Question about GE GFSL6KEXLS 26 French Door Refrigerator - CleanSteel
Ge french door refrigerator flashing 88
When I plug the refrigerator in, after a short while, the freezer and refrigerator displays flash 88. The condenser fan is working, however, the fan in the back of the refrigerator doesn't work. The compressor is running and the coils are getting cold (frost forms). I understand that the '88' indicates a test mode, but I am unable to find a diagnostic manual for this unit. Any help would be very appreciated!
  • 50 Answers
SOURCE: My GE GSS22SGMBBSCC side by side refrigerator does not cool the upper freezer portion
Most newer GE fridges have dc fan motors controlled by a computer board. Sometimes the board just fails and sometimes the fan can cause the board to fail.
Posted on Jul 02, 2008
rpbuice
  • 161 Answers
SOURCE: GE Profile Stainless Steel Top Freezer Refrigerator
Check the compressor.
Unplug for 15-20 min. plug it back in and listen for the compressor to start. You will have to be behind the ref to listen and make sure you hear the compressor start and not just a fan running. If you hear a clicking noise then the compressor relay is bad.
Posted on Dec 17, 2008
peyton32034
  • 410 Answers
SOURCE: Model is GSS25WGMD WW No cooling in freezer or refrigerator
look for ice or forst build up on the rear wall of freezer compartment, sounds like you may have a defrost problem. this will affect temps in freezer and refrig. the most common def problems for GE are bad defrost heaters. these are model specific and fairly easy to replace your self. i got this part number form Sears.com WR51X10055 good luck peyton
Posted on Jan 20, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Compressor & Evap. Fan both work for 12 hours then evap stops
I believe that because defrost is done by the mother control board this is why this is happening the part of the board that controls defrost is malfunctioning and the only way to resolve the problem is to replace the mother board part number WR55X10656 You can find the replacement board at these places below. Sea Breeze
http://appliancepartsse.blogspot.com/
Posted on Aug 25, 2009
Testimonial: "You were right, thanks for your help. The control board was bad. That is what I suspected, but I wanted a second opinion."
aasc
  • 1606 Answers
SOURCE: Refrigerator does not cool.
Ok , I'll help you .
Pull the refrig out from the wall , and unplug . Remove the 8 " X 10 " panel on the back of the refrig . Inside this panel , is the main control board .
Remove the blue plug with 3 larger wires going to it . Looking at the plug , you will see : wire1 , wire2 , space , wire3 . Get a short piece of insulated wire , and remove about 1/4 inch of insulation , from both ends . Insert 1 end of the wire , into the slot of wire2 , and the other end , into wire3 .
Plug the refrig back in .
After about 2 min , look inside the freezer , behind the bottom crisper , and look for a red glow . This glow , is the defrost heater .
If no glow , this is an indication of a shorted defrost heater , or bad defrost thermostat , both of which are located behind the rear freezer panel . Unplug the refrig , and reinstall the blue connector , and the 8 x 10 panel .
The pt # for the heater is WR51X10101 , and the part number for the defrost bimetal is WR50X10068 . Both should be replaced . The heater is at the bottom of the coils , held on by 2 screws , and the thermostat , is clipped on the top right of the coils , with a blue and pink wire going to it .
If you do see a red glow , reasemble as above , and remove the rear inside freezer panel . At the top of the coils , on the left , you will see 2 white wires attached to a 1 " piece , which is clipped to the coils . This piece is the # 4 thermistor ( evaporator thermistor ) . Pt # WR55X10025 . Also replace the # 5 thermistor , ( freezer thermistor ) which is at the bottom of the panel , slid into a holder , also with 2 white wires going to it . Both thermistors , sent readings of temp , by coldness resistance , to the main control board , which then decides if it needs to defrost , or cycle off due to coldness reached .
Posted on Oct 11, 2009
Display started flashing and now unit will not do anything
Sounds like the display is waiting for another command or the control board malfunctioned. Try to run a self diagnostic after unplugging it for 10 minutes, plugging it back in and use the procedure as outlined by Kelly, top-notch FixYa contributor at this link: Check out this solution to the GE Profile Stainless Bottom Freezer...
If the display still flashes and will not respond, I suspect a new control board is needed.
Mar 10, 2014 | Samsung RF265AA Bottom Freezer French Door...
Sears Trio model 795.75546400 error message: -88 * 88
what is the error code that is displayed? It is not apparent in your post...
Aug 04, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Low side pressure at 88 high side 600
Condenser fan not running, condenser plugged with dirt or grease, over charged with refrigerant, refrigerant metering device plugged or failed, air in the refrigeration system, extreme temperature around the condenser, mixed refrigerant charge.
Jan 13, 2014 | Traulsen ADT132WUT-HHS Stainless Steel...
Ge refrigerator 88 flashing
main control board defective, replace it
Nov 27, 2013 | GE GFSL6KKYLS (259 cu ft) Bottom Freezer...
The freezer stopped working (the fridge is working but not as cold as it should be), I cleaned all the vents and the freezer worked again fro a short time then I heard a noise like possibly the fan...
It does sound like a bad fan motor. With the compressor getting hot you may need to change the start relay, overload and run capacitor if it continues to run like this with a defective fan motor. What is the correct model number? Sea Breeze
The condenser fan motor for a model MZD2766GES is part number=> 61005323 Condenser Fan Motor or here=> 61005323 Condenser Fan Motor
Oct 18, 2013 | Maytag MZD2766GES Side by Side...
My samsung model RF263AEPN is flashing an 88 89 after the power went out
This is taken directly from the Samsung website:French Door: Why Is The Display Blinking 88 88 And Not Responding?Cyber
Drastic power fluctuations such as power outages and surges can cause electronic device to behave abnormally. If the refrigerator display is showing 88 88 (all eights) and is still cooling properly, unplug the refrigerator for 60 seconds and then plug it back in. If the display returns to normal after approximately 2 minutes service is not required. However, if the display does not return to normal service is required.
Sep 23, 2013 | Samsung RF263AEPN French Door Refrigerator
Samsung side by side RFG297AAWP display shows 88 88
Press and hold the energy saver button, and the lighting button at the same time until it beeps and clears, 10 seconds. When it goes back to normal panel do the same thing again which will put the fridge in a running diagnosis mode and see if any parts of the 8's are flashing, if so look on the back of the fridge at the error codes.
Nov 24, 2011 | Samsung RFG297AAWP Side by Side Bottom...
We just had a power outage and the door flashes 88 -88 with no controls responding
Had the same problem when hurricane Irene took the power out. Contacted Samsumg and they sent a repair man out that told me that this is a common problem and that it would cost $600 to repair my less than 3 year old refrigerator. He said it's the mother board, planning on trying to replace it myself.
Sep 17, 2011 | Samsung RFG297AARS (285 cu ft) Bottom...
No display on temp controls and both frig and freezers are warm. i don't here the motor running at all. this happened after we had a power flash do to weather.
your main board in the back of the unit is bad and needs replacing,if you recently replaced a burned out light bulb in the freezer and now they strobe rapidly this is another good sign its this board the new board is a G.E. # WR55X10942
Aug 22, 2011 | GE PFS22SBSSS Stainless Steel French Door...
Refrigerator & freezer compartments @ 64 & 24 degrees F. respectively.condenser coil clean, however, "clean condenser coil" appears on display even after being reset. circuit board...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 16, 2011 | Sub-Zero 650 / O Bottom Freezer...
GE GFSL6KEXLS 26 French Door Refrigerator - CleanSteel Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
