Question about Home
Raymor plug is stuck
Have a raymor sink where the plug is a push down to close and push again to release - only the plug is stuck and will not release
2 Suggested Answers
kachbibi1
  • 979 Answers
SOURCE: pop up vessel sink drain
Look underneath the sink and you will find the lever that moves the drain up and down. It is probably stuck.
Posted on Jan 30, 2009
Emergency brake pedal stuck won't release, there is no release pull, the pedal is push down and push down again to release won't go down any farther to release! stuck on the side of the road right now
Start the vehicle, and while pushing down on the break put the vehicle in reverse and gently use accelerator to go back an inch or four. If that doesn't work continue to rock the car back and forth until the ebrake cuts loose
Mar 26, 2016 | 2004 Nissan Quest
Belle Foret pop-up drain stopper won't release
The drain should be able to pop up after vigorous pushing down on it. When you get it released, you will find it is clogged with goo. You will have to disassemble the pop-up (remember the order of disassembly) and clean all the moving parts then reassemble it.
Apr 06, 2014 | Belle Foret Bathroom Sink Faucet -...
Chevy Prizm Hood Is Stuck Closed
try pushing down on hood while somebody elss pull latch mau be stuck
Dec 06, 2013 | 1999 Chevrolet Prizm
Pop Up Drain in vessel sink
Have a look on u tube see if there is a video on it .
Oct 08, 2017 | Plumbing
Problems closing buggy, veers to the right when pushing
Hi
What country are you in / do you still require assistance with this and we can put you in touch with the relevant customer care team.
Jul 31, 2012 | Quinny CV078BHR Moodd Stroller Complete...
Open the hood of my 2000 oldsmobile bravada the latch under the hood is stuck
see if you can get someone to push down on the bonet above the latch as you pull the hood release like bounce the bonet slightly and try to pull it up at the same time if this works lube the **** out of ti before you close it again.
Jun 08, 2012 | 2000 Oldsmobile Bravada
Moen kitchen sink faucet side sprayer is stuck on
We had this same problem. We twisted off the sprayer cap to access the diverter valve under the trigger. The nylon diverter was stuck down into the cavity and was not popping out when the trigger was released. We pushed it down several times with needle nosed pliers to release it then applied a drop of household oil lubricant with the valve pushed all the way in. Then pushed and released several times to work the lubricant around the sides of the valve. After re-assembly, the sprayer seems to work perfectly again.
May 29, 2010 | Moen 7840 Camerist Single-Handle Kitchen...
Dynex 7' network cable stuck in dell laptop port
One of two things has happened. Hopefully this has happened: The thumb tab is not pulling the lock down far enough to release the plug. Take a very tiny straight slot screw driver (jewellers) or a very long pointed pocket knife, run it down the thumb tab on the outside until you have passed the locking lip. Then move it to one side. This will cause the lock to be pressed close enough to the plug that it will clear the locking lip and release the plug. Think of it as a shoe horn.
If this procedure is unsuccessful, it maybe the other problem. The plug slides in on 8 loose wires. They are only attached at the leading edge and as the plug is inserted it presses down these wires. The wires are loose at the other end and rarely develope an upward curl. This curl hooks on the plug and as you attempt to pull out it gets tighter and tighter. You should get a very thin but tough piece of packaging plastic and cut it just less than the width of the plug. Push it up between the contact side of the plug and the wires of the receptical, far enough to pass the end of the plug. Then pull the plug free. Always remember to press the thumb release as hard as possible to release the thumb lock.
Jun 27, 2009 | Dynex 7' Cat 6 Network Cable - Gray
Pop up vessel sink drain
Jan 28, 2009 | Ultra Max Eden Bath Black Ultra Zen...
2002 Jeep Liberty, rear window latch is ''locked'' & window is open
i was having the same type of problem. we just put a couple of washers behind the latch and then adjusted the latch and it solved our problem.
Nov 16, 2008 | 2002 Jeep Liberty
Home Logo
32 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
