Question about KitchenAid 24 in. KUDP01IL - Multiple Color Built-In Dishwasher
My LG dishwasher had pump replaced, worked fine for a week and now wont even start. no error codes, one solid blue ligh when turn on
LG dishwasher LD1419W2 which would not fill -error code IE. I replaced the inlet hose complete. Now it has the error code FE and the water overflows onto the floor when in wash cycle. Peter
Try resetting by:
turn off dishwasher
trip circuit breaker to remove all power to unit
wait 30 seconds
restore power
start dishwasher
the drain pump should start and drain all water then start a cycle. Good luck
Nov 14, 2017 | LG Dishwashers
I have a LG Dishwasher, Model LDF7551ST invert-er direct drive, and it's been getting this (OE) error, it worked fine for about a yeaR
Check to be sure the drain hose isn't clogged or kinked. If that checks out, check to see if the drain pump or drain pump filter are clogged. Sometimes objects that are put into the washing machine, for example combs, money, hair pins, etc. end up in the filter. Finally, if the drain line is clear and the pump seems to be clear, you may need to replace the drain pump assembly.
Jan 04, 2016 | LG Dishwashers
How to fix lg dishwasher that has code le
I think you may be getting IE code which relates to water inlet problems. Either the water pressure is low or the inlet valve may not be working properly.
Refer page 21 in the user manual which can be dowloaded from this site
Product Support
But if it is LE code then see this page for suggested fix.
LG Help Product Support and Troubleshooting LG USA
Jul 30, 2014 | LG LDF6810ST Stainless Steel Built-in...
LG LDS581 dishwasher HE error mid cycle
HEATING (ELEMENT) ERROR // Water heating error
The manufacturer has assigned this error or fault code to indicate a problem with the water heating circuit. Turn off the circuit breaker to the dishwasher for 30 minutes, allowing time for the appliance to cool; then restart the cycle. If error returns, check the heating element for continuity and check the wiring harness for any obvious signs of damage. If the heating element shows infinite resistance after testing with an Ohm meter, replace it.
Oct 01, 2017 | LG 24 in. LDS 5811 Built-in Dishwasher
Have a LG dishwasher with a OE error. Took machine ouside and it works well with the garden tap hooked to it. Put it back inside and does not work. I noticed a major kink in the inlet hose, would this be...
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 05, 2010 | LG 24 in. LDS 5811 Built-in Dishwasher
My Lg Dishwasher , model 12aw2 , has an error message OE shortly after start up , dishwasher is over 6 years old , is this a simple fault to repair? or not worth it ?
Feb 11, 2010 | LG 24 in. LD-12BW5 Free-standing...
I'm getting an "LE" code also, and the dishwasher will not drain.
LE is a Motor error
Wiring connection is OK? The Impeller of Washing Pump is locked. The rotor of Washing Motor is locked. The Blade is locked.
Check the wiring connection. Replace the cause of restriction. Replace the Washing Motor. Replace the PCB
Sep 07, 2009 | LG LDF6810ST Stainless Steel Built-in...
2H accures in digital read out. NO Cycles start, just a humming
Do you own an LG LDF6810ST dishwasher? If not, please reply with the manufacturer name, model and serial number.
Are you saying that the display that normally shows the time is displaying an code of 2H? On an LG, that means 2 Hours, (120 minutes) and is not an error code.
On an LG with a symptom like this, I would arrage to replace the main processor card (PCB). You would be getting an error message if the motor (wash or drain) had failed.
Mar 30, 2009 | LG LDF6810ST Stainless Steel Built-in...
Im getting error code "LE" on my lg dishwasher
While LE is the LG error code for "Motor Error": The Motor is working abnormally, it does not always mean that the motor itself has failed.
As you replaced the pump motor, are you certain that the Impeller of Washing Pump is turning freely? Next, is the Blade spinning freely?
If everything above is obviously not locked, the next item is the controller board. (PCB)
Hope that helps. Please report back with your findings! Good Luck.
Mar 19, 2009 | LG LDF6810ST Stainless Steel Built-in...
LG Dishwasher model LDF7811 doesn't clean
LG DOES ****. We had this dishwasher and from the very beginning it didn't seem to dry and within a few months it was not cleaning as well as we had hoped. Within 9 months it had gotten so bad that we were really unhappy and then we got an error code. LG arranged for a local repair company to take a look at it. They ended up replacing EVERY part of the dishwasher except the tub itself. They replace the pump, the heater, the whole door assembly, the wiring harness (the wires had started melting into the sound proofing material), the electronics. Literally everything. From that point on we really noticed that we were getting food chunks on everything. Not only that, all the dishes were greasy and it wasn't even coming close to drying. There was mildew and mold growing inside the tub! Finally I got fed up and threw a fit with LG. They sent another repair guy out and he told us it was going to take 3 weeks to get a brand new pump and heater because the replaced heater had failed. After I complained to LG the repair guy got the parts in a week. He quickly replaced it and tested it and it flooded our kitchen (hardwood flooring) and leaked through the floor to the ceiling downstairs. The new heater was faulty. Not only that, the repair guy told us that the first repair, 9 months earlier, had not been completed and our turbulence detector had never been hooked up. Our solution? We fought with LG and Home Depot, where we got it, and LG offered to replace it with a new dishwasher. I said forget it, we didn't ever want an LG dishwasher again. Home Depot stepped up and took back our 2 year old dishwasher and refunded all our money. We bought a KitchenAid and we LOVE IT!
Jan 01, 2008 | LG 24 in. LDF 7811 Stainless Steel...
KitchenAid 24 in. KUDP01IL - Multiple Color Built-In Dishwasher Logo
15 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
