Blinking led My polytron tv standby led is blinking
SOURCE: standby timer light blinking, tv will not turn on
Check out Ceramic Capacitor C514 by the horiz. output transistor (burned/shorted?) My question is how do you find the specs of the capacitor and where do you buy one?
Posted on Feb 08, 2007
SOURCE: Blinking Standby Light
KV32hs500 tv won't turn on. Standby light blinks 7 times, stops and then 7 more times, etc.. The tv will usually come on after about 2 hours or so of being off. Plays fine when on but once it gets turned off the problem happens again. Any suggestions? T.V. is 5 years old.
I have a similar problem . mine blinks 6 times or 7 sometimes also,and comes on with sound ,no picture for about 2 seconds then shuts off. Anything?
Posted on Jul 15, 2008
nuwan chinth
  • 111 Answers
SOURCE: Standby led sony MHC-GNZ888D blinking (intermitent)
power amp.or power supply printed circuit board.
nuwan.
Posted on Jan 13, 2009
SOURCE: STANDBY LIGH BLINKING 9 times...
I have a Sony SRS BBE Trinitron (WEGA). The last few days when I tried to turn it on using the remote the Red Light would go on but the TV did not turn on. I would have to press the power button again to turn it on.. I tought the remote battery was just low.
Today when I tried to turn it on nothing is happening and the Red Light is blinking 9 times ??? I tried to unplug it and try it again, still does the same thing ???
We need help...
Lori Nall
Posted on Jun 21, 2009
localwonder
  • 6784 Answers
SOURCE: TV won't turn on, standby LED starts blinking
HI, this is the result of an unstable power sector in this unit. the fly back is malfunctioning and, you will need to replace it asap. i will list the part number below and a link to a site as well. you can purchase this part on-line if you wish.
FBT ASSY NX-4521//X4
Sony Part Number: 1-453-310-11
CLICK HERE TO ORDER
Sharp32lcd tv aquos standby light is ok and power on green led some second then sleep led and power led blinking how to repair
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
May 20, 2016 | Televison & Video
Tip
Error code by led indicator samsung SP67L6HX1X
<img src="mas_baz.jpg" /><br />There are three LED indicators. LAMP, TIMER, STANDBY/TEMP. Each Led or combination leds indicated problem.<br /> <ul> <li>LAMP blinking : The picture will automatically appear in about 15 seconds.</li> <li>TIMER and STANDBY/TEMP blinking : A cooling fan inside the set is not operating normally.</li> <li>LAMP and STANDBY/TEMP blinking : Lamp cover on the rear of the set is not properly shut.</li> <li>STANDBY/TEMP blinking : Check if the ventilation hole on the rear of the set is blocked, because if the inner temperature is too high, the power will shut off.</li> <li>All LED blinking : Lamp may be defective.<br /></li></ul>It takes about 30 seconds for the TV to warm up, so normal brightness may not appear immediately. The TV has a fan to keep the inside lamp from overheating. You'll occasionally hear it working.<br /><br /><br />
on Mar 29, 2011 | Samsung HL-R6167W 61" HDTV
I have a Samsung TV model UN46F6300AFXZA 2 YRS OLD now with no pic or sound. The only visible thing is the blinking red LED (standby light) Any Suggestions?
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
Jan 14, 2016 | Samsung UN46F6300AFXZA - UN46F6300AF 46...
Sony LCD TV Red LED light constantly blinking
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Dec 06, 2015 | Sony KLV-32S550A 32 inch Multi-System LCD...
My Samsung tv model CS - 29M20MH switch onto standby mode with led flashing several times then switch off - no screen coming on
Jul 20, 2015 | Samsung Televison & Video
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
Nov 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My Sony Trinitron tv is not turning on. It has turned on a couple of times, but the standby light on the front is blinking. WHat's wrong?
Sony TV LED & Blinking Codes - What Does It Mean When Standby/Timer Light Flashes
Sony has provided a "self-diagnosis function" with your TV, that in the case of abnormalities or problems the LED or red blinking light on the Timer/Standby indicator flashes a number of times to indicate the issue.
when there is trouble with your Sony Television set -- it indicates the issue in either the diagnostic mode, or even more commonly by flashing a series of LED blinks or flashes on the front of your television. Each set or frequency of the blinks indicates a very specific problem with the television itself.
Sorry but unless you may be able to repair the television set yourself , please call a local repair shop to the have a repairman sent out,,
Take care and please Remember to rate/vote for us to
continue f
or Helping out the Community :)
Jul 08, 2011 | Sony Televison & Video
I have a Sony KDS-R50XBR1 that has no picture. When I turn on the TV, the green Power/Standby LED light blinks for about 30 seconds, then turns red and blinks five times. The Power/Standby LED repeats...
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen A2 slightly.
Jan 19, 2011 | Sony KDSR50XBR1 50" Projection HDTV
Tv turns on then turns off and the standby led starts blinking
Standby light blinking is sign or internal problem in tv and how many times it blinks is error code that will show what section of tv got problem. Count light blinks and let me know, there would be 3 seconds long pause in blinks so count pause to pause.
Jul 13, 2010 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Repair inquiry
     According to the LED BLINKING there must be some problem that are given below:
Diagnosis item:  Video out abnormality detection
TIMER/STANDBY
Indicater
Number of blinks:
5 times
Supposed malfunction:  Video out, IC7101, 7201, 7301 and others in C board circuit.
Q510,516,524 (A board)
Condition:TIMER/STANDBY LED blinks approx. 30 seconds,
and then blinks for the self diagnosis.
Self-diagnosis
screen display,
Diagnosis item: Results:   5 : AKB 000
So, This was the result of 5 times led blinking.I would suggest you to please contact any expert or strongly recommend to contact any SONY SERVICE CENTRE for repair because it's not an easy job to rectify this problem. Hope you better understand my sayings.
Thank you for using fixya.
Nov 29, 2008 | Sony KP-53HS10 TV
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Electro Med Services...
