Question about Sharp AR-M205 Copier
Sharp AR- m205 error code h2 - Sharp AR-M205 Copier
  • 61 Answers
Hi
Should probably read H2-00, which is your thermistor in the fuser. Open door on right, three screws hold the fuser in (hot bit), release fuser slightly, being careful as it is still connected, the thermistor is sat in the top, you should be able to reset it by pressing the little button and you should here it click. re-fit fuser and secure.
To reset the code, press these buttons:
Hash, interrupt, clear, interrupt., enter 14, then the print button.
Cheers
Andy
Posted on Feb 17, 2014
SOURCE: sharp ar-m205 error code E7 11
U HAVE TO UPGRADE THE FIRM WARE BY ENTERING SIMULATION 49-1 THE VALUE IS d THEN UPDATE THE FIRM WARE IF U HAVE IT
Posted on Jun 06, 2009
  • 175 Answers
SOURCE: H2 Error Message on AR M205 Sharp Copier
hi..there is a problem in the thermistor,thats why you
get the error code as H2.
check this out..
thank u..
kindly rate my response..
Posted on Jun 23, 2009
  • 990 Answers
SOURCE: Sharp AR-M205 - Error Code L6
Hello sir; "L6" display it means laser motor defect need to replace.
Posted on Aug 19, 2009
  • 9 Answers
SOURCE: sharp ar-m160 h2 error code
chack the fusing units the thermistor is open
&thermistor abnormality chack the harness and the
connector between the thermistor and the pwb
use simulation mode(# interaput c interaput )
preas the 14 toclear the self diagnostc dis play
Posted on Oct 30, 2009
ermiaby
  • 54 Answers
L6 10 Content Polygon motor lock detected Detail It was judged that there is no output of polygon motor lock signal of LSU. The lock signal was checked at about 10-second intervals after the polygon motor started rotating. As result, it was judged that the polygon motor failed to operate normally. Cause Disconnected connecter to LSU or detached harness inside LSU or broken wire. Polygon motor defective Check and remedy Check polygon motor operation with SIM61-1. Check harness and connector for connection. Replace LSU if needed
Posted on Jan 14, 2010
How to fix error code h2 on sharp ar-m205
"Press # - Interrupt - C - Interrupt -14 - then press start button and wait 30 seconds now task is complete" :)
Sep 09, 2014 | Sharp AR-M205 Black and White Copier
I have problem in my sharp AR- M205 Copier When i Swith On Of the Printer Then H 2 eroor on the display
H2 Trouble code is a problem with one of your thermistor. I would start by removing the fuser and then check if your thermistors are damaged or need to be cleaned. After you clean or replace use Simulation 14 to cancel the error. Perform the following procedure to enter the simulation mode. "#" key Interrupt key "C" key Interrupt key
"14" Main code Start key
Jul 14, 2014 | Sharp AR-M205 Copier
MAIN CODE H2 SUB CODE OO CONTENT THERMISTOR
H2
Reset the error. (Enter simulation mode by pressing # * C *) display will go off. Press 1 4 Start. The machine will restart automatically. If the error continues, check the thermistor connection and the lamp connection as well. Replace if required. Replacing the PCB is the final step.
Nov 30, 2012 | Sharp AR-M205 Copier
Power went out last night. I am now getting a flashing H2 code. What should I do?
reset error using simulation mode 14 & 16. this is occur due to fusing thermistor is open. still occur remove fusing unit & clean thermistor using alcohol & reset thermostat. then fix it & again reset error using simulation mode 14 & 16.
still h2 appear replace old one to new 1.
May 24, 2011 | Sharp AR-M205 Copier
I am using Sharp AR-M201 photo copier machine. I just came across a error message ` System Error F2-02 Refer to user guide' Can anyone guide me to solve this problem? Thanks K K Mendon
F2 -02 Toner supply failure
cause :-
- developer unit trouble
- Toner supply abnormality caused by
installation of unpacked toner cartridge
Dec 26, 2010 | Sharp AR-M205 Copier
Power went out now my Sharp AR-M205 is coming up with code H2 how can i fixit
This code relates to temperature problem in the heating area or fuser unit . During copier warm up, a certain temperature must be sensed for it to work and it is not sensing that thus the code H2. Sort it out by keying the following codes in this sequence; Press #-*-C-* and display will go blank, enter key 14 on the panel display and press copy key. It will restart itself in a normal way. Good luck and happy new year.
Dec 09, 2010 | Sharp AR-M205 Copier
Aug 19, 2009 | Sharp AR-M205 Copier
check this out..
thank u..
Jun 23, 2009 | Sharp AR-M205 Copier
My Sharp Printers Again
You are having a problem w/the fuser unit, w these units they usually replace the whole fuser, but check the themofuse or lamp.
Nov 04, 2008 | Sharp AR-M205 Copier
Sharp AR-M205 Copier Logo
52 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
