Question about Cuisinart Dcc-2600 14-Cup Coffee Maker
Machine keeps shutting off - Cuisinart Dcc-2600 14-Cup Coffee Maker
Water valve doesn't shut off completly ?
What kind of valve?
Watts Duel Washer Valve or individual
shut off valves?
OR-- the Washing Machine Solenoid Water Valve?
Aug 14, 2014 | Washing Machines
Commercial espresso machine
Sounds like the safety thermostats on the machine is tripping because the machine is overheating or the circuit breaker is tripping because machine needs more amperage.
Nov 14, 2012 | La Marzocco Coffee Makers & Espresso...
The tub keeps filling with water. I must run drain/spin constantly to keep the water from coming out.
Hi There,
Either the hot or cold (or both) water inlet valves has failed and is locked open. Keep running the drain/spin as you are doing and shut off the water supply from the machine. After you have shut off the water supply and the machine has fully drained, switch the power OFF as well. There will be service valves for shutting off the water supply at the ends of the hoses connected to the back of the washing machine. Hopefully, whoever installed it hasn't located the valves behind the machine or you will need to pull the machine out to turn the water supply off - I've seen this done far too many times and it's not clever. The machine will then need to be inspected and will probably need to have at least one solenoid replaced.
Please post back if you need further assistance.
Regards,
BElectric
Nov 30, 2010 | Kenmore HE3T Washer
My coffee machine keeps shutting off...
You should check to see if either the auto shut-off is enabled or a shut-off time is set. Check the display or cycle through the menu (middle button).
May 27, 2010 | Keurig B50 Coffee Maker
The water wont shut off
Check water valve. Solenoid may be stuck. This is where your hoses attach to, all one unit.
May 25, 2009 | Kenmore 24032\24036 Top Load Washer
E machines keeps starting up and shutting down.
hello you might have a virus or memory leak.the best easiest way is to reload the windows and if it happens again then you know its memory.
Jan 05, 2009 | Computers & Internet
Roper washing machine hot water won't shut off
An obstruction in the hot water-inlet valve may mean that it's no longer able to shut off and should be replaced. Good luck !
Sep 11, 2007 | Washing Machines
Cuisinart Dcc-2600 14-Cup Coffee Maker Logo
101 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
