename. You have to change this file name to the following…..zg5ia32.fd
Now, copy this renamed file to the flash drive that you previously formatted and also copy the file, Flashit.exe to the drive as well. This file is in the same folder as the one you previously renamed.
Now make sure the netbook is off and is fully charged. Now connect the flash drive to any of the available USB slots. Now, press the “Fn” key and hold it as well as the “Escape” key and hold it. Hold these two down together and do not let go of them. While you are holding these two keys down, press the power button and hold it down until you see the green power indicator light comes on and starts blinking…once this happens, let go of the other buttons and observe the indicator light on the flash drive. It should also start blinking indicating files being read on the flash drive. Now, just wait up to 1-10 minutes for the BIOS to be written and flashed. If it all goes well…..the system should boot up without incident and without any data loss.
Posted on May 07, 2010
SOURCE: I am unable to activate wireless card. I have to
It could be a drivers problem... Unistall the drivers from the device manager and install a fresh one from the dell website.. Try pressing the FN+F2.. Still no go.. Try to check whether the keyboard is working.. Still no go - resaet the Wireless card... Still no go.. Replace the wireless card..
Posted on Sep 12, 2010
Hi i have an acer aspire one 523h-2588 and in the bios it says "IDE0 HDD Password is : Frozen" how can i get rid of it to use my laptop again cause it wont let me see my windows
Acer Aspire One BIOS Recovery The Acer Aspire One has a built-in BIOS recovery routine, which can boot into a minimal BIOS environment via a special boot block to re-flash the BIOS, even if the system does not pass POST and does otherwise not boot anymore. This procedure is also known as Crisis Disk.
First format an USB flash drive with FAT. It does not need to be bootable.
Download the latest BIOS, and extract all files. Put both FLASHIT.EXE and the BIOS file with FD suffix in the root directory of the flash drive. The files must not be in a folder. Rename the BIOS file to ZG5IA32.FD before proceeding. It only works with this exact filename.
Turn the AA1 off, and verify both battery and AC adapter are plugged in.
Press Fn and Esc simultaneously, keep them pressed and press the power button. Release Fn+Esc after a few seconds. The power button starts blinking at this point. Press it once. The AA1 will now access the files on the flash drive and initiate flashing the BIOS. After a while the power button stops blinking, and the AA1 reboots by itself. Wait patiently.
If it doesn't reboot, but keeps blinking, wait at least a few minutes before turning it off, and try again.
Oct 06, 2011 | Acer Aspire One AO532H-2527 Netbook
Set the bios password and forgotten whaat it is
You need to preform a Acer Aspire One BIOS Recovery
instructions here: http://macles.blogspot.com/2008/08/acer-aspire-one-bios-recovery.html
Summary:
You need a flash drive formatted as fat (Right click on drive. Click format. Select fat for file system. Press start)
Down load the bios 3310 from here: http://macles.blogspot.com/p/acer-aspire-one-bios.html
Extract all files. Put both FLASHIT.EXE and the BIOS file with FD suffix in the root directory of the flash drive. The files must not be in a folder. Rename the BIOS file to ZG5IA32.FD before proceeding. It only works with this exact filename.
Make sure laptop is off and has battery and power plugged in.
Plug in flash drive to netbook. Press Fn and Esc simultaneously, keep them pressed and press the power button. Release Fn+Esc after a few seconds. The power button starts blinking at this point. Press it once. The netbook will now access the files on the flash drive and initiate flashing the BIOS. After a while the power button stops blinking, and the netbook reboots by itself. Wait patiently.
Aug 20, 2011 | Acer Aspire One AOD150-1920 Netbook
Only a black screen, no indicator lights are nurning
I am using an Acer and it happened to me thrice. It is an easy fix.
If it doesn't reboot, but keeps blinking, wait at least a few minutes before turning it off, and try again. Good Luck
Jan 24, 2011 | Acer Aspire One PC Notebook
Computer is turned on, but screen is black
Link to latest BIOS
Sep 21, 2010 | Acer Aspire One PC Notebook
My acer aspire one 532h-2db blank screen but the power is on. please help me! thanks.
Thank you for contacting Fixya. This is Anil.
I understand that the Netbook starts but there is not display on the screen.
It may happen due BIOS failure on the computer. Try updateing the BIOS. Updating the BIOS will require a USB flash drive to store the BIOS information on during the update. To perform the update to the BIOS:
Go http://gd.panam.acer.com/home/ and download the latest BIOS for the netbook.
Extract the files from the downloaded zipped BIOS file.
In the Dos folder, Copy Flash.Bat; Flashit.exe; Nav50.fd to the USB flash drive
Ensure that the AC adapter is plugged in.
Insert the USB flash drive into a USB port.
