Question about Directed Electronics Dei 508d Dual Zone Proximity/motion Sensor 4 Car Alarm
Want to install dei 508 to 5303 alarm - Directed Electronics Dei 508d Dual Zone Proximity/motion Sensor 4 Car Alarm
My Viper Alarm started going off while I was driving. I pulled over, shut everything off. Got out of the car and closed the door and locking and unlocking the vehicle wouldn't shut the car off. I opened...
The alarm may not be going off. Rather it may be a malfunction of the relay that is driving all the sirens and piezo. Next time it happens check for flashing parking lights. They will flash only when alarm is going off. Also ignition input to the alarm prevents this alarm from going off while driving. Panic from the remote can still be triggered. Got to play detective....
Feb 27, 2017 | Viper Vehicle Parts & Accessories
Hey MECP guy, what a job you're doing; THANKS. I want to buy the Prostart CT-5472W for a 2004 Lincoln Navigator. I also want to get addt'l modules like DEI 504D shock sensor 506T audio sensor
Yes, I frequently use DEI modules with Audiovox( Prestige and Code) alarms and remote starters. I just have to hardwire them to work with the systems.
Oct 26, 2012 | Vehicle Parts & Accessories
I have a horn that sounds when my hay baler chamber is full. I am looking for a timer relay that will allow the horn to sound for 3 to 5 seconds and then disconect the circuit so it won't drive me...
DEI 528T appears to be 12Volt 'wait to start' or ON-delay timer.
528 receives electrical signal, and then delays the start-circuit by up to 60 seconds.
For example home alarm system. Door is opened and alarm sounds. Install DEI 528 and set for 60 seconds: Door is opened and alarm will not sound for 60 seconds.
You need 12-volt off-delay timer.
Off-delay timer receives electrical impulse, and then begins a countdown.
After countdown expires, then circuit turns off.
ELK-960 appears to have off-delay feature for 12V DC
http://www.homesecuritystore.com/p-423-elk-960-delay-timer-module.aspx
Use wiring diagram #7 for alarm cut-off:
http://download.homesecuritystore.com/downloadmanual.aspx?FileName=ELK-960_Install.pdf
Aug 25, 2011 | Directed Electronics Dei 528t Pulse Timer...
So I have a viper alarm system in my car and awhile ago the remote got wet, so in order to be able to start my car i had to disable the alarm by turning the ignition on and pressing that eraser like...
You have to turn off your ignition and immediately press that 'eraser like button'(valet switch) for a second and release it. Alarm will then come out of valet mode and your remote should work, if it's good.
Jun 01, 2010 | DEI Valet Keyless Entry System
I am trying to find an installation manual for a python 1400xp online.
Have you tried DEI's web site and go to support and scroll down to where you see installation manuals for that alarm and either save it or print it ( have lots of paper though because the ****** is 56 pages)
Aug 10, 2009 | DEI Python 1400XP Remote Start/Keyless...
I have a DEI 471T remote start/lock. The parking
There is a white wire coming from the alarm, there should be a blue 15 amp fuse in that wire, close to the brain for the alarm. It sounds like you have blown that fuse.
Aug 10, 2009 | Directed Dei Valet 561r Remote...
Python 990 isnt locking or unlocking my doors .
Its going to be either the wires going to the locks or the programming in the alarm. The only way to tell is to get the wiring tested. A plug could have just pulled out also. Do many variances for one straight answer.
Jun 04, 2009 | DEI Python 990 2-Way Security...
What fuses does it take? Have it in my car but there are missing fuses also have other dei products in my car that are wired but missing fuses. Please help!
I'm still digging but I have some info for you. DEI- 530 is a Window automation system. DEi- 529 Is a window roll up module. DEi-520 is a battery back up.
May 04, 2009 | Honda Civic Cars & Trucks
Intermittent arm/disarm of Python model 560XV
this "could" be a bad ground, however, usually when these units lose ground, they activate the siren at a really low level, because they are trying to ground through the siren.
I would say to check where the antenna plugs into the main unit,(brain) but honestly, in 17 years of dealing with DEI alarms, 99.9% of these problems are due to the transmitter - it may blink the LED like it is supposed to, but that doesnt gaurantee it is sending a signal. I would recommend buying a new transmitter and programing it to the brain.
Jan 15, 2009 | DEI Python 1400XP Remote Start/Keyless...
Directed Electronics Dei 508d Dual Zone Proximity/motion Sensor 4 Car Alarm Logo
Top Directed Electronics Home Security Experts
D. E. Hev
Tom Chichester
 Russ Hill
Russ Hill
Are you a Directed Electronics Home Security Expert? Answer questions, earn points and help others
