Question about Proscan Tablets & eReaders
I have proscan tablet when i go to wifi settings & put in my att wireles network key into password it will not connect to the wifi
homedesigner
  • 583 Answers
SOURCE: I have a Kindle (wifi
You have to enter the WPA share key. The router password is only to access the built in administration web facility. The WPA share key is the encryption key necessary for the Kindle to connect to your router.
Posted on Jan 02, 2011
Testimonial: "exactly what I needed to know"
  • 22 Answers
SOURCE: Samsung tablet isn't connecting to
Go to Settings, Data Connections, Mobile APN and press Menu.
Then choose, reset to defaults.
It will take a minute or so, but after that 3G should ve enabled once again.
Hope i was of any help. If so, please rate me.
Thank you,
PcSimples
Posted on Mar 20, 2011
damneddle
  • 1607 Answers
SOURCE: I have forgotten my wireless
Hi!
In order for you to remove the password, you need to reset your wireless router. You didn't mention what brand and model of your router, but anyway all routers have a "reset button" just look for it on your router. It is usually found at the back of the router and it is very small, you need a pin or anything long and thin to insert into it in order to push it for about 10 seconds.
Thanks for using fixya!
Posted on May 30, 2011
SOURCE: I have the Archos 101
I had the same problem with my third Archos 101 (I've had two replacements to the first one I bought in June 2011). I just got the third one two days ago and it wouldn't connect to my WiFi like the previous two would. I had to add the 101's MAC address to my router's setup and now I'm connecting to the Internet. Alternatively, if your cell phone supports tethering (my HTC Tilt does) you can tether your 101 to access the Internet through your phone. Mine is working well that way....for now.
Posted on Oct 16, 2011
  • 4 Answers
SOURCE: my arnova 10 G2 will not connect to wifi network do i need a micro simcard
The powerful 1GHz ARM Cortex A8 processor sits inside an extra-slim 12 mm body weighing only 540 grams meaning your ARNOVA 10 G2 is perfect to gather around on the sofa at home or slip into a carry case for when on the go".
Archos Arnova 10 G2
Posted on May 19, 2012
How to connect to internet doesnt recognize router password
Are you sure of Wifi password is correct?
if so, 1st; try restarting your ipad by holding down power/sleep button untill it show "Slide to shut down" leave it off for 10 seconds & then re-open it.enter the Wifi -password, sometimes this step works.
2nd solution ; try resetting your iPad network settings, it will not affect your ipad in any thing except it will forget all entered passwords for any wifi you have already connected before. go to General from Setting, choose resett, and inside only reset network setting, shut down ipad & try to connect to the wifi again. Hope this solution work for you. Also you may try shutting down & opening your router again after 10 seconds while off. Good Luck.
May 19, 2016 | Apple iPad Mini
Wi-Fi states authentication problem but can't reconnect and it won't give me the chance to input password
delete/forget the wifi connection in the tablet. re do the wifi set up with the proper WEP/WPA password from the router.
Apr 18, 2015 | Proscan 7-Inch Android Internet Tablet,...
A WiFi connection potensWL has popped up on my wifi settings. I do not know what this is but want to delete it. How do i do it? I have a Samsung Galaxy tab 2.
Hi
To connect to a WiFi system, you may need 3 pieces of information:
A username
A password
An encryption key
Once you have successfully linked to a WiFi access point then your tablet will remember the settings until told to forget them. To do this, tap on the connection in >Settings >Wireless and networks and ou will be given 3 options, Connect, Forget, Cancel. You need "Forget".
A lot of the time you may only need the encryption key, and if the tablet detects a WiFi access point then if you tap on that in wireless settings then it will either connect automatically or ask you for some sort of code - the encryption key. If this is not entered correctly then it will return an authentication problem/error. In order to connect you have to have this code.
It is worth remembering that your tablet will always notify you (via Wireless and Network settings) of all wireless networks that are within ita range.
Cheers
Feb 28, 2015 | Samsung Galaxy Tab on 3 Mobile Tablet PC
How do I connect through wi fi
Hi
Most tablets and phones working with Android will detect any WiFi access points within range.
Go to settings, Wireless & Networks, WiFi settings and the machine will show the networks within range at the top of the list.Tap on the network you wish to join and the machine will try to join the network, and if it is one you have joined before it will automatically connect. On the other hand if it is a new network to the phone/tablet, then unless it is totally open (and therefore insecure) you will need to put in the password to join the network.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Jan 22, 2015 | Tablets & eReaders
I wifi in my house for multable devices,the Tablet is one of them.well when I powered the tablet on it ask me for password or pin the only problem with that is I never set on up and I have no book for
Probably your WiFi home network is password-protected. You are asked to enter the network password , not the tablet's password. If you are asked about a pin, it means that the tablet is trying to connect to WiFi in WPS (WiFi Protected Setup) mode. You may find the network password in the set up guide of the wireless modem/router. The pin may be on a sticker affixed to the router. You enter the password or the pin, not both.
Dec 07, 2014 | Tablets & eReaders
How do I reset my wifi password on my Proscan PLT10666? I put the wrong password in (OK, three times) and now it will not go back to the input screen.
Hi. Bonnie, in your wifi settings there should be saved wifi connections, go there and either access the password and change it or delete the connection completely and then start again!
Oct 26, 2014 | Tablets & eReaders
How do i get my wifi internet back
It sounds as if you simply need to reconnect to your wifi network. If you have already connected to it, but still have no access, then disconnect from your network, remove the network from your settings (Forget The Network) and then try reconnecting to it.
Aug 27, 2014 | Irulu 7" 4gb Mid Google Android 2.3...
Why won't my tablet connect to my wifi ....
Once you identify your wireless network (SSID) you must put in a "password" or network key.
Jun 19, 2014 | Mach Speed Trio Stealth G2 Tablet -...
My proscan tablet plt 8031 was picking up my wifi and now it isn't
Go to the wi fi screen.
Access the network.
Use the forget and then sign in again with your password and connect.
Feb 22, 2014 | Proscan Recertified - PLT7035 4GB NAND...
Will not connect to wifi
  • Touch the Apps Menu button on the Home screen.
  • Open the Settings app.
  • Choose Wireless & Networks.
  • Choose Wi-Fi Settings.
  • Ensure that Wi-Fi is on.
    When you see a green check mark next to the Wi-Fi option, Wi-Fi is on.
  • Choose a wireless network from the list.
    Available Wi-Fi networks appear at the bottom of the screen. When no wireless networks are listed, you're sort of out of luck regarding wireless access from your current location.
    Optionally, type the network password.
    Touch the Password text box to see the onscreen keyboard.
    Touch the Show Password check box so that you can see what you're typing; some of those network passwords can be long.
    Touch the Connect button.
    You should be immediately connected to the network. If not, try the password again.
  • May 12, 2013 | Samsung Galaxy Tab Tablet PC
    Tablets & eReaders Logo
    Top Proscan Tablets & eReaders Experts
    tosin_christ
    David Payne
    David Payne
    EE Eddie
    Are you a Proscan Tablet and eReader Expert? Answer questions, earn points and help others
