Question about Cuisinart Grind and Brew 10 Cup Coffee Maker
Coffee Maker won't heat up - Cuisinart Grind and Brew 10 Cup Coffee Maker
Keurig B60 coffee maker won't draw or heat and "not ready" stays on
Handel not in positive position to start brew process.
Jan 26, 2013 | Keurig B60 Coffee Maker
Bloomfield coffee maker won't brew hot water
Do you mean the machine will not heat up?
Oct 18, 2012 | Bloomfield 8572 Coffee Maker
Keurig won't heat water
Element may be damaged and in need of replacement. Return for service.
Oct 03, 2012 | Keurig B60 Coffee Maker
WATER WON'T STOP RUNNING OUT AND WILL NOT HEAT
Seals failed and need replacing. See manual.
Aug 21, 2012 | Keurig Platinum B70 Coffee Maker
Why won't the hot water empty into the coffee pot?
Make sure your caraffe has its lid on , and check the bottom of the filter. it usually has a valve preventing coffee from leaking when you remove the caraffe. the lid pushes the valve back open when you place the caraffe back into the machine.
Jul 10, 2012 | Cuisinart DCC-2200 14-Cup Coffee Maker
It won't brew when it says its brewing. Why won't it brew my coffee? Just seems to be really slow and I have only had this coffee maker about a year.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Aug 18, 2011 | Keurig Platinum B70 Coffee Maker
My keurig won't heat up and the switch at the back won't go on or of
The problem is often that the machine develops a leak in the hose that is rightover the transformer...the water drips onto the transformer and kills that...then you have no power to run the machine.
Here is a tip that I wrote about this problem...
Keurig OneCup Coffee Brewer will not turn on
heatman101
May 26, 2011 | Keurig B70 Coffee Maker
Jura c9 on out of box start up won't leave rinse cycle and enter heating mode. Checked rotary dial but it seems fine.
You need to be patient and keep pressing the rinse button. I took a few water tanks of rinsing before it clicked over to heating mode. The manual and DVD need to mention this!
May 13, 2011 | Jura Capresso Capresso IMPRESSA C9 One...
My KF 180, Type 3115 Braun Coffee Maker stopped working, no heat, no purking but red light is on. I'm trying to open the bottom cover, have removed the centre screw but still can't get past the clips. I...
I have the same problem and even though I was able to disassemble the unit + get to the heating element, I fear I won't ever find a replacement part. Element is def bad; checked w/ohm meter across element - OPEN.
Like everything else we buy, coffee makers are throwaways when they fail so no one sells repair parts.
SAD!
Mar 13, 2011 | Braun FlavorSelect KF 180 Coffee Maker
Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
18 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
