Question about Yamaha HTR-6130 Receiver
When i turn on after a second it turn off - Yamaha HTR-6130 Receiver
How can i get a manual for 2005 jeep liberty ?
Owners manual.. Dealer with he VIN#. Mechanics manual, any parts store. It covers all the Liberty's.
Oct 27, 2015 | 2005 Jeep Liberty
Tip
How to reset AIRBAG SRS Light on 2003 - 2006 Infiniti G35 Coupe
Hi, on most vehicles, the airbag light should come on for at 6 seconds, and then go off if the system is working properly. If there is a fault or a problem in the system, the light will remain illuminated, or flash continuously. If the airbag light does not work properly, some vehicles have an audible tone that sounds indicating a problem with the airbag light system. When the light is on (or the tone is sounding), the airbag will NOT deploy, even in an accident. <br /> The flashing light on your car is telling there is a problem. <br /> <br /> <b>How to reset AIRBAG SRS Light on 2003 - 2006 Infiniti G35 Coupe </b> <br /> Ignition Key Method: <br /> <ul> <li>Turn IGNITION on (but don't start car).</li> <li>After the AIR BAG warning lamp lights for 7 seconds, turn IGNITION off within 1 second.</li> <li>Wait 4 seconds.</li> <li>Turn IGNITION on (but don't start car).</li> <li>After the AIR BAG warning lamp lights for 7 seconds, turn IGNITION off within 1 second.</li> <li>Wait 4 seconds.</li> <li>Turn IGNITION on (but don't start car).</li> <li>After the AIR BAG warning lamp lights for 7 seconds, turn IGNITION off within 1 second.</li> <li>Wait 4 seconds.</li> <li>Turn IGNITION on (but don't start car).</li> <li>Wait 3 seconds.</li> <li>Turn IGNITION off.</li> <li>Wait 2 seconds.</li> <li>START Car (the light may be blinking slower than before).</li> <li>Wait 3 seconds.</li> <li>Turn IGNITION off.</li> <li>Wait 3 seconds.</li> <li>START Car.</li></ul> <br /> <b>This is a little easier</b> To reset the light simply turn the iginition to the on position, (you dont need to start it). All the lights should stay on for thier diagnostic check. As soon as the airbag light goes off, before it starts flashing, immeditatly turn the car off. Repeat this 3 or 4 times (turning to on then off) and the light should go away
on Dec 07, 2010 | Infiniti G35 Cars & Trucks
How do I program a transponder key for the ignition in a 2009 Pontiac Vibe?
first the first digit must start with the number 1,or 4 of your 17 digit number for this to work.so fit your chip key in your ignition.
1, insert the key in your ignition turn the key to on for 10 min 30 seconds
2, within 45 seconds turn the key to off then back on for 10 min 30 seconds
3, within 45 seconds turn the key to off ,then back on for 10 min 30 seconds then back on for 10 min 30 seconds.
then after 10 min 30 seconds turn off then on .then start the engine.
Dec 17, 2014 | 2009 Pontiac Vibe
Fridg. not cooling. digital display not working, frezzer thawing.
he refrigerator/freezer defrost system can be checked by manually initiating a defrost cycle. There
are two methods of initiating the ADC Test Mode.
First Test Method:
1. Turn the thermostat off for 15 seconds.
2. Turn the thermostat on for 5 seconds.
3. Turn the thermostat off for 15 seconds.
4. Turn the thermostat on for 5 seconds.
5. Turn the thermostat off for 15 seconds.
6. Turn the thermostat on for 5 seconds.
7. Turn the thermostat off.
In 3 to 8 seconds the ADC should turn on the defrost heater (with the bimetal closed). NOTE: The test mode will terminate when the bimetal opens. If the refrigerator/freezer is already in defrost, Test Mode can be terminated by unplugging the refrigerator/freezer from the wall outlet and waiting 30 seconds before plugging it back in. The refrigerator/freezer should immediately go into cooling mode if the thermostat is closed.
If this first test procedure fails to make the ADC initiate a defrost cycle, try the following procedure to make the ADC begin the Test Mode.
Second Test Method:
1. Disconnect the refrigerator/freezer from the wall outlet for at least 30 seconds.
2. Turn the thermostat off.
3. Reconnect power to the refrigerator/freezer.
Within 3 to 8 seconds the ADC should turn on the defrost heater (with the bimetal close). If the unit fails to go into the defrost mode during this test, the problem may not be with the ADC. A defective bimetal may be the cause of the failure. The ADC will only go into a test mode if the bimetal
is closed. If the ADC senses an open bimetal it will return to the cooling mode within 3 to 8 seconds.
