Question about Kodak ESP5250 All-In-One InkJet Printer
How to charge m753 battery - Kodak ESP5250 All-In-One InkJet Printer
I have a easyshare M753 kodak digital camera I have a new battery it will not charge whn I plug it into my computer and charger it will not charge the green light does not come one and the battery is in...
Hello Barb, I am not sure if you are dealing with a bad battery or you are having problems with the camera, I would suggest trying a new battery as this is the cheapest route to take,then will will know for sure if it is battery related or a camera failure.
Best Regards, Russell
Dec 12, 2012 | Kodak Easyshare M753 Digital Camera
My M753 Kodak Digital Camera won't charge the battery or turn on. Is there a resolution to fix it??
If the battery is the problem then yes it can be fixed, but you could have a more serious underlining issue, you said the battery was not charging, is the charging light coming on ? or is it completely dead? If the light is working then the battery needs to be checked, if there is no charge light, this would indicate a systems control board problem which controls vital areas of the camera.
Feb 13, 2011 | Kodak Easyshare M753 Digital Camera
How long to charge battery
Your Kodak Easyshare M753 Digital Camera should get fully charged in less than 3.5 hours.
The maximum you can charge or keep the batter for charging is 3.5 hours particularly for your model.
If this is not the case and your battery does not get full charged or takes more longer time then there are chances your battery is worn out and may need a replacement.
However, if you are using re-chargeable batteries then you can also charge the Kodak battery by connecting it to PC/Laptop
For further reference, please check this link as well - Link
Regards,
Fixya Technical Team
Nov 02, 2010 | Kodak Easyshare M753 Digital Camera
We have a M753 7.0 camera that is giving us a 122,1,0,0 Kodak lens error - thoughts?
Here are the steps:
1. Make sure you will install a new or fully charged
battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from
your camera, then wipe the battery contacts with a soft,
clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
If issue persists, call 1.800.235.6325 for repair.
Thanks.
Neerak21
Sep 25, 2009 | Kodak Easyshare M753 Digital Camera
My Kodak EasyShare M753 wont turn on at all, but when i tried charging it, it still wouldnt turn on. I have tried lots of different charging methods, like my USD port that came with the camera and my...
This problem is frequently due to corroded battery terminals inside the camera. Before you purchase new batteries, remove the batteries and wipe the terminals with a soft cloth (heavy corrosion may require a fine wire brush, steel wool, or sandpaper). Remove any residue left in the camera by the cleaning. Clean the terminals on the batteries in the same manner, and then replace them in the camera. This cures most problems, but if it doesn't work for you, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
It uses a simple Q&A format to diagnose problems and propose solutions.
Jun 28, 2009 | Kodak Easyshare M753 Digital Camera
Kodak Easyshare M753 is not charging.
You LI-Ion battery is bad and not holding a charge. Buy a new one.
Apr 08, 2009 | Kodak Easyshare M753 Digital Camera
M753 kodak camera does not come on.
go to the nearest electronic place that sells cameras they will tell you wats wrong
Nov 28, 2008 | Kodak Easyshare M753 Digital Camera
Red light
Unless you have a spare battery and/or external charger it will be hard to tell if the charging circuit is defective or the battery is bad. I have seen posts in other forums with the same issue. I assume the camera is under warranty but you may want to purchase a spare battery and charger anyway as a backup if you are going to keep it.
Oct 13, 2008 | Kodak Easyshare M753 Digital Camera
Kodak m753
to remove the purple tint on your LCD screen, all you need to do is:
1. Turn the camera off.
2. Take out the batteries and wait about 10 seconds.
3. Replace the batteries with new or freshly charged batteries.
4. Remove the memory card from the camera.
5. Turn the camera back on.
If the issue is not resolved, send cam for repair. Kodak cameras have 1 year warranty
Aug 06, 2008 | Kodak Easyshare M753 Digital Camera
Won't turn on
Make sure you have the correct cable, not all will work for the m753
May 15, 2008 | Kodak Easyshare M753 Digital Camera
Kodak ESP5250 All-In-One InkJet Printer Logo
15 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
