Question about Sanyo 18KS52 Air Conditioner
UNIT KEEPS GOING OFF
Unit is on for a while then goes off.
    Master:
    Sergeant:
  • 388 Answers
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset.
Air Conditioning Fort Lauderdale
Posted on Dec 02, 2015
Outside unit shuts off while inside unit keeps running, temp goes up
outside unit going out on safety overheating or thermostat satisfied
Sep 17, 2013 | Ruud Handle Air Conditioner
1999 dodge durango "check guages" keeps coming on and oil monitor goes to zero when standing still. I checked the oil yesterday when it first happened and needed to add 2 qts. Oil guage still going to...
You could have either a bad gauge or bad oil pressure sending unit. I would start with the sending unit, it is cheaper and easier to replace.
May 13, 2010 | 1999 Dodge Durango
The washing machine only keeps filling with water never stops
there is a water sensing device in your unit that is not working, it is located at the top end of a small plastic tube cumming from the washing drum the unit will have a number of wires going to the top or side of it and the plastic tube attached to the bottom, replace this unit
Apr 28, 2010 | Kenmore 24032\24036 Top Load Washer
Heater keeps going off on its on also fan not
Please provide more info. When it goes off does it come back on by itself or do you have to flip a breaker? Is the furnace gas or electric? If it is not moving enough air across your heat exchanger in a gas furnace or across electric heating elements this will trip a safety switch that will stop heating but not fan. Low air speed is most likely from inexperienced or improper duct design/ installation. Duct sizing is very important to move enough air. Don't believe me try breathing thru a straw. If your unit is a gas furnace it has a flashing code that will tell you what is wrong codes listed inside unit door. Could be lots of things. Reply with more info.
Dec 04, 2009 | Goodman Heating & Cooling
My RPM gauge keeps jumpin 7000 RPM down to 4000 and back to 0
spark plug wires probably aren't seated firmly or cdi unit is going bad!
Sep 27, 2009 | 2001 Yamaha YZF-R1
Unit does not turn on and circuit breaker is good, power is to the unit.
this happened to us. The control kit goes out. It has happened again this year after being replaced last year. Does anyone know why this keeps going out?
Jul 13, 2009 | Dometic Rooftop RV Air Conditioner
Unit keeps kicking out the breaker to outside unit
poor wiring might be the cause, call for serviceman to overall checking of the system.
Jun 08, 2009 | Heating & Cooling
I have a thermo king super 2 unit,that will not hold 36deg it just keeps going until it reaches 10deg.It has no trouble holding temp @ 10deg or less.I have replaced the temp control and it still does the...
Check your pilot solenoid. It may not be switching the 3 way valve. I have seen this many times. No codes in unit at all but temp goes passed setpoint
Apr 29, 2009 | Freezers
Our toshiba ras13 skv a heat pump keeps going to pre def mode and not heating the house
this happens when the outside temp is low, asthe outdoor unit blows cold when in heating (reverse) then the unit goes to pre def to avoid it freezing. You should hear a whoosh this is the heat being blasted to the outdoor unit to defrost it, then the heat has to build up again before the indoor unit fan runs up again and blows heat. Mine does the same every 20 mins or so (its -2 outside) brrrr
Leigh
Jun 18, 2008 | Heating & Cooling
Hi how are you going im
Try new/different cable, if still have problem? You have a loose connection in the unit on the connector.
Feb 23, 2008 | Televison & Video
Sanyo 18KS52 Air Conditioner Logo
79 people viewed this question
Top Sanyo Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Tim Whalen
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
