Question about Ematic EGS102 Genesis Prime XL 10" Touchscreen Android Tablet - Black
Sd card storage setting
How do i get it to work
I put an sd card into my tablet but my apps does not give me an option to save to sd card. What am i doing wrong. Not good at this stuff so help.
If it's an android, you can change it within an app - like camera. Go into settings and change default storage location from internal storage to sd card.
If the app can't see your sd card, make sure it's "mounted" within your device. Depending on the software version: Go to settings, general, phone/tablet management, storage, from here you should be able to see the sd card. It is either ejected or mounted. Click on the sd card, if you can see the folders content, then it is installed correctly.
Also, if it was used in another device, it may need to be formatted to be used in your tablet. You can do that from the same setting menu.
Hope this helps.
Jan 01, 2018 | Tablets & eReaders
We have a lenovo tab2 A8, with a 64 GB microSD card installed. With both netflix & amazon prime video, in options, there is no selection to download to the SD card instead of the internal storage.
First, go to Settings > Storage and check if the "Default write disk" is set to "SD card". Then go to Settings > Apps and swipe to the left until you get to "SD card". Below will be all the Apps that can be be moved to the external SD card. Click in the box on the right and another page will come up. About in the middle of the page will be "MOVE TO SD CARD" tab. Tap on it and wait until it finishes. Then go back and pick another App to move. You should be able to download apps directly to the external SD card. I haven't done that on this device and not all apps will download to the external SD card (the app maker can restrict downloads to only the internal memory. This tablet is one of the rare few Android devices that allow moving Apps to external memory.
May 25, 2017 | Amazon Tablets & eReaders
How do I get the 7 in irulu tablet to see an SD card I put in the slot so I can move apps over?
sd card is automatically recognized, however you need to
- set default storage as sd card
- also move apps and data to sd card from memory/storage setting menu individually.
Yet many apps occupy main ram and refuse to release space
Aug 29, 2016 | Tablets & eReaders
How do you move internal storage to the sd card to free up internal space
touch the "Settings" icon, go down to the "Device" area, touch the "Storage" icon : go to the bottom of the screen, and select "Transfer data to SD card", then select the items you want to move.
You should also move some apps from internal storage to the SD card : "Settings", "Device", and touch "Applications" : then touch each and every application : for most of them, the button "Move to SD card" will be active, just proceed.
Dec 18, 2015 | RCA RCT6077W2 7" 4 GB Black Wi-Fi Tablet...
How does ram vs internal storage work on tablet?
There are 2 storage in just about every smartphone or tablet. There is an internal storage, usually about 1gb. or 2gb. And there an internal SD storage, which is not same as the external micro sd card. RAM stands for Read Access Memory, it will not work as storage. Now, when you download an app it is usually save in the internal storage. If you move an app without an external micro sd card inserted, you are moving them to the internal SD storage. If possible got to setting>storage and check how is the storage divided, if you insert the external micro sd card it should display 3 separate bars. Also, another way to move apps and other things around is by using ES File Explorer. Check that out first and I hope you do resolve the problem, best of luck.
Jan 22, 2015 | Tablets & eReaders
How do I use sd card storage
Hi if you want transfer your apps on sd card go to setting- application manager- choose the app and there you will see a move to SD card button, just press it and after a while your app gona be transferred to memory card. You need do it for every app sepretlly. If you want store a photo's on it go to camera- setting and there press storage and choose memory card. With music create a folder music on it using my files and player should detect it automaticlly if not navigate there.
If you need more help let me know.
regards
Dec 14, 2014 | Samsung Galaxy Tab Tablet PC
I have an irulu tablet. I inserted a 32gb sd card. It says it is mounted and when i try to install an app from the google play store i get the message there is insuficient space available. how do i get it...
Most apps do not natively install to an SD card when downloaded from the play store. You have to have an app like AppManager, that has a function to 'move' apps from internal storage to an SD card, or use a manual option in the Android Settings section to move each app individually.. If you are that tight on space that you cannot load any new app, you may have to delete or move something from your internal storage so you can download AppManager or some similar app, and then move as many apps as you can to your SD card. If you have a lot of photos and music you can try moving that to the SD card if your player/viewer software will allow you to find it there. Best way to move bulk items (music/photos, not apps) is to connect to a PC through USB, which brings up your internal storage and the SD card as external USB storage items. Then copy from internal storage to SD card through your PC. Best to establish folders on the SD card to hold these items and then tell your app where they are.
Dec 03, 2014 | Tablets & eReaders
How to set memory card as default memory storage
Download Titanium back up. it has all you need you can move all the apps to sd card including built in apps (the ones that can not be unistalled)
Caution: your phone has to be rooted juts google how it can be done in case you are not rooted yet. and be carefull while moving apps some apps can cause damage to your phone if moved to sd card. just move the downloaded ones and some few like photo viewer, galary, music player and the like
Nov 13, 2014 | Nextbook Tablets & eReaders
I have a pandigital black novel tablet And I And unable to download any apps and all my apps have been erased. And my sd card is not working b c when I try to download a app It tells me that I dont have...
Tablets have internal storage and external SD cards (optional) storage. Apps will download to the internal storage. So under Settings > Storage make sure you have space on your internal storage.
Dec 30, 2012 | Tablets & eReaders
Ematic EGS102 Genesis Prime XL 10" Touchscreen Android Tablet - Black Logo
35 people viewed this question
Top Ematic Tablets & eReaders Experts
Ap12
Ap12
Michael Harrier
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you an Ematic Tablet and eReader Expert? Answer questions, earn points and help others
