Question about Scotsman DCE33PA1BC 15in Built-in Automatic Ice Machine/Maker w/ Drain Pump, Black
HOW TO TURN ON
HOW TO START IT WORKING
I have a 2002 sunfire... and i have trouble turning it on. Once it startes it is stuck there because it will not turn at all. Once it is in this position the wipes wont work, the windows wont roll down,...
sounds like you need a new ignition, reason nothing works cause once it doese turn over n starts the car the tumbler is stick in the starting position jus not far enough to keep the starter engaged but far enough the it still trying to go trough the start process which cuts the power to everything else till the ignition returns to the on postion
did you try jus turning the ignition far enough to when the starter engages jus let go of it so the car doesnt start and see if everything else still doesnt work if it dont i belive its the igniton
also with out starting it or engaging the starter as in just turning the key on to get power does anything work?
Jul 12, 2012 | 2002 Pontiac Sunfire
Turn on ignition everything works but want start
sounds like a starter. if possible without getting hurt maimed or mutilated, try tapping on the starter (best done with a rod standing beside the car) while someone holds the key in the start position. if car starts (works about 50% of the time) it's the starter. otherwise, if all lites come on, radio works, etc but nothing when you turn the key, replace the starter
Jul 07, 2010 | 2001 Hyundai Sonata
Key turns on but no click or start, Radio works lights work but key turns hard. No solinoid click and doesn't start.
check battery and connections first starting requires 300 plus amps lights about 50 so lights work but not enough to start try jump and if starts take to parts store and have then test battery
Jul 06, 2009 | 1998 Dodge Durango
Car will turn over but not start.97 audi a4 1.8
It sounds like you don't have quite enough juice to start it. Sometimes vehicles will turn over but won't start when battery is low. Have someone jump you with jumper cables and I bet it will start then have your battery tested. If it won't start try giving it a shot of starter fluid as well as jump starting it and this will probably do the trick. If not you will have to have it diagnosed professionally. Good Luck
Nov 29, 2008 | 1997 Audi A4
Turn signals
replaced turn signal flashers and muti switch turn signal still won't work Why?
Nov 08, 2008 | 2000 Jeep Grand Cherokee
Scotsman DCE33PA1BC 15in Built-in Automatic Ice Machine/Maker w/ Drain Pump, Black Logo
13 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Tim Whalen
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
