Question about Barbeques Galore Grilling
Convert lpg to natural gas
How do i convert to work with natural gas.
  • 222 Answers
SOURCE: injectors for hobs convert from LPG to natural gas
try to call wat brand u have to buy a injector for convertion,big different the injector for LPG and the natural gas,the LPG injector is small hole & the natural is have big hole.
Posted on Dec 02, 2008
SOURCE: gas convertion
stoves have a pressure regulator as the flex line from the house connects to the stove, it's about 2 inches by 3 inches in dimension and it has a knot in the middle and one to the side of it that is to the front of it that second one you can unscrew and put that knot the other way or upside down, that's the position for natural gas, now some regulators do not have it, in that case get one that can do that,or that is for lp and natural gas. then you must close the air a little bit on all the burners the vent is located as the burner meets the valve that supplies gas to the burners. and that vent is part of the burner.
Posted on Dec 12, 2008
jumptrout51
  • 3361 Answers
SOURCE: can you convert any natural gas hobs to LPG?
They are convertible. Most come with converting parts attached to the interior of the range.
Posted on Feb 21, 2009
  • 2976 Answers
SOURCE: I want to convert to natural gas.
The only thing you can do if Weber doesn't have a natural gas manifold for their grills , is to buy one that will fit. They use propane on outside grills because of the stability of the gas. Natural gas will blow out much easier.
Posted on Feb 25, 2009
freetek
  • 5568 Answers
SOURCE: Want to convert from LP to Natural Gas
Typically, the only thing required is changing any and all jets since energy content and pressure are different. The only source for these is probably the manufacturer; check their website.
Posted on May 20, 2009
Convert from gas to lp
This is going to result in you needing a different metering orifice on the gas valve. There are LPG kits to install this, but I highly recommend a professional to eat the liability on this one because LPG is heavier than Natural gas and if it's installed improperly, a leak will cause the gas to settle on the ground creating an explosion hazard.
Nov 25, 2013 | Magic Chef CYG3004AWW Gas Dryer
Hi, I have Osaka Gas Heater model 43-540.
A natural gas heater can only burn natural and vice versa unless there are changes such as orifice and regulator. They can easily be converted to use either fuel, but you have to know what fuel supply you have, and what the appliance is set up for. Since you've already tried LPG, if it turns out the appliance is natural gas, then replace the spud (burner nozzle) before trying to operate it again. LPG cannot pass through the small nozzle hole in a natural gas appliance.
Nov 25, 2013 | Heating & Cooling
329H portable heater Can this be converted to a gas bottle fitting will it be ok what is the use age and how many watts of power to run the electronics etc
You need to convert the unit if you are changing from Natural gas to LPG. This involves getting a full conversion kit for your model and changing burner , gas pressures and electronic settings.
Power draw on high remains at 22Watts. Input is almost identical for either natural or LPG gas as you would expect but running costs depends on how much you pay for your LPG. For example in Australia we use 45kg bottles of LPG, they retails at about A$110 delivered. One of these would last about 170 hours running a 329 on high.About 2 litres of LPG per hour
Aug 26, 2010 | Heating & Cooling
I have a newhome1000df. can it run on lpg?
If it's designed to run on natural gas then usally the answer is yes but it will need to be converted the orifices for LPG are a different size than for natural gas. Trying to run it without converting is dangerous!
Jun 26, 2010 | Stoves 1000DFDL Dual Fuel (Electric and...
Can we convert Laars lite llg175N to propane from natural gas? If so how
You can convert this laars with a new burner tray, new gas valve etc..I have lots of customers who was the visa versa to you Natural to LPG and LPG to Natural..I offer an exchange service please see..
http://www.laarsman.co.uk
Miles
May 20, 2010 | Jandy Laars Lite 2 Pool Heater 125,000 Btu...
What is required to convert an LPG Rinnai 1001 to natural gas
Its complicated to convert. Get a qualified gasfitter to do it. The part number to convert LPG to Nat Gas is R1911 (at least it is here in New Zealand)
Jun 14, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Can you convert any natural gas hobs to LPG?
Feb 21, 2009 | Stoves 1200DFa Dual Fuel (Electric and...
Convert LPG gas cooker to Natural gas
how do i convert a lpg stove to a natural gas stove
Nov 28, 2008 | Kitchen Ranges
Injectors for hobs convert from LPG to natural gas
Nov 21, 2008 | Cooktops
Grilling Logo
Top Barbeques Galore Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Are you a Barbeques Galore Grilling Expert? Answer questions, earn points and help others