HELPFUL HINT: Upon entering the Test Mode, the relay mounted on the ADC board should turn off the compressor and turn on the defrost heater. Listen for the relay to click.
• If the relay clicks one time when entering the Test Mode, check for continuity in the defrost heater.
• If the relay clicks two times, check for an open bimetal.
Jun 11, 2011 | Whirlpool Refrigerators
How do i get unit to go in deforst
The refrigerator/freezer defrost system can be checked by manually initiating a defrost cycle. There
First Test Method:
Second Test Method:
Nov 26, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
1999 olds aurora when you turn the key just says clean key wait 3 minutes
the key has magnet on it that may be weakening. It will have to be reprogrammed.
  1. Insert the first valid key into the ignition switch and turn the ignition switch ON for at least 3 seconds but no longer than 15 seconds. Turn the ignition switch OFF and remove the first key.
  2. Insert the second valid key and turn the ignition switch ON within 15 seconds. After ten seconds a chime will sound and the Theft Alarm Light will begin to flash. Turn the ignition switch OFF and remove the second key.
  3. Insert a new Key into the ignition switch and turn the ignition switch ON within 60 seconds. After 10 seconds a single chime will sound. The Theft Alarm Light will stop flashing, turn on for 3 seconds; then turn off. The new key has been programmed.
Jul 07, 2009 | 1999 Oldsmobile Aurora
Nissan Installed throttle reprogram
Here is the way to do it without the nissan scan tool. Make sure to follow all steps and it it best if you use a watch with a second hand.
1. Perform "Accelerator Pedal Released Position Learning".
a. Make sure that accelerator pedal is fully released.
b. Turn ignition switch 'ON' and wait at least 2 seconds.
c. Turn ignition switch 'OFF' wait at least 10 seconds.
d. Turn ignition switch 'ON' and wait at least 2 seconds.
e. Turn ignition switch 'OFF' wait at least 10 seconds.
2. Perform "Throttle Valve Closed Position Learning" .
b. Turn ignition switch 'ON'.
Make sure that throttle valve moves during above 10 seconds by confirming the operating sound. 3. Start engine and warm it up to normal operating temperature.
4. Check that all items listed under the topic 'PREPARATION' (previously mentioned) are in good order.
5. Turn ignition switch 'OFF' and wait at least 10 seconds.
6. Confirm that accelerator pedal is fully released, turn ignition switch 'ON' and wait 3 seconds.
7. Repeat the following procedure quickly five times within 5 seconds.
a. Fully depress the accelerator pedal.
b. Fully release the accelerator pedal. 8. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 20 seconds until the MIL stops blinking and turned ON.
9. Fully release the accelerator pedal within 3 seconds after the MIL goes off.
10. Start engine and let it idle.
11. Wait 20 seconds.
12. Rev up the engine two or three times and make sure that idle speed and ignition timing are within the specifications.
13. If idle speed and ignition timing are not within the specification, the result will be incomplete. In this case, more test needs to be done.
Jun 24, 2009 | 2004 Nissan Sentra
When turn on 2 seconds off,2 seconds turn on,2 seconds turn off
May be the power supply unit Transformer and other circuit seems to be faulty, And i don't want you to check it.. without proper precautions since its electrical equipment..
Please contact service person near by It takes very less time to service it..
Hope this info helps
Jun 01, 2009 | Televison & Video
Car wont idle
idle stepper motor(IAC) controls idle speed it is located on throttle body
f33d4ad.jpg IDLE LEARN PROCEDURE
Whenever the battery cables, the electronic control
module (ECM), or the ECM fuse is disconnected or replaced,
the following idle learn procedure must be performed:
1. Turn the ignition ON for 5 seconds.
2. Turn the ignition OFF for 5 seconds.
3. Turn the ignition ON for 5 seconds.
4. Start the engine in P/N (park/neutral).
5. Allow the engine run until the engine coolant is
above 85_C (185_F).
6. Turn the air conditioning (A/C) ON for 10 seconds, if
equipped.
7. Turn the A/C OFF for 10 seconds, if equipped.
8. If the vehicle is equipped with an automatic transaxle,
apply the parking brake. While pressing the
brake pedal, place the transaxle in drive (D).
9. Turn the A/C ON for 10 seconds, if equipped.
10. Turn the A/C OFF for 10 seconds, if equipped.
11. Turn the ignition OFF. The idle learn procedure is
complete.
May 07, 2009 | 2000 Daewoo Lanos
Yamaha HTR-6130 Receiver Logo
27 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
