Question about Sport & Outdoor - Others
Manual needed for healthstream estm2.0
Just purchased a Healstream estm2.0 and I need a manual
Healthstream manual for GS1185T Asteroid HRC Plus. where can i get a manual for it.
Try Googling (Healthstream)(GS1185T)(manual) without parens.
Jun 05, 2017 | Exercise & Fitness
Want to download a manual for the healthstream GS1180T
Your model doesn't seem to be listed on the manufacturer's website. Contact them directly for additional support.
http://www.healthstream.com.tw/index.php?act=contact
Feb 24, 2015 | Exercise & Fitness
Where can I download a manual for a Voyager HealthStream HS9000 (serial: 04091112)Please
Here is customer support for them. Maybe they can point you in the right direction as to where to find a Manual. 1-800-521-0574
Customer Support Hours:
7:00am to 7:00pm CDT
Monday through Friday (except for holidays)
Sep 29, 2014 | Exercise & Fitness
What voltage does this model run on,24volts?
The details regarding volts current etc should be in the back of your manual
Jun 17, 2014 | Exercise & Fitness
Healthstream manual I have a GE3400T healthstream
go please to www.fitness.manualsonline.com or www. retrevo.com
and download for free.
God bless you
Oct 31, 2013 | Exercise & Fitness
I need a user guide for my bike. Brand name and model is: Healthstream GE5650B Slipstream Upright Bike
Pouri the mob that make this don,t have a manual. I understand the difficulties but can I help?
paul
0487626000
Mar 04, 2013 | Cycling
Error E6 on Healthstream treadmill
If you wish to get some details about treadmill error codes ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Mar 16, 2012 | Exercise & Fitness
Owner manual for Impuls T790 Treadmill
Hope this is what you need.http://www.healthstream.com.tw/upload/2011/01/20110128111522.pdf
Sep 15, 2011 | Nordic Track Nordictrack Exp 1000...
How can fix my healthstream LS720T treadmill? my healthstream LS720T treadmill after i turn it on it slowly run then it will go faster then stop and will indicate error message E1, what is wrong with it?
You will need to check the speed sensor for proper alignment and function. it should be located near the front roller or mounted on the motor. It should be within a credit cards width of the magnet or toothed wheel. If properly adjusted check with an ammeter to see if it is opening and closing by manually spinning the front roller or motor flywheel. If it isn't replace the sensor. If it is functioning make sure you are getting 5vdc to it across the wires. If you are not replace the upper control board(console). If you are getting the proper voltage then replace the lower control board(motor controller).
Jul 30, 2010 | Exercise & Fitness
Sport & Outdoor - Others Logo
14 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
