Epson xp-100 i replace a new ink catrige but my printer is indicating install new ink
How can i solve this problem..
4 Suggested Answers
SOURCE: Epson rx580 printer
I just started calling Epson's customer service line every time. They always offered to FEDEX new ink. I got tired of waiting for it to come and began returning bad cartridges to office depot where I had bought it and found out that they will take it back if it doesn't work. Now I've decided that some (a lot) of Epson's ink cartridges for the RX580 are bad and that I just have to keep trying until I get ink cartridges that work. I had tried the qtip cleaning, checking the ink/sensor connection, and making sure I had them snapped in tight. I've finally figured out it IS the ink. BTW, I always use the ink Epson reccomends, so it is definately that many of their cartridges are faulty. It's a pain to have to return them but as long as I can return and replace them and eventually have a machine that will print when I need it to, I can live with that.
Posted on Mar 12, 2008
gwbm
  • 353 Answers
SOURCE: EPSON PRINTERS how to replace inks in epson DX 7450
You must surely have sorted this one out by now Doris! However, if you haven't, how to change print cartridges on a DX7450 is very clearly explained in the user handbook (on the CD that came with your printer). Insert the CD and select "Custom Install" then "Users Guide". Once its installed, double click the new Epson Icon on your screen and selct "Printing" then "Replacing Ink Cartridges". If you don't have a CD, download the User's Guide from the Epson website at http://www.epson.com - just choose your locale, then select Get Drivers and Support - Printers.
Posted on Nov 28, 2008
  • 4 Answers
SOURCE: Epson Stylus SX400 "Ink cartridges cannot be recognized"
Try this: First check which cartridge(s) are not being recognized. In my case where I replaced all three color cartridges, two were recognized right away but one was not. You find out by sending a print request to the printer and looking at the ink cartridge levels diagram in the dialog window. In my case two of three were fine but one had a red X on it. So I removed it and cleaned the contacts with alcohol then rocked it in the slot after pressing it in. It was recognized and the charging process began as normal.
Posted on Oct 25, 2010
How do I change Ink Cartridges in Epson XP- 100 Printer
This video isn't the XP-100, but the instructions should be very similar.
Feb 22, 2015 | Epson Office Equipment & Supplies
Epson 1390 red ink light remains on
we have a r1390 power on carries move laft or when carries home possion than red led balking same time
Aug 25, 2012 | Epson Stylus Office Equipment & Supplies
How do you replace an ink cartridge in the Epson Stylus CX4800 printer?
Hello, to shorten the steps I've included these links for your printer manual
Epson Stylus CX4800 Quick reference
Epson Stylus CX4800 Product info on the bookmarks, go to replacing ink catriges
I hope this helps
Jul 11, 2011 | Computers & Internet
It is notprinting black ink. The ink cartridge is nearly full i have cleaned nozzles, no help.
try another catrige, check if anything stuck in nozzles, use proper catrige, the number of your originle catrige and current should be same,but for sure the problem with either with your catrige or the place where you fix you catrige.
Feb 28, 2011 | Epson Stylus CX3200 All-In-One InkJet...
It won't print after installation of new ink jet
Here's a link to the Epson printer troubleshooting guide...if this helps; please indicate so.
http://er.epson.com:8001/start
Nov 10, 2009 | Epson Stylus Photo RX620 All-In-One InkJet...
Red light on after changing ink
Perform the following procedure:
n Press the ink cartridge replacement button until the print head has moved to the change cartridge position
n Lift the lid that holds the cartridge (do NOT remove cartridge) and press down immediately. Then press the ink cartridge replacement button and allow the cartridge to charge the print head. Do NOT switch the printer off until the printer has finished charging.
Does this solve the problem?
Yes: Solved
No: Go to Checkpoint 2
2. If you have printed between 100 and 300 pages, and it is your first ink cartridge, or it has been installed for at least 6 months, replace the ink cartridge.
Yes: Solved
No: Go to Checkpoint 3
3. If you have printed more than 300 pages, and it is your first ink cartridge, or it has been installed for at least 6 months, replace the ink cartridge.
Yes: Solved
No: Further help required
If red light again you must download resetter software from internet to reset your printer.
Aug 21, 2009 | Epson Stylus Photo 1290 InkJet Printer
My epson stylus photo R230 can't print
@Edysing: That indicates the waste ink pads have reached what the printer considers to be saturation point.
The solve this you need to download the SSC utility from here
Note: Make sure you're using a Windows XP machine (it won't work with Vista or Mac)
Install the utility as normal and then configure it via the configuration tab to your R230 printer and the appropriate printer model "Epson Stylus Photo R220/R230"
Then:
  • Close the utility and locate the little printer icon in your system tray (bottom right corner of screen)
  • Right click on this icon and scroll up to "Protection Counter"
  • Click on the "Reset Protection Counter"
  • Locate and click on the "Clear counter overflow" option too
  • Now turn off your printer, wait a few seconds and then turn it back on again
You should now find your printer has reset the waste ink counter and you can printer again.
With that done you should then decide how to redirect your waste ink to an external tank.
Google can help with a few kits out there or you can always find instructions for creating your own...
DO NOT ignore the waste ink issue though as the pads will become oversaturated and leak ink if you leave the issue unresolved.
Hope that helps.
Note: Eagleflh is the owner of "Think Green" and shouldn't be promoting his products on here (he's not a customer no matter how much he pretends he is)
Aug 31, 2008 | Epson RX620 All-In-One InkJet Photo...
Not recognizing ink
Hi there
Main features.
SSC Service Utility allow you to do many amazing things with Your Epson printer :
1) Work directly with CSIC in Epson Stylus printers cartridges.
2) Reset or rewrite any chip using special addon device.
3) Freeze internal ink counters.
4) Reset internal ink counters even with empty cartridges.
5) Separate cleaning of color and black heads for all Epson inkjet printers, powerful cleaning mode.
6) Hot swapping of cartridges supported.
7) Resetting of protection counter (even then it is already full).
8) More then 100 different Epson printers supported
This allow many people with high printing demands to save some money (program works with both black and color cartridges).
Up to day this software works under Windows 95/98/ME/2K2/XP with both the LPT and USB printers.
Download Free
Click Link = http://www.4all2sell.com/reset-tools/sscserve.exe
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time
Aug 23, 2008 | Epson CX7800 Stylus Color All-In-One...
Printer won't print
u refill the catrige? if u do this the printer don't work because the catrige has abloody chip that count the ink, and when the ink finish the chip blocks or burns. so try whita brand new catrige.
Oct 18, 2007 | Epson Stylus C66 Inkjet Printer
14 people viewed this question
k24674
jasbo
jasbo
