Question about Korg M50 61-Key Music Workstation Keyboard - M5061
I want to record from my Korg M50 to Cubase LE4 on my laptop.
I have the midi cord with the usb but the keyboard doesn't recognize it and i'm not getting any results. I'm basically starting from scratch and don't know what to do from step 1.
    Novelist:
  • 152 Answers
Hello, To record into a lap top you will need a USB mixer, your audio output from the SYNTH will go into the mixer, you use the midi USB cable from the mixer to the lap top. this will help pre amplify your synth to normal audio levels. hope this helps.
Posted on Jan 19, 2016
drifterK
  • 4924 Answers
SOURCE: I recently bought a Korg
check the firewall in both places in control panel ..and on the antivirus if it has...and try to turn it off and see if it works ..cause if you have the correct driver and the software ..and it is seen already ..
check in device manager and see if ti is ok ..if it is in yellow it needs another driver cause it is not working ..look for the device by name ..
Posted on Jan 03, 2011
  • 11 Answers
SOURCE: Where can I get the Korg m50 service manual or
http://www.korg.com/SupportResults.aspx?productid=413 just click here :)
Posted on Feb 28, 2011
  • 5603 Answers
SOURCE: Hi Iam using my
The styles on the PSR9000 are NOT available on the PA50. Any styles of the PSR9000 would only come from the audio generation and outputs of the PSR9000. The PSR9000 would have to be setup to the style independently as that cannot be controlled via MIDI from the PA50 controls.
Posted on Jun 25, 2011
  • 5603 Answers
SOURCE: My Korg CX-3 MIDI configuration tests for
If this is a flash upgrade to the unit be VERY careful as a failed upload can leave unit dead. They usually have pretty tight checks to prevent an error from killing the unit during the upload. For certain music products I have found that I had to upload an in between version first that was available before uploading the latest current version.
Posted on Jul 29, 2011
Testimonial: "Thanks, fredy2."
  • 23 Answers
SOURCE: while using korg m50 editor using usb data cable there is no sound from my lap.the sound is only from my head phone connected to my keyboard directly?
Are you connecting to the laptop and using it as a midi controller? You can record midi notes from the keyboard and send them to your laptop via USB using any midi sequencer program (reason, logic, etc). Create a midi track, select the input of that track as your keyboard, then hit record to play some midi notes. To hear what you record, you have to set the output of the midi track to whatever midi sounds or instrunents you have installed on your laptop.
If you are trying to record the actual audio sound the keyboard makes, use an audio program such as cubase, sonar, audacity, pro-tools, and either mic the keyboard, or connect one of the other audio outputs (1/4" TRS) to an audio input on your DAW, and record an audio track that way (as opposed to a midi track).
Posted on Apr 14, 2012
How to connect PSR 290 keyboard toP.C.(midi connections only)
you need to buy a sound card that has midi in and usb out, make susre u have a working recording software that will be compatible with your sound card. try cubase and yamaha midi sound card
Nov 02, 2016 | Music
Korg m50 freezes after 10minutes
Hello I have this M50 61 key korg model, I had the same issue the fix is simple remove the back cover on the unit, carefully push in all the small cables reattach them well do it to all the small connectors these cables get lose and cause this issue, good luck let me know if that helped I fixed mines that way its been working excellent since. good luck..
Jun 08, 2012 | Korg M50 61-Key Music Workstation Keyboard...
While using korg m50 editor using usb data cable there is no sound from my lap.the sound is only from my head phone connected to my keyboard directly?
Apr 13, 2012 | Korg M50 61-Key Music Workstation Keyboard...
How can I send recordings to my laptop? I have a usb connector and i want to connect my portable grand to my laptop but the laptop does not detect the piano and i don't know what to press on the piano...
Hi mjaynneb,
I could be wrong here but I have a number of keyboards and the USB connection is usually for Midi control from software like Cubase and the like. If by recording you mean recording Audio then I think you'll find that it won't be possible using the USB port.
Midi is great and I use it a lot. It enables you to arrange music using your computer. Also you can record the music you play on the Keyboard on the computer as Midi. This means that the computer can play back through your arranger what you just played. Bear in mind though that Midi is purely numbers that represent notes, velocities and note duration so is not actually audio.
My keyboards have the ability to record to SD card or a Hard Drive, however if this is not a feature of your arranger then probably your best bet for recording audio from it is by using the Audio out ports of your arranger and using a connecting lead to a good low noise sound card on your computer. As you are using a laptop you can find external usb sound cards/interfaces so that should do fine. Then you could probably use something like Audacity which is free software, to record to a wav file.
I hope this helped.
Kind Regards
mparkyn
Jul 27, 2011 | Yamaha DGX 640 Keyboard Arranger
Where can I get the Korg m50 service manual or parts manual?
Feb 26, 2011 | Korg M50 61-Key Music Workstation Keyboard...
Re: Casio WK-210. Audacity, Jet Audio and Ctrl Pnl allow me to choose a USB PnP "record from" option, however, no sound is being recorded from the Casio to the PC. What am I doing wrong. Many...
Pat, the USB output on the Casio WK-210 is only capable of sending and receiving MIDI information. It's not sending any digital or analog audio. Audacity is primarily for sound file editing.
In order to use the keyboard to record onto your computer you can connect an audio cable from the 1/8" stereo mini-jack to an input on your computer. Then you can record into Audacity.
Or you can acquire MIDI recording software (ie. Logic, Cubase) and then using the USB output on the keyboard, you can control and record multiple MIDI instruments in those programs.
Feb 23, 2011 | Casio WK-210 PACKAGE 76 Keys Electronic...
Yamaha Psr-340
I don't have Cubase myself but there must be a track setting that allows you to monitor what you are playing live. Also make sure your keyboard shows up as the midi controller on the software. Your receive channel has to match the send channel of the keyboard. Make sure that synthA or synthB shows up as the sound source (audio out). XFi Midiport is your midi in but since Cubase already sees your keyboard your problem is an audio one not a midi one. Hope this helps.
Jul 18, 2009 | Music
I am trying to install the Zoom H4 with Cubase LE4. Can't
Sounds like it's time you upgrade to a core 2 or better computer.
Jan 06, 2009 | Zoom H4 Handy Recorder
Recording on my Yamaha CP33 keyboard using USB
We're talking about audio recording. If so you must conntect your piano by using the L + R outputs with your sound card or mixer line inputs (that's how I do this). USB is ok if you want to use your piano as a master keyboard (MIDI). Another important thing is that you must have an additional application installed called sequencer ( for example Cubase Sx, Sonar...) which will let you store your digital music. I'm not talking about the proper settings of them because it could take a day or so...:)
Overall, you will have to learn a bit about the home studio, home recording techniques. There are tons of informations on web. A great thing is that you can use your CP33 as a master keyboard to control additional virtual instruments (VST) or for example play different piano samples (check Synthogy Ivory). Possibilites are endless!
Regards
Radek
May 24, 2008 | Yamaha Full-Size Keyboard
Korg M50 61-Key Music Workstation Keyboard - M5061 Logo
55 people viewed this question
Top Korg Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Korg Music Expert? Answer questions, earn points and help others
