Question about JVC TH-C50 System
Jvc surround system blows fuse
Blown fuse
3 Suggested Answers
SOURCE:
  • 120 Answers
SOURCE: JVC RX-318 keeps blowing fuses
could be several things, speaker wires touching,shorted output transistors, a shorted rectifier diode,bad filter caps in the power supply,those are the most common
Posted on Jan 06, 2009
mlapres
  • 757 Answers
SOURCE: JVC Surround Sound System HDCP error message
HDCP...high definition copyright protection.
This means that one of two things have happened;
1) The connection method you used for video from the player to your monitor does not support the decoding of media that is copyright protected such as the Blu-ray format, or;
2) The media you are using is not a valid original recording.
As of yet, the only video connection available that supports the HDCP decoded signal is HDMI. Component video is capable of even greater resolution than HDMI but manufacturers haven't made a way of implementing it's use for copyright protected digital signals. However not ALL Blu-ray or HD-DVD media are copyright protected, that is completely dependent on individual title in which case a component video connection will work.
Posted on Dec 15, 2011
Wont turn on
The fuse is blown 1amp 250v slow blow fuse at RadioShack . Easy fix open it up and it's right next to the power in.
Jul 28, 2012 | JVC TH-C50 System
I have a JVC TH-S3 surround sound system and would like to know if I can l watch television in surround sound as i can watch dvd's and listen to the radio in surround sound. thanks
Yes you can get simulated 5.1 surround sound from your TV as well as radio. Just switch the JVC surround mode to Pro Logic II movies or music In some systems it will display only PLII.
Just connect the TV audio out to the JVC Aux input at the back ( red and white sockets ).
Apr 26, 2011 | Audio Players & Recorders
BLOWING FUSES INSIDE UNIT. REPLACE FUSE. BLOWS INSTANTLY
hello because theres a dead short and the fuse is doing it's job could be number of thing that are wrong. 1 shorted diodes/ 2 shorted output transistor/ 3 shorted resistors /4 blown or swelled capacitors get an engineer to check it out good luck
regards
shaun
Dec 27, 2010 | JVC TH-A10 System
My JVC THM303 will not work at all. took it apart to see if there was a blown fuse and the fuse is blown but do not know where to get on. The fuse says 51MS on one end and 125V1.6A on other
You need a 1.6 amp gma fuse, be sure not to get a slow-blow fuse.
Fuses blow for a reason (a short circuit). Not very often does it only need a fuse. I suggest trying only once if it blows again right away, take it in for service.
Nov 16, 2009 | JVC TH-M303 System
Surround System setup
Hello
I did not find HVC(DId you mean JVC?).
If you meant JVC i found a link where you can download the Manuel,
http://www.retrevo.com/support/JVC-TH-M505C-Home-Theater-Systems-manual/id/318bh527/t/2/
Really hope this can help.
Oct 13, 2009 | JVC TH-M505 System
Jan 06, 2009 | JVC RX-318 Receiver
My jvc receiver has blown fuse if i replace the fuse and it blows again what else could be blowing the fuse
blowing fuse only indicates that there is power surges in your area. in order to avoid blowing your fuse again. you may need to a have a surge supressor and auto voltage regulator used for your receiver and any appliance that may need it.
Mar 24, 2008 | Audio Players & Recorders
Z-5300 blown fuse
When fuses blow theres a problem, now how it blows help you find out where the problem is, If the fuse flashes and turns black the second you turn it on or plug it in there is a massive short in the power supply, If it blows but is clear the surge was not a dead short but a overload, Either way best to run it down to the shop and get it looked at
Feb 14, 2008 | Logitech Z-5300e Surround Sound System...
Cannot TV to play throught JVC TH-C50
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=9f8aca666be88c19dfe7c8b7d3504340&q=JVC+TH-C50
Dec 24, 2007 | JVC TH-C50 System
JVC TH-C50 System Logo
41 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
