Question about Home
There is a creaking or squeaking noise when raising or lowering the seat or lid of our Caroma toilet. I have sprayed it all over with WD40 but it has made it worse. It is not possible to actually get into the enclosed plastic casing. Has anyone any suggestions as to how we can stop this noise?
HVACRH20
  • 237 Answers
SOURCE: Screeching Noise
If you know that the fan is the culprit then it can be replaced. The motors are fairly cheap and easy to replace.
Posted on Nov 18, 2006
SOURCE: Strange Noise - Creaking
I had the same problem. My fridge would make a creaking sound as soon as the freezer was closed. I took 10 minutes to trouble shoot the problem and pinpointed that it was coming from the icemaker. After wondering if I was going to have to replace it, I noticed a piece of ice wedged in a way so that the ice maker arms could not fall into the basin to make ice. The sound was the motor creaking because of the jam. Removed the ice and the sound went away. Now, I'm sure the motor will **** out in a few months since it has been jammed for 2 weeks burning up the motor. Oh well. Hope this helps.
Posted on Aug 09, 2008
dww0642
  • 79 Answers
SOURCE: creaking noise in front end 1997 explorer
I had the same problem. It would squeak kinda bad when I pull in my driveway. My cv boots were good. I found the ball joints were getting wore out, as well as the shocks were over 10 yrs old. I replaced the ball joints and shocks. I know my squeaks stopped, I personally believe it was the shocks that fixed my squeaking.
Posted on May 20, 2009
  • 1206 Answers
SOURCE: Caroma Sydney 305 toilet growls
this is caused by a slight leak in the wax ring causing a gurgle sound, remove it again and reset the wax ring should solve your problem. .
Posted on Jan 26, 2010
  • 105 Answers
SOURCE: tiled bathroom floor. Went to install toilet
hi, the tile is supposed to go under the toilet flange (the thing you put the wax ring on), very common "oops", can be rectified by placing another wax ring right on top of the first on. best to make the first one a "horn type" wax ring, then put the plain one (no horn) on top of first and try to smoosh it on just enough to stay in place so when you install toilet it doesn't move,.....cheers!
Posted on Jan 31, 2010
Where can I get a Caroma Monarch Toilet Seat and Lid? unit is from 1998.
try good plumbers supply shop ( not hardware)
contact the manufacturer on line for spares or distributors that may have spares.
May 24, 2015 | Caroma Home
Can up country shocks be used on a non-up country suspension. Worried about the travel and collapsed measurements. Not enough travel or too little?
doubtful the shocks would be the source of any creaking/squeaks. Most creaking and squeak noises are usually a result of worn/dry bushings. I would inspect all swaybar/control arm bushings for dryness and deteriation. Spraying wd40 on all rubber bushings in the rear may cause the noise to subside for a while until you are able to isolate the exactr source
Apr 30, 2015 | 2000 Jeep Grand Cherokee
I have an old Caroma Dual flush ( 15-20 years) and the washers on the inlet valve dont seem to be able to regualate the flow in, after the toilet has been flushed, as a result water sprays up out of the...
Well luckly the velve can be replaced by a modern 1. iets not exspensive and dosent take long to do, u will get a step by step apon perches.
Plz rate my advice
Jun 16, 2010 | Caroma 270W-RF Reflection Round Front...
How do i remove the lid on my modern style toilet cystern
Your lid should have two PVC or Nylon screws on the underside. Twist them off and pull off your seat. They may be excessively tight to keep the side from sliding from side-to-side, so be prepared with a pair of Channel-Locks to get in there and break them loose.
Chris
Apr 26, 2010 | Caroma 270W-RF Reflection Round Front...
I need a tank LID for the 270 Caravelle dual flush toilet. Where can I get one fast? A customer broke the lid in a thousand pieces and we need a replacement ASAP.
Toilet seats are standard and fully interchangable. You should be able to pick one up at your local hardware store. The only thing you need to know is if you have a round or elongated bowl.
Sep 18, 2009 | Caroma CARAVELLE270ADAW-EL Caravelle...
How to stop the creaking sound in a new full suspension mountain bike? (it's not the seat post or handlebars)
Well that's a hard problem to solve without having the bike here, not hearing the noise. Make sure your chain is lubricated (with bike chain oil, not WD40), because this is the foremost cause of weird bike noises in my experience. The other thing, is it a Target/Wal-Mart/CostCo/Etc bike? these bikes have REALLY inferior parts and they will indeed squeak and squeal.
Regards,
matt
Sep 14, 2009 | Cycling
Creaking noise in front end 1997 explorer
Sounds like it is your CV axles.  Turn the wheel one direction, right or left, and check just behind the wheels to see if your CV boot is cracked or ripped (the boot is a black, rubber accordion looking thing).  If it is cracked or ripped, I would say that is definitely the problem.
May 17, 2009 | 1997 Ford Explorer AWD
LOUD CREAKING NOISE COMING FROM FRONT END
grease ball joints that should fix it
Mar 21, 2009 | 2002 Chrysler Sebring
Home Logo
103 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
