Question about Garden
My gardenmate two dial automatic tap timer does not work.new battery. it starts then it cuts out
2 Suggested Answers
  • 3 Answers
SOURCE: can't find battery compartment on
Batteries located inside, accessible from behind unit. ie under round cover, just unscrew...
Posted on Dec 21, 2010
Gardenmate tap timer
this kind of machine they need a traction battery
Nov 27, 2013 | Garden
Instructions for gardenmate two dial timer
one of them should be for night and one for day night will be black and day white and there should be numbers
Nov 22, 2013 | Garden
How do I program a GE Relocatable Power Tap EMP700UL-MT
TIMER INSTRUCTIONS:
When the timer is plugged in, the timer's dial will turn clockwise. The pointer, on the face of the dial, points to the current time of day.
1. Locate the segments on the outer edges of the timer's dial. These segments, each representing 30 minutes, can be pushed down (try using the tip of a pen or pencil). Conversely, segments pushed down can be easily pushed back by hand. Be sure all segments are pushed up before programming. Select a time period (or periods) you want the device turned on, push down the segments that fall on or within that time period. For example, to have the timer turn a device on 10PM and off at 2AM, push down the segments representing 10PM and 2AM, and ALL the segments in between. See Figure 1.You may need to turn the dial clockwise to access the desired segments.
2. Rotate the timer's dial clockwise until the pointer on the face of the dial points to the current time of the day. Note: Nighttime hours (from 6:30PM to 6:30AM) are highlighted.
3. Plug the timer into an electrical outlet convenient to the device to be controlled.
4. Plug the device into an outlet on the timer. Turn the device's switch to the on position for automatic control. The timer will not turn the device on if the device's switch is in the off position. The device will now turn on and off at the times you have set. In case of power failure, reset the time of the day as explained in step 2.
Sorry no Image.
Dec 04, 2011 | Televison & Video
I have replaced the batteries on my Gardenmate Dual Outlet Tap timer, and it is still not working. The system is only 12 months old, and I am unable to solve it. Can you please help me.
I reckon they're useless. New batteries still aren't powerful enough to drive the whirring gears of the timer inside (they only take AAA batteries).
I have the same problem as you, which has happenede on both timers I've bough...they usually give out after a month or so and nothing gets them going again,
Sadly a dreadful product, poor design and waste of money. Shame really as it could be so good to really "set and forget"
Feb 20, 2011 | Garden
Can't find battery compartment on gardenmate dual outlet two dial automatic tap timer
Dec 12, 2010 | Garden
I bought a Westek TM77DHB Automatic Timer and the instructions that I received were not only cut in half (with the other half missing) but they were in Spanish. I have no idea how to this. Someone please...
You are replacing switch with 2 wires
One of these wires goes to timer black wire
The other wire goes to timer red wire
When finished, if these two wires are reversed the timer will not work, so go back and switch them
The green wire connects to bare ground wire
Timer white wire connects to white neutral wire
For details how to connect wires:
http://waterheatertimer.org/Programmable.html#wire
Once the timer is wired, the slide switch has to be moved to far right.
Turn dial to start countdown.
Finally::
If you have Spanish and want English, you want Google translate >> it has helped me translate detailed electrical manuals written in Italian
http://translate.google.com/#it'en'
Oct 10, 2010 | GE 60minute Automatic ShutOff Timer Switch...
Automatic cycle dries but doesn't turn off GE
Check for bad motor timer. Attached to dial control. Test by turning dial to timed position without starting dryer. Dial should return to off. Timer is available online.
Jul 11, 2009 | Dryers
Garden Logo
42 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
