Question about JVC Car Audio & Video
What to do to hook-up JVCRX778VBK to JVCRX705VTN to make unit work as one unit
Make unit work as one unit, how to hook it up
Ematic esb112x
Try resetting the unit buy holding down the volume up and power button at the same time. It may work.
ELECTREPAIRUSA@ELECTREPAIRUSA.COM
Dec 28, 2016 | Audio Players & Recorders
Tv will not work
My guess here (seen this before) you either tried to hook up with units on or had more than one unit hooked to same speakers.
In every instance where this happens it gets the set---feeds back from unit into set via the audio circuit which can kill parts in main power supply in set that feed the audio output.
sorry but going to be a shop repair.
Oct 22, 2012 | Panasonic Televison & Video
I have lost all my HDMI inputs for my Hitachi L42X01AU, i had my PS3 hooked up and it worked but now when i hook it up none of the HDMI inputs work
try unplugged all units involved---HDMI does not like being hooked or unhooked with units powered and or on.
Wait a while and make the connections and then power set, box, whatever is inline back---the units will try to reboot and that may cure the issue- it is worth trying
Jun 17, 2012 | Hitachi Televison & Video
Have mex bt2600 sony xplode car cd player ::: also have sony xplode amp model no.xm 754sx problem is i want to hook up a subwoofer and the amp to the head unit (also currently have 2 sony xplode 3ways...
If the Sony front end unit (stereo) has RCA jacks (Left and Right) in the back it's an input to the Xplode amp. If that's right then the Subwoofer putputs should plug or wire into the Xplode amp. I haven't hooked these up for some time but try a search on Youtube with the units you describe I'm more than 90% sure that there are videos there.
Nov 19, 2017 | Sony MEX-BT2600 Car CD/ MP3 Player
I hooked up my Sony cdx m-600, all works fine but radio does not work. at all. Why?
make sure the unit is hooked to the antenna correctly. This unit will not play the radio and will disable the static noise on the radio. So ensure the antenna is properly hooked in. For more info on how to use the deck click here for the manual. got this directly off sony's website for model cdx m-600. So let me know if that it is properly hooked up and we can figure out where to go from there.
Aug 31, 2010 | Sony CDX-M600 CD Changer
Dead Samsung HTZ310
You can get your unit repaired. (cheapest option) You can hook up the speakers to another unit as long as it will work with the same impedance speakers. Don't hook them up to a receiver that is rated for 8 ohms. Your speakers are 3 ohm. The sub is a passive one, so the replacement receiver will have to work with a passive woofer.
Mar 15, 2010 | Samsung HT-Z310T Theater System
Hooking up head unit
the head unit i had all i did was hook the wire up to a ground and it worked fine.
Jun 26, 2009 | Car Audio & Video
Fuel gauge does not work at all
i recently did my chev s10 and they give you a new wire harness that you have to splice the wires and hook them up so it now has the same hook up. those wires are for your gauge as well as your pump. if your sending unit was not hooked up you would not go any where..take it back and demand this gets fixed.
Dec 21, 2008 | 2001 Chevrolet Blazer
No rca jacks
these are designed to hook to a head unit from Pioneer. There are many units that will work if they have a P as part of the unit number. There are some with some cassette units, some with CD units, some with other connections.
Dec 27, 2007 | Pioneer 12DISC CHANGER
Car Audio & Video Logo
14 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
