Question about Delta "RP37034 Quick Connect Spout Hose N/A, Part"
Trying to install a delta quick connect rp37034
    New Friend:
Did you figure this out? What's the secret? My husband was happy with the ease of installation until we turned the faucet on and water started shooting from this part RP37034. Does anyone have an answer why this happens? Is the part faulty?
Posted on Feb 01, 2015
Need help disconnecting a hose assembly on Delta faucet. This is the new white sort or rectangular type quick connect hose assembly.
There is a plastic horseshoe shaped retainer clip that must be pulled back from the housing to remove the hose. It can be a little tricky so bring a very small flat screwdriver with you to help pry the clip open.
Aug 03, 2016 | Delta Plumbing
I just installed a new shower with no tub. I have water to my delta fixture but no water out the head. I used shark bite connectors and did not solder the fittings
Are your walls still open? I assume they are as you'd be unlikely to close them up without having had tested your water flow. Here is what I would do.
1.) use the orange plastic C shaped release tool to depress the white plastic ring on the shark bite fitting that you have on the delta side of the Delta-ShowerHead connection.
2.) Carefully and slowly turn water on and see if water is exiting the fixture where you expect it to.
IF yes, water is coming out of the delta fixture then you know the flow problem is somewhere between the delta fixture and your shower head.
IF no, water is not coming out the delta fixture then you need to re-access how you connected the supply lines to the delta fixture.
Oct 24, 2014 | Delta & Single Handle Shower Faucet
Remove delta quick connect hose
pull the black plastic piece down. you should hear a click. then gently pull the hose out. no matter what , BE GENTLE. Those things do seat very well but you have to be careful on removing them. Installing is easy, just a push in until it locks.
Nov 09, 2013 | Delta 2402 Classic Single Handle Kitchen...
I have water hammer when using shower only
Your Delta faucet is open and close the valve very quick. This will produce back pressure on pipes. You need an anti water hammer / back pressure suppressor to avoid this problem. You can find it in local market.
Regards
Mar 30, 2011 | Delta Faucet Delta RP17453 Pull-Down...
How do I secure the quick connect clamp to my main water line?
the quick connect should go to the sprayer hose and there should be two lines for the hot and cold.....??? does that help..
Jan 26, 2011 | Delta 2402 Classic Single Handle Kitchen...
My delta kitchen faucet model 21902 quick connect spray hose leaks where it connects to the faucet. Help
Is there a little rubber O-ring that may need replacing or is missing? You might try removing and flushing out the line and replacing it.
Dec 03, 2010 | Plumbing
How do I disconnect quick connect hose from a Delta kitchen faucet
Solution 1 from Rico did work but it required the use of pliers in each hand to apply enough pressure to hold the top part in place and to pull on the bottom part down. It took several attempts but it came apart.
Oct 02, 2010 | Delta Faucet DELTA/PEERLESS FAUCET CO....
Need lower guide for model # 4822
Hopefully - you shouldn't need a lot number. All of Delta's 4822 use the same hardware. You just need to know whether it is the right or left one (as you face the crib) and color. BUT - I wouldn't recommend re-installing a new part. To remove the old one, you had to un-screw it. Putting a new one in and using the same hole in the wood will make that screwed connection weaker and much more prone to unscrewing on its own, which can have deadly consequences. Ask Delta for a whole new drop side with the hardware already installed.
Jun 14, 2010 | Delta Luv Delta - Baby Products 5-in-1...
My bandsaw will not always start. It will make a buzzing sound like the motor is trying to spin, but the blade doesn't move. I've sometimes spinned the lower wheel by hand quickly, and then turned it on,...
The problem you describe is common to capacitor start motors. It is the starting capacitor that is bad. (There are no diodes and Radio Shack will not have the part you need.)
The starting capacitor is under the small cylinder on the side opposite the electrical connections (Not inside the motor housing.)
My bandsaw has a capacitor with leads that go into the housing. If I had to replace it I would cut the leads right next to the capacitor leaving them as long as possible and splice them using wire nuts or put spade lugs or quick connects on them depending on the new cap. The important criteria for the cap is Voltage rating (probably 200volts if you are using 110vac) and Capacitance.
Graingers or McMaster-Carr would be a source.
Good Luck
May 20, 2010 | Delta Woodworking Delta Rockwell 14 Inch...
Delta spout diverter broken cannot find direct replacement
I have a Linksys router WRT54G and i was used it on my verizon network, now i want to re-install it to another computer that i have with comcast network
The router was works well with the cable old attached, either the new one, but when I go to wireless it doesn't works
I get a strong signal but unable to get on the internet with WEP security.
With security disabled the wireless works fine. But will not connect to the
internet with WEP security on. I tried to use the CD install disk that comes
with the router but ir does not help. So i want to know what i might suppose to do?
Any help would be apreciated.
Mar 18, 2010 | Delta Home
Delta "RP37034 Quick Connect Spout Hose N/A, Part" Logo
257 people viewed this question
Top Delta Home Experts
Mike
john h
Tim Whalen
Are you a Delta Home Expert? Answer questions, earn points and help others
