Question about Midland WR120 Weather Radio
Beeps once every 10 minutes and all three light alerts are always flashing
Green light flashing on first alert smoke detector
Remove the covers and give good clean with coton and meths sensors and covers and resit the alarm good luck.
Feb 06, 2017 | Home
How do I make my Frigidaire Affinity dryer stop beeping and run?
Have you checked the lint has been cleaned off filter and water reservoir emptied.?
Dec 09, 2014 | Frigidaire Dryers
How do I set my samsung S111phone to repeat the notification of a text until I answer it?
Kindly follow the steps listed below to do so:
  1. Go to Apps through Home screen.
  2. Tap Messaging.
  3. Tap the Menu key.
  4. On pop up menu select Settings.
  5. Scroll to Notification settings section then tap Message alert repetition.
  6. Here you can see three options available on pop up menu. They are:
    • Once: Choose this option if you want your phone ring the tone just once when receiving an incoming messages.
    • Every 2 minutes: Choose this option if you want your phone ring the tone every 2 minutes until you open the message.
    • every 10 minutes: Choose this option if you want your phone ring the tone every 10 minutes until you open the message.
  7. Tap the required message alert repetition option you wish to use. When the dot indicator next to the option shows green means the option is selected.
  8. Tap Home button to return to the standby mode.
By adjusting message alert repetition just once or more than once, now your phone will notify you when receiving new message and repeating the tone according to the settings you've just done. So, what's the option you use on your phone?
Sep 24, 2014 | Samsung Cell Phones
Trac light came on on a left turn about 10 mph it flash and it beep and lock my front left wheel
Senor issues. Car thinks it is slipping. Pull the fuse for the TCS and see if that clears code and make your car derivable. If not, then try disconnecting the battery for 10-20 minutes. Otherwise, take it the dealer.
Mar 21, 2014 | 2005 Toyota Sienna
First alert 9120b
Hi hislop_amand,
I know this is coming to you late yet I just seen your post and hope the following can still help you or others.
Kind Regards,
SD
FIRST ALERT Model: 9120 9120B
Normal Operation (AC Power)
Green LED ON; flashing Red LED once/ minute
No Audible Alarm
Normal Operation (DC Power - 9120B only)
Green LED OFF; Red LED flashes once/minute
No Audible Alarm
Mar 23, 2013 | First Alert SC9120B Smoke / CO Detector...
Hello I saw the break alert light lit on my
Usually when th fluid level low light comes on, it is because the fluid is ging to the front calipers to fill the pistons that push the brake pads against the rotors. This is because the pads are worn down and probably need replacing.
As for the 3 beeps, it is not related to the brakes.
if it is 5 beeps, it is the air bag or pretensioner.
When the ignition is cycled (turned off and then on), the air bag indicator will remain lit for six seconds and then go out. If an SRS fault exists, the air bag indicator will then flash the two-digit LFC. The air bag indicator will flash the LFC five times, then it will remain illuminated for the rest of the key cycle. The RCM will also communicate the current and historical DTCs through the data link connector (DLC), using the scan tool. If the air bag indicator does not function, and the system detects a fault condition, the RCM will signal the GEM to activate an audible chime. The chime is a series of five sets of five tone bursts. If the chime is heard, the SRS and the air bag indicator require repair.
Mar 02, 2010 | 2002 Ford Ranger Regular Cab
My first alert smoke detector went off at midnight last night. It is doing the three beeps, pausing and then another three beeps. This happened for about 3 minutes, stopped and then started again...
Change brand new battery,every three months.Take some rubbing achahol clean the test button metal contact inside the detector.Well works correctly after these steps.
Dec 15, 2009 | First Alert SA302 Dual System Smoke...
My four way flashes are staying on for about a minute after i lock it and when i open my doors on car. the immobiliser light is flashing none stop.
TAMPER ALERT:
The VTSS tamper alert will sound the horn three times upon disarming, if the alarm was activated and has since timed-out (about eighteen minutes ). This feature alerts the driver that the VTSS was activated while the vehicle was unattended.
Any more info, clarification?
Jan 15, 2009 | Peugeot 405 Cars & Trucks
Frigidaire Tumble Action Washer - lights flash, beeps, does nothing else...
If you have had a lightning storm or power surge it may have fried the electronics panel. That is what happened to mine. Once it is fixed you should put a surge suppressor on it that is rated for major appliances.
Oct 17, 2007 | Frigidaire 14 Cycle Tumble Action Washer
Midland WR120 Weather Radio Logo
54 people viewed this question
Top Midland Audio Players & Recorders Experts
John
John
Are you a Midland Audio Player and Recorder Expert? Answer questions, earn points and help others
