Question about Lenovo ThinkPad Edge E531 Laptop
Think pad edge e531 thermal sensing error
Thermal sensing error
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 78 Answers
Sorry but the only solution is to replace the motherboard. Check lenovo site http://support.lenovo.com/en_US/product-service/warranty-status/default.page?
as your warranty may still be in effect and the cost free. Otherwise, they are around $200 and you will also need a boot thumb drive to set up the new mobo with serial and model number.
Posted on Apr 13, 2014
I am using MP 1600 AFICIO COPIER AND ITS SHOWING ERROR OF LOAD PAPER AND THE PAPERS ARE INSIDE,WHAT COULD BE THE PROBLEM?
Sometimes, the leading edge/ front curls due to humidity.
If the pickup roller cant pull it in due to the edge not being grabbed, a detector senses that no paper has advanced.
Your copier could be sulking because it thinks you're not feeding it.
Check ream is butted fully in, edges are flat.
My pennies worth... :)
Oct 07, 2017 | The Office Equipment & Supplies
Tip
Error codes related to Canon ir 2200/2800/3300
E000 Heater temperature fault
(fails to increase)
E001 Overheating detection error
E002 Heater temperature error (fails to reach
specific level; inadequate increase)
E003 Heater temperature error (abnormal
drop; low-temperature detection)
E007 Fixing film rotation error
E010 Main motor rotation error
E014 Fixing motor rotation error
E019 Waste toner case full, sensor error
E032 DA unit communication error
E051 Horizontal registration HP
detention error
E064 Power supply voltage error
(high-voltage error)
E100 Laser BD error
E110 Polygon motor rotation error
E202 No. 1 mirror base HP detecting error
E204 ADF image leading edge signal
detection fault (absent)
E220 Lamp ON error
E225 Standard white plate/edge white
plate read error
E240 Mcon-Dcon communication error
E243 Mcon-control panel
communication error
E248 Backup (EEPROM) error
E261 Zero-cross signal error
E302 Shading error
E315 Image data processing error
E601 Image transfer error
E602 Hard disk error
E604 Image memory fault
E605 Image memory battery fault
E606 HDD error
E674 Fax board error
E677 PDL board mounting error
E710 IPC initialization error (Rcon)
E711 IPC register error (ctrl)
E712 Communication error (with ADF)
E713 Communication error (with sorter
finisher)
E716 Communication error (with pedestal)
E717 Communication error (with ASSIST)
E719 Card reader, coin vendor
communication error
E732 Reader communication error
E733 Printer communication error
E737 SDRAM error
E740 Ethernet board error
E741 PCI bus error
E742 RIP1 board error
E743 Mcon-Rcon communication error
(Rcon detection)
E744 Language error
E746 Resolution conversion board error
E803 MPWS power supply voltage error
(low voltage error)
E805 Fan rotation error
E901 Pedestal main motor rotation error
[ADF]
E420 Back-up data read error
E421 Back-up data write error
E422 IPC error
[Saddle Finisher-G1]
E501 Communication error (Punch unit)
E505 Back-up RAM
E510 Feed motor
E514 Delivery motor
E530 Width plate shift motor
E531 Stapler motor
E532 Stapler slide motor
E537 Alignment motor
E540 Tray ascent/descent motor
E577 Paddle motor
E590 Puncher motor
E592 Puncher sensor error
E593 Puncher shift motor
E5F1 Saddle folder motor
[Finisher-J1]
E500 Communication error
E514 Stack handling motor
E530 Rear alignment motor
E531 Stapler motor
E537 Front alignment motor
E577 Delivery motor
E580 Delivery tray ascent/descent motor
E585 Stack handling error
If the thermistor has a short circuit, the indication in service mode
(COPIER>DISPLAY>ANALOG) will be as follows from the start: FIXC=250°C
for the main thermistor; FIX-E=310°C for the sub thermistor.
Error codes from E000 to E003 can be in some cases reseted from service mode: PROCEDURE:
Press*
Press2
Press8
Press*
Navigate to: COPIER>FUNCTION>CLEAR>ERR.
