Question about Global Marketing Partners FLOWCHARTS AND MORE for PC
Flow chart of an integer n display positive n negative
Can negative integer be considered as a positive integer?
You mean can it be used in the same manner? Yes it can, but with different answers resulting.
Apr 20, 2016 | Office Equipment & Supplies
What are the setting for simple addition and subtraction. I also need it to print it for me
The manual mentions an add mode, turning the calculator into an adding machine.
If this is the case, you can do this test and see if it works to confirm that it is acting like an adding machine.
4+
3-
5+
Think of these as integers. The 4 is positive, the 3 is negative, the 5 is positive. When we add all these integers together, we get positive 6.
Good luck.
Let me know if you have any questions.
Paul
Sep 23, 2015 | Sharp EL-1801P Calculator
Is zero an integer
0 is an integer number in math, where integer numbers are the infinite set: 500602c6-8540-4def-b9ba-b45092b717e1.gif.
Depending on circumstances, the "natural numbers" and "natural numbers with zero" are also sometimes referred to as integers, quietly dropping the "positive" or "non-negative" property of the set.
Note, the former does *not* include 0.
Mar 22, 2014 | Office Equipment & Supplies
Locating wiring diagram for radio
Hey found this on www.the12volt.com
NISSAN VERSA AUDIO WIRE COLOR CHART
Brownish-orange(the thickest lead) - 12v Constant
Orange - Illumination
Cyan - Switched Lead/Accesory wire/Ignition wire
Black - Ground
Grey - Right Rear Negative
Teal - Right Rear Positive
Purple - Left Rear Negative
Red - Left Rear Positive
Brown/Pink - Left Front Negative
White - Left Front Positive
Green - Right Front Positive
Red/Blue - Right Front Negative
Jan 29, 2014 | Car Audio & Video
Flowchart that will display the positive or negative number
input a number and check whether the number is positive or negative?
Jun 28, 2012 | Global Marketing Partners FLOWCHARTS AND...
I am trying to divide a power of 10 by and another number to a neg power of 10
For integer powers of 10 you can use the EE shortcut. [2nd][,] displays E.
For non-integer values of the exponent (such as -5.34) you must use the key sequence [2nd][LOG] (10^x) then enter your negative non-integer exponent.
Jan 16, 2012 | Texas Instruments TI-84 Plus Silver...
Draw a flow chart that adds the first n even positive integers
It would be hard to draw a flowchart here, but it would go something like this
sum=0
input n
1: sum=sum+2
n=n-1
if n=<0 goto 2
goto 1
2: display sum
stop
Dec 12, 2011 | Office Equipment & Supplies
What is the meaning of whole numbers?
no decimals (1.5, .56) no fractions (1/2, 1 3/4)
whole numbers are just whole numbers
1, 2, 3 and on 9,10,11 .....
not
1.5, 2.5, 2.356
1 1/5, 2 2/6,3 1/5
Jun 19, 2010 | Mathsoft StudyWorks! Mathematics Deluxe...
Find two consecutive even integers whose product is 1,520
2n = 1st even integer
2n + 2 = 2nd even integer
Product = 2n(2n + 2) = 4n^2 + 4n = 4(n^2 + n)
1520 = 4(n^2 + n)
1520/4 = 4(n^2 + n)/4
380 = n^2 + n
0 = n^2 + n - 380
0 = (n + 20)(n - 19)
n = -20, +19
Answer can not be negative so n = +19
2n = 2(19) = 38
2n + 2 = 2(19) + 2 = 40
ANSWER: the integers are 38 and 40
Nov 16, 2009 | RCA HD52W59 HDTV Projection Television
C++ problem
I guess this can be done quite easily with stl sort function:
http://www.sgi.com/tech/stl/sort.html
You can also code a sorting algorithm like quicksort or bubblesort yourself. This is quite fun!
Nov 28, 2008 | Computers & Internet
Global Marketing Partners FLOWCHARTS AND MORE for PC Logo
Top Global Marketing Partners Computers & Internet Experts
deton8 von Splosion
JonSnell Electronic
JonSnell Electronic
Isabella Moore
Isabella Moore
Level 1 Expert
Are you a Global Marketing Partners Computer and Internet Expert? Answer questions, earn points and help others
