How do i clear samsung clp-775nd transfer belt error
jaylex
  • 417 Answers
SOURCE: reset transfer belt samsung clp-300
Unfortunately you cannot there is a resistor on the unit that when you replace it it blows resetting the transfer counter.
Sorry
J
Posted on Jan 20, 2008
SOURCE: transfer belt errors
helped me and solved the lever and transfer belt. Actually it is the combined black toner cartridge and transfer belt. The side plate is about 3 inches long and has the two screws fixing it on. The sensor has a single screw fixing it, but in fact just looks like a black cover plate. Lever it out easilly at the screw end, not the other end which is impossible.
I just blew out the **** in the sensor, wiggled the white 3 pin connector, and since it has the look of a reflection based optical sensor, then I cleaned the belt along its edge with antistatic cleaner , ie tissue paper soaked and rotate the gear to move the belt round. There is a silver patch on the belt which passes the sensor once every revolution of the belt, and I gave this a particularly good clean as it is probably the only bit that matters.
Anyway, several black refills (hole and a bit of tape sealing it) later and the unit still works fine. Actually I always refill everything and just high pressure blow off the whole printer every so ofter.
Posted on Jul 03, 2008
  • 8 Answers
SOURCE: Samsung CLP 500 Error message 'Replace transfer roller'
You need to enter the hidden engineer menu: turn the printer off then turn on again whilst holding down the enter key on the control panel. It should say something like EDC menu on the display and you can scroll through several menus to find the one about resetting counters. Be careful not to play with other options as you can screw the printer up if you don't know what you're doing!
Posted on May 06, 2009
kikeenono
  • 4 Answers
SOURCE: Transfer belt error on CLP 315
it could be just that the imaging unit is not sitting correctly on it's tracks remove and also proceed and taking the other unit behind it and just simply replace back carefully on it's tracks
Posted on Jul 05, 2009
  • 5 Answers
SOURCE: I have a Samsung that say Transfer Belt Error
Hi
I have a utility to reset the consumables errors on this printer, but only if the component is past its lifecount. (60k for transfer belt)
Its called CLP-300_Reset_RLCv04.exe or just RLCV-04.exe (if you can find a copy)
If you need a copy, let me know and I'll find some way to get it to you.
I've used it for transfer belt reset and it works.
Posted on Jul 13, 2009
Transfer belt
Try to take out transfer belt and reinstall. You might have to tell the machine that a new transfer belt has been installed.
Sep 09, 2013 | Samsung Image Transfer Belt...
I was getting a message that the transfer belt needed to be replaced and I replaced it. But the message won't go away.
try this:
1. Press # sign; then 1934
2. Press MENU
3. Arrow to Tech Mode (not User Mode); press OK
4. DataSetup; move arrow to Clear All Memory
5. Clear All Memory; press OK
6. Choose coonutry; press OK; will erase and print out configuration report; clearing the transfer belt error.
This wipes out the counter on the Transfer Belt. Clear All Memory means all your settings are wiped out. This also reset all the counters EXCEPT the imaging unit counter.
Trust this helps. Please vote.
Dec 14, 2010 | Samsung CLP 300 Laser Printer
Invalid transfer belt error on Samaung CLP 600N
This error can arise when the door on the right-hand side of the printer, the part you open in order to replace the toner cartridges, is not correctly closed. Close the top right-hand section first and then close the door on the right-hand side firmly (slamming it if necessary) and then check that all edges look correctly aligned. That should solve the problem. Incorrect shutting of these parts has always been the cause of this error on our Samsung CLP-600N laser printers and we have several of them.
Mar 23, 2009 | Samsung CLP-600N Laser Printer
Internal error on samsung clp 300
what you need to do is get a new transfer belt, if you email the company they should give you a new one.
Feb 02, 2009 | Samsung CLP 300 Laser Printer
"Lever Unlocking Error" Message
Probably a bad connection between the transfer belt contacts and those inside the machine - clean any dirt/toner off them and make sure they aren't bent out of position and try again.
Dec 30, 2008 | Samsung CLP-500 Laser Printer
Nov 27, 2008 | Samsung CLP 300 Laser Printer
Transfer roller
Use the keys on the control panel to select the following menus: setup|maintenance|check others|transfer belt|reset then press [enter]. The LCD should read "reset now" and the printer will return to the ready prompt.
This assumes the error message you have is for the transfer belt near end and not the transfer roller itself (which is NOT part of the transfer belt, it's actually attached to the RH door as you look at the control panel).
Oct 16, 2008 | Samsung CLP-500 Laser Printer
Samsung printer error
Time to buy a new transfer belt. samsungparts.com
Apr 29, 2008 | Samsung CLP-500N Laser Printer
jasbo
jasbo