Press and Hold down the Fn and the Esc keys together and press the power button.
When the unit's power light comes on wait a few seconds and release the Fn and Esc keys.
After the keys have been released the power light will start to blink.
During the BIOS update process the display will be blank.
Let the unit run and after approximately 1 to 7 minutes, the unit should reboot and the BIOS will be updated.
If the unit fails to reboot, or the BIOS was not updated sucessfully, try the steps again. If the unit continues to fail to reboot, the unit may need service.
I believe the above resolution should resolve the issue, however, if the issue still persists, please contact us. We will be glad to help you.
Thank you. Have Great Day.
Regards,
Anil.B.R
Jul 30, 2010 | Acer Aspire One PC Notebook
I turn my Acer on and nothing happens. The light
Try this it worked for me
  1. Go here and download the latest BIOS for the netbook.
  2. Extract the files from the downloaded zipped BIOS file.
  3. In the Dos_Flash folder, rename the BIOS file from 3310.fd to ZG5IA32.FD, in all capital letters.
  4. Copy ZG5IA32.FD and Flashit.exe to the USB flash drive
  5. Ensure that the AC adapter is plugged in.
  6. Insert the USB flash drive into a USB port.
  7. Press and Hold down the Fn and the Esc keys together and press the power button.
  8. When the unit's power light comes on wait a few seconds and release the Fn and Esc keys.
  9. After the keys have been released the power light will start to blink.
  10. During the BIOS update process the display will be blank.
  11. Let the unit run and after approximately 1 to 7 minutes, the unit should reboot and the BIOS will be updated.
Note: These instructions are only for the Acer Aspire One AOA-110 and the AOA-150 netbook series and should not be performed on any other model Acer Aspire One.
Mar 27, 2010 | Acer Aspire One PC Notebook
Keyboard doesn't work
If keyboard is not working then there is some issue with connectivity of the keyboard.
For touch pad there will be a Fn combination (Fn+f8 or Fn+esc ) and you can try pressing the combination simultaneously.
Thanks.
Mar 04, 2010 | Acer Aspire 5610-4648 Notebook
Black screen acer aspire 4315, changed screen & inverter but still no joy any help please.
If the screen is black and the power light & fan still work....try this:
ASPIRE ONE BIOS FLASH RECOVERY
First format an USB stick with FAT.
Download the latest BIOS, and put both FLASHIT.EXE and the BIOS file in the root directory of the stick. Rename the BIOS file to ZG5IA32.FD, that's important. Do not remove the USB stick.
Turn the AA1 off, make sure both battery and AC adapter are connected. Press Fn+Esc, keep it pressed and press the power button to turn the AA1 on. Release Fn+Esc after a few seconds, the power button will be blinking. Press the power button once. The AA1 will now initiate the BIOS flash, do not interrupt it under any circumstances. After a while the power button will stop blinking, and the AA1 will reboot shortly after. Wait patiently.
The BIOS has been flashed and all settings reset to default.
If for some reason you made a mistake during the procedure and it doesn't reboot by itself wait 5 minutes before turning it off, just to be safe that it isn't still flashing the BIOS.
http://support.acer.com/drivers_download.aspx
Jan 19, 2010 | Acer Aspire 4315 Notebook
Black screen on acer aspire one .tryed download the bios from acer on usb.it works but computer clicks on and off still black sreen.no lights at all just power lights.
TRY THIS AGAIN............ i have this problem 2 days ago.. and this works on me... maybe on your's too you may need to flash your bios. why need to flash the bios.. ? 1. had the black screen of death. or deleted the bios how to flash the bios: STEP 1.download the AA1 BIOS from this link: http://www.acerpanam.com/synapse/data/7117/documents/AS1_BIOS_3309.zip 2. extract the file 3. rename the file 3309.fd to zg5ia32.fd 4. put zg5ia32.fd and FLASHIT.EXE onto the usb drive now, start the process STEP 2 A. make sure the power cable is in B. the laptop is turned OFF C. Plug the usb stick in! STEP 3: Press and HOLD down the FN and ESC key together then press the power button, while holding the buttons release the power button and continue holding FN and ESC for about 5 seconds release the buttons and the power light will start to blink let the laptop run and DO NOT PRESS anything this can take upto 8 mins when it's done the laptop will restart. this works on me... good luck.. and i hope it will help you.....
Jun 10, 2009 | Acer Aspire 5100 Notebook
Battery will not charge
Power reset the unit, unplug it pop out the battery and hold the power down for a minute, put the battery and ac adapter back in and start her up, the mobo was probably still holding power when the battery died causing a "hiccup"in the system, this should resolve or at least help a little
Jan 23, 2009 | Acer Aspire One PC Notebook
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
