Question about Epson TM-U220 Matrix Printer
Epson m118b wont print
Already replace ribbon
The dot matrix will print out two invoice sheets before printing out ink on the third one
Replace your ribbon and make sure it's moving. Usually with an impact printer the reason this happens is because the ribbon has stopped spinning.
Aug 17, 2015 | Epson LX-300+ II Matrix Printer
A u220b epson printer will not print
check Printer Ribbon may be dyed replace with new Printer Ribbon
Jul 14, 2014 | Epson Office Equipment & Supplies
Hai my printer epson lq 300 + printing issue zigzag kindly solve this issue
Hello This condition of Dot Matrix printer only due to
1. Bad ribbon cartridge (25%) 2. faulty print head (75%)
First replace your ribbon cartridge and try printing, if not OK then you have to replace the print head.
Good Luck
Jan 08, 2011 | Epson LQ 300+ Matrix Printer
Hi I work in a restaurant and we have a Epson TM-U220A Model M188A printer. The last few days the printer has not been printing on the White receipt paper. We've tried replacing the ink and it doesn't do...
If this is the thermal head model, you will need to have the print head replaced. These were also sold under the Dell label, so finding a used replacement printer may be more economical. If it takes ribbons, you will need:
Ribbons
This printer needs a ribbon cassette to print receipts.
EPSON ribbon cassette, ERC-38 (B) (Life: 3,000,000 characters / Color: Black) EPSON ribbon cassette, ERC-38 (P) (Life: 4,000,000 characters / Color: Purple) EPSON ribbon cassette, ERC-38 (B/R) (Life: 1,500,000 characters / Color: Black)
(Life: 750,000 characters / Color: Red)
You can order replacement parts here: http://www.umd.com.au/itd/products/spareparts_epson.html
Thanks
Jan 08, 2011 | Epson TM-U220 Matrix Printer
Datacard sp55 printer won't recognize ribbon
PR-01726 Ribbon Out
Out of print ribbon.
Possible Cause 1 : The print ribbon Cartridge is empty.
Solution 1 : Reload the print cartridge. Change the cleaning sleeve and replace the cartridge in the printer. Run a cleaning card as soon as printing is completed.
Possible Cause 2 : The printer ribbon is not loaded correctly.
Soultion 2 :Load the printer ribbon correctly and then close the cover.
Possible Cause 3 : This ribbon has been completely used.
Solution 3 : Use a new roll of ribbon.
Tips for Success
* When this message appears, replace the old ribbon with the new ribbon of the same type. The printer has already prepared the card data for this ribbon type. You can change the colors of monochrome ribbon (such as from dark blue to gold).
* If you must change the type of ribbon (such as (YMCKT to KT) when this message appears, install the new ribbon, cancel any cards waiting to print, and change the ribbon type settings. Finally, return to the card creation program to send the card data to print.
* If the ribbon was repaired, the wrong take-up spool was used. Repair the ribbon again, using the correct take-up spool.
If you cannot fix the problem contact your service provider for assistance.
FTB
Nov 23, 2009 | Datacard Group SP55 Card Printer
Ribbon jam
i get the error RIBBON JAM anytime i try to print,even though i have changed the ribbon.Dan
Sep 11, 2008 | Epson DFX-9000 Matrix Printer
Print quality is very poor
I used to use an LX300 and have never had this problem. I'm not sure what unclear means so I will just do some guessing. Clarity of the print depends on 3 things, software, printhead and ribbon. These are your problem areas. Epson has an option to print NLQ or near letter quality. So that should give more clarify. I basically double prints the same letter to create a darker image. The printhead, if your printer is really old, you need to either find someone to refurbish the printhead or buy a new printhead because it could be the impact pins are bent and not giving the strongest image. Lastly the ribbon, obvsiously the more used the ribbon is the weaker the image. So either re-ink the ribbon or buy a new ribbon cartridge. Hope this helps.
Aug 05, 2008 | Epson Dot Matrix LX-300+ II Printer
Epson printing not printing
If you have already tried 3 consecutive head cleanings and nozzle check from the computer, tried reseating the inks and tried replacing the ink and it still acts like its printing but just provides a blank page chance are your printer already has hardware issue. The ink delivery system is already clogged. If your printer is still within the 1-year warranty period I suggest that you call Epson Tech support for more options otherwise, you would need to get the product repaired by an Epson certified service center. To locate a servicer in your area click on the link http://www.epson.com/cgi-bin/Store/support/SuppProductSearch.jsp?BV_UseBVCookie=yes
Jun 03, 2008 | Epson Stylus C86 InkJet Printer
Problem with my Epson Dot Matrix printer
Chances are, you didn't installed the ribbon correctly...
A. Open the printer cover
B. Use a pin to guide the ribbon between the print head and the ribbon guide, then turn the ribbon tightening knob to help feed the ribbon into place, it shouldn't be twisted or creased.
C. Slide the print head from side to side to make sure it moves smoothly
Feb 21, 2008 | Epson LX-300 Matrix Printer
Horzontally double printing & characters are not clers.
Is the ribbon tight or sticking, If ribbon can't turn, it delays entire carriage, you will notice that if you move carriage up and down by hand ribbon turns, I have seen sticky ribbon s cause problems as well as gearing that drives ribbon with wornout gears
If self test fails then all faults /i can think of on these is
  • Dry rail/dirty bearing
  • incorrectly manufactured ribbon
  • Damaged dot head
  • broken/breaking ribbon interface carriage cable
  • worn ribbon drive gears
  • worn/dirty ribbon drive rail
  • main board
Nov 17, 2007 | Epson LX-300 Matrix Printer
Epson TM-U220 Matrix Printer Logo
65 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
