Question about Soundcraft FX16ii Mixer
Only channels 1 to 8 work - Soundcraft FX16ii Mixer
  • Soundcraft Master
  • 3,382 Answers
Check page 14 of the manual. You probably have condenser microphones on the upper channels. If so you simply have to turn on the phantom power, be sure the levels are low when you do this otherwise you may blow a speaker.
http://www.rcc.ryerson.ca/media/2011StudioDSoundcraftfx16ii_UG.pdf
Posted on Oct 23, 2014
Not working
Try to connect your computer hard wired to the router. Check if you could ping the router. If yes, try to access it. For the wireless channel, I suggest you try channel 1, 6, 9 and 11.
Feb 24, 2010 | 2wire (2701HG-B) Wireless Router
Channel 2 doesnt work. Channel 1 works perfectly fine and i have been using the mixer for abt a yr and from one day to another channel 2 stopped working.
did u find any solution with the mixer? I have a similar problem. Channel 2 works great, Channel 1 is sending only the Left side, something like Mono instead of Stereo.
Feb 21, 2010 | Nu Mark Numark Dxm01 DJ Mixer With Two USB...
I can get channels 1 to 4 can't get channel 5 and no freeview
Hi, I had the same problem, try removing your aerial from the box - retuning and saving so it blanks out all previous channels and then reattaching the aerial and doing another retune, this worked for me. Good luck.....
Oct 06, 2009 | Televison & Video
6 mnths old Alto L8 Mixing desk developed hiss on channel 1 only.
The slider or the amps for channel 1 may have a problem.
Sliders do wear out.
Try shorting channel 1 input and see if that affects the noise. A hissing noise is probably a bad preamp chip. That is shop work at a repair facility.
Aug 16, 2009 | Music
Pioneer deck kicker sub 2 mossfit amps
scanman84: i would recommend using the 2 channel 300W amp to drive the dual voice coil alone. i wouldn't combine the single channel amp with the 2 channel. you can't tie the 2 channel outputs together & use that on 1 voice & attach the single channel amp to the other, plus there could be slight differences in amplification & timing which, could cause the sub to have minimal movement or cause a canceling effect which would reduce the spl, sound pressure level. if you need more volume use the lowest impedence speaker recommended by the amp's mfg & if you need serious volume, go with a higher output single 2 channel amp. just make sure you have sufficient wire size to handle high powered amps. example, 8awg wire is rated for 73 amps. also make sure the amp is well grounded with nut & bolt connections to the frame & that there is good ventilation.
peace-out
Jan 06, 2009 | Car Audio & Video
Audiobahn A4601T, only 1 audio channel works
Is it the same channel in both amps that produces output?
Have you tried all combinations of setting for the switches and pots on both amps?
Oct 25, 2008 | AudioBahn A4601T Car Audio Amplifier
Dual channel memory supported?
have you checked the bios setup may not be the problem but worth a try
My computer recognized dual channel automatically do you have them set in correct Channels as they are specific for dual channel
normally labeled 1 2 3 4 etc must put dual channel ram in 1 and 2 channel
Jul 25, 2008 | ASUS P4P800 SE (890552603657) Motherboard
Only 1 channel works for both the A - B selection
If only 1 channel works for A and/or B speakers, you have an amplifier failure issue and the unit needs to be repaired/replaced.
If you have audio in both channels on A, but only 1 on B - then you need to check the connection for the B channel,
Most receivers from the 1980s forward require that to use A *and* B speakers at the same time, all must be connected.
May 14, 2008 | Technics Audio Players & Recorders
Can't get to "Video 1" to play DVDs
try turning your dvd player on and then doing a channel search if that does not work just buy a RF modulator and hook up your dvd player to it and it will run on channel 3 or 4 and will switch over by itself when you turn on your dvd player
Feb 26, 2008 | Emerson EWF2703 27" TV
Mitsubishi HS-412UR - Audio - Right Channel Not Working Properly
One of the strangest things that has happened to both the consumer and the technical field has been the use of a flexible adhesive on many of these machines' circuit boards. The glue in question is vanilla-colored, and has a tendency to react to electricity by inducing capacitance, resistance, and in some cases, even causing inductance issues. The fix, of course, is to remove as much of this material as possible, and following right behind with a nylon-based retainer. Then, if the problem persists, a followup with tried and true technical procedures...accordianman
Feb 12, 2008 | Televison & Video
Soundcraft FX16ii Mixer Logo
118 people viewed this question
Top Soundcraft Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Soundcraft Audio Player and Recorder Expert? Answer questions, earn points and help others
