Question about Garden
Reticulation sprinklers not pop up after - Garden
Reticulation sprinklers not pop up after replacement
  • Garden Master
  • 2,478 Answers
Check your screen. Not getting water.
Posted on Feb 18, 2014
Garden sprinkler not popping up and not working
Replace that sprinkler head.
Feb 10, 2017 | Garden
How adjust distance
Turn the sprinkler on. Go to the sprinkler and at the center of the pop-up nozzle you should find a screw.If the screw is there, it can be tightened or loosened to adjust the spray distance.
Jun 21, 2014 | Orbit Irrigation 54196 400 Series...
My sprinkler head is stuck spaying in one spot and I can't figure out how to adjust the range and distance of it.
Sounds like you have a bucket impact sprinkler. These are problematic as they tend to beat themselves into non-operation from the moving parts involved and the impacts. They stop turning for a number of reasons, low water pressure, dirt and debris filling the bucket impeding rotation, plants covering the sprinkler etc. If no debris is found and others continue to work on same zone the water pressure is probably unchanged it may just be tired. I suggest replacing it using a pop-up rotor preferably a Hunter PGP-ADJ or PGJ-ADJ Rotor as rotors have only 1 moving part a gear which is sealed inside the sprinkler making them very dependable.
May 14, 2014 | Orbit Sprinkler System Super-jet 3-inch...
Is mid season checkup necessary for pop up sprinklers?
Totally, damages can happen to pop up sprinklers any time through the season due to vandalisms, lawn mower mishaps and other wear and tear.
Aug 02, 2013 | Raindrip Rain Drip Ultra Spray Series 2"...
Sprinkler will not pop up
Sounds like "Sure pop" was misleading. Try unscrewing the top or entire sprinkler then the top remove the spray nozzle to access the spring. Stretch it out longer and re-assemble the sprinkler screw it back in place with the spray notches on nozzle facing are you want covered. This should solve the problem if not, replace the pop-up.
Jul 15, 2013 | Rainbird Sure Pop 600 Series 2-1/2" Pop Up...
My rain bird 1800 head keeps leaking how to fix it
if this is an older sprinkler ,it may just be worn.usually the leak is around the white plastic surrounding the popup shaft.in this event the cap needs to be replaced.
Apr 17, 2013 | Rainbird Rain Bird 1806nsi Pop Up No Side...
Sprinkler head does not spray water
Make sure when you pull the head to ck the screen you turn the system on and blow out the line, then run a hose through the head to make sure it isn't plugged up anyway. Depending on the head and the cost of a new one will dictate cleaning or replacement.
Oct 04, 2009 | Garden
Reticulation
blocked by what?
I have to deal with iron and minials and I use the product called the works. I soak rags in the works and set it on parts that I can not reach or soak in '"works'
Apr 14, 2008 | Kenmore Elite 45986 Front Load Washer
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
