Question about JVC DR-MV150B DVD Recorder/VCR
Vcr tape got stuck
WHEN PUSH IN VCR cassette iNSIDE, the cassette tape bend inside and brake
  • 473 Answers
SOURCE: My VCR is egecting the tape with the casstte adapter.
The cassette adapter uses 1 AA battery. When you place your VHSC tape into the adapter and close the cover, you will hear the motor running and the red piece on the adapter will move inside. Check the placement of the battery and make sure the clear shrink wrap has been removed from the battery
Posted on Sep 05, 2005
Kimi
  • 277 Answers
SOURCE: Doesn't repond to buttons and stuck on rewind
... The takeup reel is turning properly but one of the reel rotation sensors or its electronics is defective. As a test, check to see if the tape counter is changing at any time during the loading and abort process. Non-real time tape counters usually get their pulses from this same sensor. Real time counters operate off of the A/C head control pulses and therefore would not be affected by a defective reel sensor). Some older VCRs used a belt driven counter - the belt may have broken or fallen off. Most newer VCRs use an optical sensor which may simply be dirty. See the section on: "Reel rotation sensors". 2. The roller guides are getting hung up and not fully loading the tape either as a result of an obstruction or dried up grease, or a slipping tape loading belt (often accompanied by an spine tingling squeal). Parts may have broken or fallen off of the roller guide assemblies preventing them from fully engaging the 'V-stoppers'. A similar fault may prevent the capstan from fully engaging against the tape d pinch roller. 3. The mode switch sensor is dirty or defective and confusing the poor microcomputer as to the position of the loading mechanism. In this case, the loading process may stop half way, pause, and then unload as in (1) or (2), above. Or, it may do almost anything. See the section on: "Erratic behavior in various modes". 4. Some other condition such as the end-of-tape sensor thinking that you are at the end of the tape is aborting the tape loading process. This might be indicated by a sudden reversal and shutdown rather than a pause (usually accompanied by the sound of a motor whirring) at some point attempting to complete part of the cycle. For problems with record in particular, the record protect tab switch may be dirty or worn resulting in random aborts. 5. Electronic problems like bad grounds or other bad connections are alos possible. Since with some models, (a number of JVC manufactured VCRs, for example) ground integrity is via screws through the mainboard, should these loosen, erratic behavior may result. Tighten the screws. 6. A defective microcontroller or other logic could also be at fault but this is less likely than any of the preceding.
Posted on Nov 29, 2005
  • 130 Answers
SOURCE: Tape is stuck in VCR- Fast rewind and forward
It may need to be cleaned. Mechanical problems are one of the big problems with VCRs they use alot of mechanical moving parts and play for so long they fail. Plastic parts dont help much either. The pinch roller takes up the slack and is usualy the part that fails first because it constantly runs along the tape and builds a coating on the rubber so it doesnt grip the tape and pull it back into the cassette. If its not pulling the tape back in then it hangs up inside and you cant get the tape out. Fastforward uses the reels to pull the tape not so much the roller. Try and stop 2 times then fast forward then eject the tape. Try and eject the tape while its fastforwarding so it doesnt do anything else. Sometimes machines will unload after its been in fastforwad a while then it will eject. You will hear a change in the sound when it unloads, you can hear the mechanical arms move the tape in and out of the cassette. Thats when you eject it. You cant really clean it till you get the tape out. YOu can clean the pinch roller with fingernail polish or paint remover. It is a wheel inside it looks like a black tire. It pinches the tape against the capstan arm this is why it developes a film or a shine on the rubber making it slip.
Posted on Apr 04, 2006
  • 579 Answers
SOURCE: vcr does not respond to tv/vcr button on remote
You will not know from looking at the VCR if it is in VCR mode or TV mode. This is more likely a TV issue of whether the TV is monitoring the VCR or not. Make sure you have the TV selected so that it is monitoring the VCR.
That VCR/TV button has caused more confusion for the average person than anything else.
Hope Ya Fix It!
Posted on Jan 25, 2008
MNfisherman
  • 11896 Answers
SOURCE: Will not release the cassette when ejected and breaks the tape.
there is a spring attached to the tape release gear that will eventuall wear out through time, also, sometimes the rubber belts wear out and throws the timing off.
