Need replacement wrist strap for this model watch. KC 1697
SOURCE: Kenneth Cole Wrist Watch unable to remove link
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Hope it'll help.
Regards
Arthur
SOURCE: kenneth cole wach band
Have you tried contacting your nearest store?
You can find out their details at http://www.kennethcole.com/helpdesk/index.jsp.
SOURCE: need repacement black rubber strap for kenneth
To find an international store go to following link:
http://www.kennethcole.com/content/index.jsp?page=intlstore&h=688&w=900
Or call 1-800-KEN-COLE
SOURCE: i NEED A STRAP FOR
This is a bit of a tricky one. Their online store apparently has a section just for straps, but when I tried to find JUST the straps and not the whole watch, it didn't really work.
You can try talking to one of their customer service representatives at 1-800-536-2653 or try contacting their by e-mail at the following link:
http://www.kennethcole.com/helpdesk/index.jsp?subdisplay=contact&display=store
SOURCE: I have a Kenneth Cole
Call this certified Kenneth Cole watch repair company and speak to the representative. Not sure if they are on the West Coast.
Geneva Watch Group
1800-874-0907
