Question about Robotoolz RT-5250-2XPK ePlane XP High Power Automatic Leveling Laser and E
How to lesvel a porter cable RT-5250-2XP
How to level on trypod
My Porter Cable will run for 30 to 45 seconds and just stops. After a few seconds it will start again. What could be the problem the batteries are fully charged.
Hello Terry Dugger,
If it is suddenly stopping it could be a bearing problem... but if it is slowing down like a tired battery...
DEPENDING VERY MUCH on what kind of battery
you have (undisclosed model ...purpose tool)...
"some" RECHARGEABLE BATTERIES develop a memory... and are reluctant to go BELOW that level.
Typically these are seldom used tools...
wiki does a pretty good description on these batteries (types).
There are folks out there that think it is CLEVER to DISCHARGE these thing... or pulse them to BREAK THE MEMORY.
Likely to case a fire or explode as to succeed...
If you are suddenly using a tool that has been stored foe a while... you MIGHT notice the battery time is getting better...
Else just buy a replacement battery...
Cordless tools do not do well if stored incorrectly.
Hope this helps.
https://en.wikipedia.org/wiki/Memory_effect
Nickelcadmium battery
Porter Cable Home
Amazon com porter cable batteries
Oct 25, 2016 | Porter Cable Tools & Hardware - Others
Where can I get a wiring diagram for a Porter Cable20volt battery
images for Porter Cable20volt battery wiring
Power Tools - Porter-Cable
www.portercable.com/20Volt
Get Linked with the Power and Performance of the 20V MAX* system of tools. Powered by a lithium ion battery platform which delivers the performance and ease ...
Shop PORTER-CABLE 20-Volt Max Lithium Ion Battery, 2 ...
www.lowes.com/pd_472386-79992-PCC680LP_0__?productId...
Lowe'sPORTER-CABLE 20-Volt Max 1.5-Amp Hours Power... ... PORTER-CABLE 20-VoltMax 4.0-Amp Hours... ... PORTER-CABLE 2-Pack 20-Volt Max 4-Amp Hours...Missing: diagram
Jan 20, 2016 | Porter Drills
I need a capacitor for a porter cable DBS1325 alternator but it is rusty and I cant read the labeling
Porter-Cable Portable Generator - Lawn and Garden Manuals
lawnandgarden.manualsonline.com > ... > Lawn and Garden Porter-Cable
Products 1 - 35 of 35 - Porter-Cable Portable Generator A02871-043-0. Porter-CableGenerator Instruction Manual. Pages: 0 Saves: 0. See Prices Buy or Upgrade ...Missing: dbs1325alternatorcapacitor
Sep 12, 2015 | Porter Cable Electrical Supplies
What type fuel does a 5250 porter cable generator take
From p.10 of the manual
"Check fuel level, fill as required. Make sure generator is turned off and has been allowed time to cool down. Use clean, fresh, regular unleaded gasoline with a minimum of 87 octane. Do not mix oil with gasoline".
(taken from bottom of this webpage
http://www.cpoworkshop.com/porter-cable-bsi525-w-5-250-watt-electric-generator/pcbnbsi525-w,default,pd.html?cgid=porter-cable-delta-discontinued )
(Is this your exact model ?)
14.April.2014
Apr 14, 2014 | Electrical Supplies
My porter cable 200 psi air compressor will not run
The curcuit breaker on the motor. Probably a little round button that's about the size of a screw head.
Jan 04, 2013 | Porter Cable Air Tools & Compressors
A porter cable 135 psi 60 gallon upright
If the motor doesn't shut off at the desired pressure then your pressure switch is either set too high or is broken/stuck. The pressure leak at 150 psi is the safety valve doing its job opening when the pressure gets to an unsafe level in the tank.
Aug 27, 2012 | Porter Cable Air Tools & Compressors
My Robotoolz : RT-7210-1 was stored improperly and now the lazer beam is dim and hard to see in bright sunlight... Could really use info on repair or info on a place that can repair it for me.
Improper storage (I've done it too), usually means that the batteries have become too hot - and
therefore weak. The first thing I'd try is changing the batteries.
The 635nm laser operates on (4) AA batteries, and the rotary uses (1) 9V battery.
The online reviews for this a horrifically bad - see:
http://www.gosale.com/4364289/porter-cable-robotoolz-rt
May 17, 2011 | Robotoolz RT-7210-1G Robolaser,...
How do you set up telescope on to trypod
I have never seen this telescope? Is this an Equatorial mount? or an Alt Az mount? You never said.
Read this page:
http://www.optcorp.com/product.aspx?pid=3050
and read my Equatorial Mount TIP on my profile page.
Dec 16, 2010 | Fujinon U.S.A. 25x150 MTM TELSCOPE...
Robotoolz RT-5250-2XPK ePlane XP High Power Automatic Leveling Laser and E Logo
63 people viewed this question
Top Robotoolz Measuring Tools & Sensors Experts
Jim Parker
Jim Parker
 Mikey
Mikey
Tom Chichester
Are you a Robotoolz Measuring Tool and Sensor Expert? Answer questions, earn points and help others