Turn off and on.
on Aug 03, 2010 | Office Equipment & Supplies
Tip
ERROR codes Canon 6650
Canon 6650 E000 Thermistor E001 SSR E002 Thermistor, ht. Lamp thermal fuse or SSR E003 Thermistor, ht. Lamp thermal fuse or SSR E005 Fuser cleaning belt E010 Main drive problem E020 Toner motor, toner level sensor, toner hopper sensor E030 Counter E050 Duplex problem E203 Scan home problem E210 Lens home sensor E401 Document feeder paper pickup motor E402 Document feeder belt clock pulse problem E403 Document feeder main motor clock pulse problem E411 Document feeder sensor problem E500 Sorter/copier interface problem E500 An error is identified in the communication between the sorter and the copier E510 The clock signal from the motor is absent for 250ms or more E510 Sorter motor drive E513 The clock signal from the motor is absent for 250 ms or more E530 Sorter home sensor E530 The home position sensor (P17) fails to go OFF when an equivalent of 2560 pulses of the motor drive command has been generated E531 The stapler unit swing sensor (MS9) fails to go ON within 500 ms after the motor drive command has been generated. MS9 fails to go back OFF within 1000 ms after it has gone on E531 Stapler swing sensor E540 The lead cam home position sensor (P12) fails to go OFF within 2000 ms after the motor drive command has been generated. P12 fails to go back ON within 2000 ms after it has gone OFF E540 Sorter lead cam home sensor E541 Sorter lead cam home sensor E710 DC controller board E711 DC controller board E712 Document feeder problem
on Jan 19, 2010 | Office Equipment & Supplies
"Thermal sensing error" on what? Please repost with more information, thank you.
Oct 28, 2016 | Computers & Internet
Re: 2100: Detection error on HDD0 (Main HDD)
It is telling you that there is a problem with your hard drive. If you know how to get to your bios screen and have a recovery CD you should be able to restore it. That is IF the hard drive is in fact not defective. Otherwise you will need to to take it to someone who does computer repair and either let them replace the hard drive or depending on your ability do so yourself or purchase another laptop
Apr 07, 2016 | Lenovo ThinkPad Edge E531 Laptop
Tip
ERROR codes Canon 6150
Canon 6150 E000 Thermistor E001 SSR E002 Thermistor, ht. Lamp thermal fuse or SSR E003 Thermistor, ht. Lamp thermal fuse or SSR E005 Fuser cleaning belt E010 Main drive problem E020 Toner motor, toner level sensor, toner hopper sensor E030 Counter E050 Duplex problem E203 Scan home problem E210 Lens home sensor E401 Document feeder paper pickup motor E402 Document feeder belt clock pulse problem E403 Document feeder main motor clock pulse problem E411 Document feeder sensor problem E500 Sorter/copier interface problem E510 Sorter motor drive E530 Sorter home sensor E531 Stapler swing sensor E540 Sorter lead cam home sensor E541 Sorter lead cam home sensor E710 DC controller board E711 DC controller board E712 Document feeder problem
I am having a fit, my Lenova think pad edge e531 showed a message "thermal sensing error". This computer was purchased Oct.10, 2013. What do you think I should do??
Have a look at this page about replacing the fan.
Thermal fan assembly removal and installation ThinkPad Edge E531 Lenovo...
Also the service manual which says the solution is to " Replace the system board."
http://download.lenovo.com/ibmdl/pub/pc/pccbbs/mobiles_pdf/e531_hmm_en_0c10929.pdf
Replacing the board is the most expensive as it is the whole computer. It could also mean that it has a loose connection!
Feb 28, 2015 | Edge Computers & Internet
My microwave shows an error that says c-5 what is it
That would be "CS", which means low current sense.
CS Current Sense
Current Sense - Indicates control is sensing low current
(Amp) draw. Check components which would allow unit
to run but produce no heat or low heat. Current sense
circuit is active only when using pre-programmed pads.
Time Entry feature will by-pass current sense circuit.
Red wire from cavity T.C.O. must be routed through
current sense loop on H.V. Board.
Possible Causes:
1. Interlock switch (contacts 2 & 3).
2. Open thermal cut-out (magnetron).
3. Open/loose wire.
4. Power relay.
5. H.V. Board.
6. Magnetron.
7. Diode.
8. Capacitor.
9. Transformer.
10.Triac.
See the full service manual here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Oct 01, 2010 | Amana RC17 Microwave Oven
Thermal Sensing error
"Thermal sensor error" just means "Broken fan".
Jan 11, 2009 | IBM ThinkPad R40 2681
Lenovo ThinkPad Edge E531 Laptop Logo
618 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
