Question about Coffee Makers & Espresso Machines
My new neff warming drawer will not warm up when I switch it on
When I turn the drawer on the ceramic plate does not warm up have tried putting plates in and turning it on but still does not work
GARYDALE
  • 15 Answers
SOURCE: JVC KD -S680 needs help
all radios like your has two power inlets one is battery and the other is Acc or Ing. The battery line keeps power in the radio after you turn off your car both lines must work for the radio to turn on it sounds like a resister burn out thats why your face plate was warm.
Posted on Sep 25, 2006
Rotu
  • 175 Answers
SOURCE: Subzero 700BR Refridgerated Drawers Not Cooling
If your unit is new enough to have an on/off button on the keypad, then put it into diagnostic mode by pressing and holding the "colder" button, the pressing the on/off button at the same time. the display should change and it should read a temp like 67r or 67e. you can scroll back and forth through the 2 temp readings by pressing the colder key. If the fridge has been running, the temp of the one ending in "e" should be no more than 38. If it is, then you most likely are low on freon and will need to have the evaporater replaced. The part will be covered under the 12 year parts warranty, but the labor will only be covered for 5 years.(from date of install, not date of manufacture printed on the lable) If you want to go into it more, take the lower drawer out and remove the 6 screws holding the panel to the floor inside the fridge, then slide out the floor panel. Look at the coils in there, and if you see a ball of ice on the left hand side, you have a freon leak and the above repair is what youll need to to. if its older than 5 years, ecpect to pay about$500 to have it fixed...it's a mojor pain. If its less than a year out of the 5 year, call subzero...theyll probably take care of it for you anyways. Good Luck!
Posted on Jul 18, 2007
  • 19 Answers
SOURCE: Coffee maker shuts off too quickly
It seems this coffeemaker insists on shutting itself off after 4 hours,
or whatever "auto-off" time you've programmed in. The only work-around I've found is to switch it to "Brew" and cycle the power switch off and on every time you pour a cup. That will start a new
4-hour timer cycle. Since the pot's still hot, it will go quickly to the
"brewing done" state and render 5 beeps.
Posted on Jan 19, 2008
Enquiry
  • 152 Answers
SOURCE: Warming Plate
actually the warming plate have heating element... they stop working only when the heating element gets open circuited or wire to that plate gets cut....
Posted on Jan 31, 2008
  • 60 Answers
SOURCE: Warming plate boils coffee.
Make sure you are using the type of commercial coffee pot like the one in the picture. They don't have to have to be plastic with the metal bottom, they can be all glass. The commercial pots are heavy duty and usually disperse the heat well.
If you are using commercial pots the only solution without replacing the warmers is to put three pennies on the warmer and to put the pot on top of them. The pennies will get hot so don't forget and grab them but the pennies help to move the pot just a little way away from the direct heat.
Posted on Feb 09, 2008
Is the pull drawer just below the oven for storage only
They were originally sold as 'plate warming drawers' but have evolved as storage. There is no heating element in there, they just warm up from radiant heat from the base of the oven.
Dec 18, 2015 | Kitchen Ranges
Where can I get installation and operating instructions for a NEFF 29c warming drawer?
Hi Pat,
I suggest contacting Neff directly. You can email them or telehone them from choices on the page linked below:
http://www.neff.co.uk/customer-service.html
Apr 14, 2015 | Neff Ovens
A Neff warming drawer red light flashes
There is a 'plug and socket' connector at the back of the warming drawer which does wear and eventually start to make erratic or no electrical contact. The drawer electronics read this as an open drawer and switch off the power to the heating element (flashing red light). If your competent the drawer can be stripped down and the contacts serviced or replaced otherwise consult a service technician.
Dec 07, 2012 | Neff Ovens
My Corelle plate (round) is wedged in my round Rival stoneware crockpot - have tried everything I can think of to unstick it - soap, oil, hot water, cold water -- only the tip of a thin knife fits between...
suggestion to try, depending on how far the plate is down in the stoneware, try filling the Crockpot with warm water. Then plug in the Crockpot and turn it on to a medium heat. Then keep close watch on it, as the stoneware warms up it may expand enough to release the plate.
May 24, 2011 | Microwave Ovens
Problems with the fan on neff b1641 oven
Hi, from what you describing it can only be either the oven element (located behind the back plate inside the oven, hold by 6 screws, 2 at the top, 2 at the bottom and 2 on the sides). Switch off the cooker, remove this panel and have a look at the element, looking for unsual bends, corrosion, or burn marks. The other possibility is the safety stat located near the element connections at the back of the oven. Pull the oven out, remove the back chassis panel and inspect the stat.
Cheers
Feb 19, 2009 | Neff B1641 Single circotherm super...
Indesit PI 640
i find your problem is short of desame line that why it remained lighting,try to hang the connection to that light,try to find it one by one , the principle of the lighting here is like in the rice cooker when warm the light is yellow when cook it turn to red when you going to see it ,it is one connection only.there is a thermal plate ,when it sense extreme heat it will move that to switch off ,,then when it warm its switch on. maybe there is short to thermal plate or the thermal plate not working even extreme heat it will not shrink...try to find this plate .if my solution help you to understand the problem please rate me FIXYA...
thank you in advance Stevecarr.....
Jun 25, 2008 | Cooktops
Using a thermal pot
I also bought the thermal carafe; before I could hack the warming plate, my wife set the "Auto Off" feature to 1 minute, which shuts off the carafe heater. The settings are preserved unless you lose power for an extended period.
The warmer does still warm through the brewing cycle but it doesn't overheat the carafe (IMO.) Hope this helps.
May 29, 2008 | Cuisinart DCC-1200 Coffee Maker
Warming tray too hot
You can either replace the warming element with a new one, or some people put 3 or 4 pennies on the top of the warmer tray. Don't laugh- this really does work!
Feb 08, 2008 | Bunn VPR Coffee Maker
Coffee Makers & Espresso Machines Logo
29 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
