Question about GE PTC22MFM Top Freezer Refrigerator
Evap. fan frozen in ice
Ice builds up on the freezer bottom and under the coils. cleared the drain hole under the coils and water ran into the fridge itself, it seems there is no place for the water to go. ie water pan
2 Suggested Answers
  • 430 Answers
SOURCE: I have a GE PTC22
Its defrost problem. Try manual defrost by unplugging the refrigerator from main power outlet for 24 hours then reconnect it and check, if the same problem is noticed again,. If yes then its defrost board problem. The defrost board located in the back of fridge section. You can get required parts from www.repairclinic.com or from online sears part site. ------------- Thank you.
Posted on Jan 31, 2011
My freezer is making ice at the bottem
I had this problem. The cause is water generated during defrost cycle that cannot drain into pan in back of fridge due to a plugged drain pipe. Ice builds up into a dam, and the water has no where to go except to bottom of freezer housing. Eventually this builds up with ice and runs out the bottom seal. Solution requires 2 things. First is empty fridge and freezer and disassemble freezer to expose frozen over evap coil. Melt this ice with hair dryer, lots of towels and patience. Then clean up drain pipe which is accessible from rear of unit after removing metal cover. The plastic pipe has a small black cap with a hole in it that is designed to let water flow out but keep spiders and such from getting in. On my unit this cap had sticky greasy deposits in it, was a bit stiff. I cleaned it thouroughly with mineral spirits, reinstalled and all is now a okay. Hope that helps.
Sep 05, 2013 | KitchenAid KFCS22EVMS Stainless Steel ...
Fan inside fridge not blowing
is the ice on the floor of the freezer?if so the freezer drain is blocked,ice is building up and the fan blade is jammed from the ice.when the machine gets cold ice forms on the evap coil in the freezer,when it goes into defrost the heater turns on and melts the ice and the water drains down a hole under the evap coil and the water goes down into a pan where it evaporates from the heat of the compressor and condenser coil but your drain is blocked and the water is leaking onto the floor of the freezer instead of going down the drain,i use a steemer to clear blocked drains but if you don't have a steemer you can use a hair dryer to melt out the ice,on your machine you can pull out the machine from the wall,remove the back bottom panel and unplug it first,then look at the right side,you'll see a plastic drain line with a wire tie around it,that's the drain line,you might have to cut the tie and then pull the drain line down and remove it,now go to the freezer,you have to remove the door and racks and then remove the back inside wall of the freezer,melt out all the ice that you see with the hair dryer,after you melt the ice go to the back and snake a long plastic tie like the one that's on the drain line or if you have a piece of 1/4 inch plastic water line or anything you can think of to snake through the hole where the drain line came off of,i would use plastic,if you use metal be careful not to damage anything,then pour hot water into the drain in the freezer,if it drains out the back hole you're done,if not keep hitting it with heat and if you have a turkey baster or anything that will push air down the hole to clear it and when you think it's clear pour more hot water into the hole until it drains.hope this helps and good luck with your machine.
Nov 15, 2011 | LG LFD25860TT Titanium French Door...
Water is leaking into the refrigerator from the freezer it seems to be worse when the ice maker is on
if it's worse with the ice maker on i'd have to say the ice maker is leaking but normally the water is from a blocked drain in the freezer.unplug it,remove everything out of the freezer,pull off the inside back wall of the freezer,melt out all the ice with a hair dryer,next you'll see a hole under the evap coil,that's the drain,you have to free it up,i use a steemer to blow down through the drain but if you don't have a steemer keep heating up the area where the drain hole is,you can try using a turkey baster to blow through the drain,when you think the drain is clear pour hot water into the drain hole,if it goes down you're done,if it doesn't keep heating it until the water drains down the hole.also open the fridge door,in the top of the fridge in the middle of the ceiling and where it touches the back wall you'll see a mold,that's also the drain,heat that area up with the hair dryer to melt out the ice in the drain.the problem is slime builds up in the drain,when the fridge goes into defrost the heater comes on and melts the ice off of the evap coil and the water goes down the drain and into the drip pan on the bottom of the fridge,your drain is blocked and the water is leaking into the fridge,the drain has to be cleared.good luck with your machine.if i can help you with anything else let me know.
May 11, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
I have ice at the bottom of my side by side GE TFX30PRY. It seems to be a clogged drain but I'm not sure where the drain is located on this model
Remove the bottom freezer crisper , and at the bottom of the panel ( it looks like you have a drain trough cover which has to be removed ) , if its not frozen over with ice , youll see a drain hole . Use a hair dryer to defrost the drain until you see the hole . Then continue defrosting the hole until water will flow thru it . Sometimes , hot water helps to thaw the drain . When thawed , use a small hose inserted into the drain , and blow thru it , to clear out any debris in the line .
Aug 25, 2009 | Refrigerators
Ice collecting under bottom of Freezer drawer/ seal round door intact/ food staying frozen/ Ice is cleared periodically but then builds up again
Your defrost drain hole is clogged. Look for the drain hole in the bottom rear of the freezer section. Turn off the fridge. Heat the drain hole with a hair dryer and clear the ice. Pour a quarter cup of bleach into the hole.
Jul 04, 2009 | Hotpoint Freezers
Water is not draining into pan. it is going inside fridge under
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Mar 17, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Ice formation
Jan 04, 2009 | Refrigerators
Fridge on Fridge freezer not working
Ok there is a drain pan under the evap. coil under the fan that may be clogged and full of ice there is a 3/4" hole the water drains out of that needs cleared if there is a puddle of ice over it , the ice will also effect the airflow traveling down the duct to the fresh food section of the unit.
If there is no ice puddle at the bottom of the refrigerator then make sure the unit is cooling well by making sure it has been running for 10 min. or so and checking the coil in the freezer , it should have a small layer of frost on it showing its getting cold the whole way through it. Let me know how this works.
Phil
Jan 02, 2009 | Zanussi ZI921 / 8FF Bottom Freezer...
Water in my fridge
Nov 18, 2008 | Kenmore 61282 / 61284 / 61289 Top Freezer...
Ice forming on bottom of freezer section. Water leaking in from back
Nov 07, 2008 | Maytag MSD2454G Side by Side Refrigerator
GE PTC22MFM Top Freezer Refrigerator Logo
32 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
