Question about Canon P23-DHIII Calculator
I need paper for this calculator and also ink
I need paper to fit this calculator and also ink.
How do I add ink to the Canon P20-DH
It takes paper that does not need ink.
Sep 08, 2011 | Canon BP120 DH Calculator
How to load paper in casio calculator HR-100TM
Put the roll on the arms "like a toilet paper roll on the extender", and pull it under. There is a slot, slip the paper into this slot, and press FEED until the paper reaches the ink.
Sep 05, 2011 | Casio HR-100TEPlus Calculator
WHAT INK ROLLER MODEL NUMBER FITS CANNON P23-DHV
Canon P23-DHVInk roller Part# IR40T
http://www.gorillapaper.com/ink-roller-ir40t-b-r.html
Thank you
Sep 30, 2010 | Canon P23-DHV Calculator
I replaced the roll of paper and now it will not
The Casio DR-T220 does not use regular adding machine tape, it requires a thermal tape since it is a thermal printer. There is no ink or ink ribbon in this caculator, it is heat activated and it is the special paper that make the numbers appear. Thermal tape is available at all office supply stores.
Oct 05, 2009 | Casio DR-T220 Calculator
We have a TI-5045 11 calculator. It won't print
Yes it can. Go to "Office Max" look for Porelon 11203 calculator black ink roll.
Aug 27, 2009 | Texas Instruments Office Equipment &...
Printing is very faint. How to change or add ink printer device.
This is most likely a ribbon impact system. Any office supply store should have the ribbon you need, with information on compaitability on the package.
Remove the paper roll and gently but firmly pry on the bezel surrounding the paper exit path. Examine the sides of the ribbon casing for any clips or fasteners.
May 22, 2009 | Victor 1280-5 Calculator
Canon Calculator; P28-D
Hi there, there are a couple possibilities. First, Remove the cover where the paper feeds out, if there is a ribbon or an ink roller in there it will need replacing. This you can get a staples. The other possibility is, if there is no ribbon or ink roll, it is probably a thermal printer which means is uses a special heat sensitive paper. If this started when you changed the paper, this is most likely the problem. This you can also get at staples!
Jun 19, 2007 | Canon BP120 DH Calculator
Canon P23-DHIII Calculator Logo
44 people viewed this question
old marine
old marine
