Question about Watts Onan Portable Generator - 4000 , Model# 5500
Generator clicks but won't turn over on 1994 Dutchman motorhome
Motorhome starts but generator clicks and won't turn over
Onan generator cranks then wines no start i have a onan generator in my motorhome it stop running now when i try to start in it turns over but does not run what should i9 cheack
check oil level in the sump
if the oil level is correct check for a problem oil level sensor circuit
it is there to stop the engine when the oil level reaches critical level
Dec 12, 2016 | Electrical Supplies
My generator will turn over but wont start
Our motorhome Onan 5000 Marquis generator will turn over and try to start but fails everytime we test. We have primed, gas and oil are fine and we have new spark plugs. We also changed the gas filter on the generator. Any suggestion? Thanks, Loretta
Mar 30, 2014 | Watts Onan Portable Generator - 4000 ,...
My onan emerald 1 genset is not transfering charge to the battery
Assuming your generator has the battery charger option?
Measure the battery voltage at the battery lead in the generator, without the unit running, or the motorhome ignition on. It should read approx 12V after the unit has been sitting a while. Then start the generator, it should rise to approx 13.8 with a good battery. If it does not then the stator windings and charge rectifier in the generator should be checked. If the voltage is 13.8 approx with the generator then you problem lies further upstream, and possibly with an isolation solenoid. If you generator does not have a battery charge winding/option then charging comes from the line voltage via a motorhomes inverter, check the inverter.
Sep 08, 2012 | Onan RV QG, 2500W GenSet, LP Gas
We have an rv with a onan emerld I set generator on board. When we bought the rv (used) the generator did not work at all. We purchased the motherboard for it and it now starts and runs fine but we are not...
Is your generator wired in to an automatic switchover in the motorhome, or do you have external plug in on face of generator, or near it. The power from the generator needs to be attached one way or another to the motorhome. It may be as simple as plugging the cord from motorhome into it, depending on what set-up you have.
May 16, 2010 | 1983 Chevrolet Chevy
I have a 1984 winnebago motrhome with a 6500nh rv onan generato runs getting power on the line but none in the motorhome
Hooked in to motorhome via automatic switchover, or does the power plug of motorhome have to be plugged in to receptacle at or near generator?
Mar 15, 2010 | Watts Onan Portable Generator - 5000 ,...
Onan Generator stopped working in motorhome because the gas got too low. I blew out the front fuel filter,changed oil and filter, air filter, one spark plug and now it won't start. Is there a fuel shut...
Yes it wil not let you run your motorhome out of fuel they set it up that way so you dont strand yourself you may have a air bubble in the fuel line to the generator try blowing air generator fule line back into the tank
Jan 31, 2010 | Watts Onan Portable Generator - 4000 ,...
Genset starts and runs fine but the 30 Amp circuit breaker trips as soon as a load (AC) is applied. Started right up, ran half a day, but now when it starts the minutes I click on the ac the circuit...
What about when you have it powering the motorhome, without AC on, does it trip then? Do you have anyone you know with a multimeter and knows how to use it? How about buying a plug in voltage meter at a hardware store as a good start. You simply plug it in to a receptacle in your motorhome and it will tell you the incoming voltage and they are not very expensive. That will help diagnose generator problem.
Nov 01, 2009 | Watts Onan Portable Generator - 4000 ,...
Everything works when hooked up to shore power and when aux. generator is on. No 12VDC power when the shore power is unplugged and generator is off. Refer does not work from batteries nor anything else. Is...
First thing to check is the battery terminals. Then use a voltmeter to trace the flow.
They MAY have a "fusible link" which looks like a piece of wire but actually fuses (opens) within insulation. They are usually spliced into the regular wire.
If the battery is also charged by the engine, AND you ran the battery down for the vehicle AND they don't have an isolator, the backflow when starting the vehicle could open the fuse or fusible link.
A voltmeter is your friend to trace this out.
Oct 18, 2009 | Rv Motorhome Dual Co & Lp Gas Alarm...
Genarator runs short period of time & shut down
What type of motorhome & generator is it. Some generators will shut down (basically run out of gas) at 1/4-1/2 tank in motorhome as a feature, to allow you enough gas to get to a station, in case you forget. The fitting for fuel from tank, for generator is placed that way in tank. Is that not the case? Make sure you have at least 1/2 or more fuel in tank of motorhome just to be sure, as we found many that were supposed to be set about 1/4 tank, but were closer to half tank on motorhome.
Jul 20, 2009 | Electrical Supplies
Watts Onan Portable Generator - 4000 , Model# 5500 Logo
23 people viewed this question
Top Watts Electrical Supplies Experts
Jim London
Jim London
Ottoniel
Joseph Hoffmann
Are you a Watts Electrical Supply Expert? Answer questions, earn points and help others