That would be the first two things to check. Make sure spring is not stretched. Try testing with cover off and watch to see if the part holding the back of the tape releases.
Posted on Mar 11, 2009
I have a vhs video cassette stuck inside my vhs. Is their any way I can get it out without breaking the vcr. It is an older vcr, but I would like to get my tape out.
You might be able to unbolt the two halves of the VCR to remove the tape, but it depends on the VCR type and how it's stuck. You might end up having to get it serviced, or just getting a new VCR, as I can almost guarantee the tape is probably damaged beyond recovery, unfortunately.
Mar 16, 2011 | Video Game Consoles & Games
Toshiba VCR
Check this link it has some solutions that you can try in removing the tape inside the VCR http://www.fixer.com/no-eject.html
Hope that helps...........
Sep 12, 2008 | Televison & Video
Jvc video recorder. cassette will not eject
make a hard reset and try to eject
Jul 08, 2008 | Cameras
The vhs cassettes keep being ejected when put in the vhs player
Well the vcr might be broken for the part that allows the tape to sit in there or something is stuck inside of the vcr so it will need to be fixed.
Jun 17, 2010 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
VCR tape stuck in VCR
One way is to take off the cover of the unit so that you can see where the tape is hung up and help push the tape out. (One of two problems are usually involved: the cassette cover isn't closing down evenly (a high corner blocking the travel path) or a loop of the tape blocking the cover closing.)
On my VCR unit it was ~4 screws on the back that held the cover in place. (That was VCR only. There might be a few more screws in the larger unit.)
I hope this helps.
Jun 06, 2010 | Samsung DVD-V3500 DVD Player/VCR
Sony slv-960 VCR cassette stuck inside
As your "free service" is not free I solved the problem by throwing the item into the trash.
Jun 25, 2009 | Sony SLV-675HF VCR
Tapes won't go down, and then eject.
Have you tried to force eject the cassette. May be the ribon of the tape has come out. Try using another cassette.
Mar 24, 2009 | Panasonic PV-V4522 VHS VCR
Vcr tape stuck in unit
Marvin,
I am not registered here as an expert, so there should not be any charges. I do not have the option of chatting I am guessing only the registered experts have that. Here goes: 1. Take a phillips screw driver and remove all the screws that are holding the case on, there will be some big ones on the sides and a few maybe smaller ones on the back. 2. Lift the the case off 3. You should see the tape on the inside the vcr 4. You may or may not have to remove some of the metalic shielding which should be only anywhere from 4-6 screws if you have a piece of metal directly over the vcr tape some have them some do not. 5 Gently pull the magnetic tape up from around the feeder posts and the drum. 6. Try and work the vcr tape up and out, If you are having extreme difficulties with this try plugging the vcr back up and pushing the eject button while still holding the magnetic tape. The tape should eject now and you and carefully pull it out. 7. When you get the tape out, use your thumb to push up and turn one side of the white reals on the tape to slowly wind the magnetic tape back inside the tape. 8. Unplug the vcr again and replace everything that you had to remove and replace the cover.
I hope this helps and let me know if you need further assistance. And since I am not a registered expert here there should be no charge for this help unless you chatted or got help from one of the registered experts.
Jul 05, 2008 | Samsung DVD-V5500 DVD Player/VCR
VCR kicks out cassettes
Sounds as if something got bent in the loading mechanism when you freed the stuck tape. Careful examination of the loading operation with the cover off may reveal the problem, but you may require a service shop, as there are hazardous voltages present inside, even when switched off.
Jul 13, 2007 | Toshiba MW24F52 24" TV/VCR/DVD Combo
Cassette stuck in video
I am a sanyo VCR technician and i will share to you what i had encountered. the problem of your VCR is in the mechanism "slide front" unable to push out the ejector portion of the tape. If you can locate this part just push it so that the tape will eject.
Aug 28, 2006 | Philips VR630 VHS VCR
JVC DR-MV150B DVD Recorder/VCR Logo
50 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
