Question about LG RU-17LZ22 17 in. HDTV-Ready LCD Television
How to install a magic eye on new polaroid tv
Sky Magic Eye not working over SLX 8 way booster/spliter
have you got it set on second out put on the sky box as number one is just normal. all cables have to be set to second output using a splitter box . so its like this.
arial in booster.
out booster to sky box.
out to tv/etc on first output on sky box.
second out put to spliter linc. ( eg 4 rooms out four way splitter)
each room with sky eye fitted to end of the aerial from number feed from sky box.
with each room with Eye sky can be controlled
also check that RF outlet power supply is set on sky+ or HD in settings menu.
access this.
settings
select ( remote)
type 01 (select on remote)
RF outlets.
RF outlet Power Supply ON
RF channel 25 ( is best for most areas)
Feb 01, 2014 | Televison & Video
Virgin tvvo box
Not sure about about the transmitter but the magic eye thing is possible however you wouldn't be able to change channel unless your pointing your remote at your box because a sky box has power going through the magic eye but a virgin box doesn't
Jun 06, 2013 | Televison & Video
Help please purchase samsung smart tv ue37es6300 led hd tv connected it with magic eye to sky box in another room and picture is terrible much worse than tv we used before. Samsung say it is because it is...
Analog resolution is very low compared to what is possible on new HDTVs. Think of it as trying to spread a wallet sized picture out to the size of a billboard. You will see all the imperfections in the picture. The magic eye is not capable of sending a higher resolution picture. You need a different device to send the high resolution video.
Sep 24, 2017 | Televison & Video
Magic eye light is on, but the remote control doesn't work anymore
open the remote control, and clean the keypads from oxide, corrosion, dirty.
change the batteries and put a new ones.clena the contacts batteries with pencil erase.
retight the springs contacts batteries, for better contacts. and try again.
Otherwise you must go to the repair shop TV for fix it.
God bless you
Sep 23, 2012 | Televison & Video
Just installed a sky magic eye to my digital tv upstairs, works perfect. however I have now lost all my digital channels!!
Hi
If you have installed a sky magic eye, i am assuming you have taken a sky feed from the RF outlet of the back of the sky box to view sky in another room, if this is the case, this is an analogue feed which you would have to tune in manually to the second tv, this would suggest that you havent lost the digital signal you just have you second tv selected on analogue. On the assumption your system is connected like the following;
Sky box connections
Main aerial input
sky sat input
rf out to second tv
Reagrds
TechSupp12
Dec 12, 2010 | Televison & Video
Sky magic eye not working on hd
I work for Sky as an Engineer.
on your Sky HD remote:
service,
4,
0 1 select
make sure the power is turned ON
now go to the room you can not change the sky channels over with.
you should notice on the magic eye itself should now have a Red led light on it now. you should now be able to change the channel over just remember to press the blue sky button on the remote at the top otherwise this will not operate the sky box.
If not unplug this magic eye and try this directly into RF out 2 to make sure that its not the magic eye that is at fault. If it is working correctly then the light will appear.
Hope this helps
Little dish fitter
Aug 16, 2009 | Televison & Video
Stopped receiving sky on second tv - does my samsung need a reset
I install a lot of magic eyes etc.
You have checked that the magic eye lights up when it is connected directly into the sky box. So your eye is working correctly.
the next step I would take is with your sky remote in your main room. press SERVICES, 4, 0,1, SELECT go to RF settings and check the rf channel and make sure the power is on. Take a mental note of the channel number.
Now go into the room where the link is feeding. Turn on the TV and go to channel number 6 press your MENU button and then go down to setup. go across to manual install and then down to the channel number type in what you retrieved from you box ie rf channel and then type it in and STORE.
If you go into your main room and just put the normal tv guide on ie blue screen. then check that your getting the sky into the other room. IF you are then great it just needed tuning in. IF not I would remake the coax connectors. as there may be a bit of copper braid touching the centre core. once this is done your sky should be on all you need to do now is put the eye back on. Once you have done this the red light should appear on your magic eye. if not go to your main box and follow the first instructions I gave you and turn the power off on the RF and then save and then go back in and turn it back on and save.
Hope this sorts out your problem
Cheers
Little Dish Fitter
Feb 27, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Tv digieye
Hi.
At the back of the box there will be 2 rf outputs.
What you are looking for is the rf output 2. What you need to do is connect a rf cable from rf output 2 into the magic eye,which in turn plugs into the rf input on the tv.
To make sure that the 9v signal is being passed up the cable(this is what allows the magic eye to work)
go into services on the SKY guide the press 4(system set up) then 01 select. This will give you access to the installers menu. Press 4 (rf outlets) and then make sure that power supply is ON. Save new settings.
This will now let you use a magic eye.
http://dysonmanuals.llc.nu/
Chris.
Mar 11, 2008 | Televison & Video
Open Questions:
LG RU-17LZ22 17 in. HDTV-Ready LCD Television Logo
13 people viewed this question
