Question about iSymphony M1 Shelf System
Cd door is stuck - iSymphony M1 Shelf System
Cd stuck in sterio aparently there is a reset button to push and release cd.were is the button?
I'm not aware of any button on car cd units. Usually when a cd is stuck in the unit, you need to take another cd, open the door and gently lift or pry up the stuck cd to release it.
Dec 04, 2016 | Car Audio & Video
How do I open a cassette door that is stuck?
problem in belt
rotuate fly wheel door is open
Apr 28, 2014 | Sharp CD-BA250 CD Shelf System
Crossly turntable/cd tape player
If there's a small hole in the front of the door anywhere, push a paperclip in there to release the door.
Mar 04, 2014 | Slide-Co Sliding Glass Patio Door Latch...
CD stuck in player after an accident. Got it removed, and tried a CD again and it became stuck. Just had it removed again and now no CD will go into the player. Also, since the accident, the window on...
the cd transport mechanism is plastic when it breaks its f..... you will have to replace it,sorry.as far as the window is concerned,put the key in the door and unlock the car holding the key over will lower all windows,then lock the car and hold over the key,the windows will go up.(that resets the windows and SHOULD reset door rollback.)if not its a computer brain reset.
Aug 25, 2010 | 2005 Volkswagen New Beetle Convertible
Sonycmthpx9
if under warranty, send for repair.
No warranty, open it yourself and try to open the cd tray/door. remove anything stuck between the tray/door or wriggle the tray/door.
Aug 23, 2008 | Sony Audio Players & Recorders
Cd door player is stuck
Break it open. Then buy a new cd player.
Apr 20, 2008 | Curtis RCD843 CD Player
C d door stuck
you can find a small hole at the front side of your cd drive , carefully insert any pin inside this hole and press it , your cd drive door will open.
Some time holding the cpu in 90 degree angle while system is on and pressing the eject button releases the cd door.
Feb 06, 2008 | Computers & Internet
RCA 2656 bookshelf music system cd door
I have a similar stereo system and accidentally put two CD's in one tray and it got stuck and could not open. What I did was unplug everything from the unit and took off the side panel. After some careful fiddling I got it to open. You could try something like that.
Dec 30, 2007 | RCA RS2531 CD Shelf System
ASUS 52CD-writer's door is stuck....
Is the door stuck shut? If so there should be on the front a little hole about the size of a pin. Unfold a paper clip insert it into the hole and push firmly this will open the door. If not you can remove it from the computer and unscrew the sides allowing you access to the insides.
Thanks J
Nov 25, 2007 | ASUS (CRW5232A/QTWHT/G) CD-RW Burner
iSymphony M1 Shelf System Logo
65 people viewed this question
Top iSymphony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an iSymphony Audio Player and Recorder Expert? Answer questions, earn points and help others
