Question about Pyle Audio Players & Recorders
Receiver won't connect to tv
Receiver
My tv won't stop humming. I have only had the tv for 2 months
make sure you have it and the other electronics plugged into a surge protector strip and all cables wires & connections are fully seated (fully plugged in).The problem is in how the electrical current is being received and it is manifesting the humming sound / " GOD BLESS "
Apr 08, 2013 | Televison & Video
Bose av321 video settings won't display on tv
Make sure the video output from your Bose System is connected to the right input source of your tv.If it does not work,try using a different remote control.If it still doesn't work,then you will need the service a Bose repair technician.
Jan 28, 2013 | Bose Av3-2-1 Series Ii Media Center...
My dish 311 receiver goes on and off when connected to dish pro plus lnb
rdjennings10,
It does sound like there could be a power problem with the receiver. The Dish Pro Plus LNB won't cause any issues with that receiver. If the receiver is plugged into a power strip or surge protector, try plugging it directly into the wall. If it is already directly into the wall, try a different outlet if available.
If the problem persists, we will have to replace the equipment. You can reach me at thomas.faust@dish.com to get that taken care of.
Tommy Faust
DISH Social Media Representative
Oct 30, 2012 | DISH Network Televison & Video
Wireless headphones won't connect with tv
ENSURE THAT THE SETTING ON YOUR TV SET HAS BEEN SET. DOUBLE CHECK IF THE HEADPHONE IS COMPATIBLE WITH YOUR TV SET
Sep 12, 2012 | NexxTech High Quality 2.4ghz Wireless...
What amplifier do i need to connect 4 speakers to my vizio P50HDTV10A TV
Check the back of your set there are 2 Audio RCA Jacks, You can't do it with an amplifier alone because that won't split the channels to 4. You have to go to a surround sound receiver.
Jul 14, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
Component won't work
Check the input selection to TV. Set it to receive component video. Refer its user manual for more details.
May 26, 2012 | Sharp 36K-X2000 TV
Setting up my rx v2400 to my tv
The setup may depend on your TV and other components and how you plan to use the system. Does your TV have analog or digital audio outputs? The receiver has analog and both types of digital inputs (coaxial and optical).
Use the best cables that you can. You can get all cables at online cable stores for much less than at the electronics big box stores. I'll assume that you already have the speakers connected to the receiver.
Next you can either connect your devices (cable box, blue-ray player) the receiver's inputs. Then connect the receiver's video out to the TV. This is great if you will only listen to the devices with the home theater system. Then you can also connect the TV audio out to the receiver for the OTA TV audio. For this you probably need component video cables and audio cables. These are all cables with RCA plugs.. Then get another audio cable for the analog or digital optical output of your TV. For some TVs the only audio out is the headphone jack. In that case, you also need a 3.5 mm to RCA adapter (the simplest is 3.5 mm M to RCA F/F for connecting to an RCA audio cable). For this method, you won't have to turn off the TV speakers most of the time; the TV won't have any audio.
Alternatively, connect each device audio/video out to the TV's input and then only connect the TV's audio out to the receiver DTV audio IN. Since the receiver doesn't have HDMI, this is the best option if your devices have HDMI out. For this, use the appropriate number of HDMI cables and the analog or digital optical audio cable from the TV to the receiver. Then turn off the TV speakers and enable the external speakers in the TV menu. You can connect to any of the receiver's inputs. If you use the labels, you'll find it easier to turn on the inputs.
If you have any devices with composite video output, use the same basic steps as for the component
The documentation for the RX-V2400 is available at the Yamaha product site: http://usa.yamaha.com/en/products/audio-visual/hifi-components/stereo-receivers/rx-v2400_black__u/?mode=model . You'll need to be a registered Yamaha user (Easy-Pass) to read the manual online.
I hope this helps. Please add a comment with your devices (including the model of the TV) for more specific information.
Feb 19, 2012 | Yamaha RX-V2400 Receiver
We have a Samsung Smart TV. We cannot get the signal and have installed a Digital Satellite Receiver. We have a Magnavox VCR and a sony DVD Player. We owuld like to attache the same to our TV and watch...
Depending on your Satellite receiver's output type (i.e. HDMI or Component - Red, Green, Blue) you should connect to your tv's appropriate external inputs. Example: if you choose to connect the receiver via HDMI, then you use the SOURCE button on your tv and select the correct HDMI input you have connected your device to. If connected by Component (Red, Green, Blue) then use the SOURCE button to select the correct Component input, and so on.
Note: HDMI is the best connection type - you won't be able to access your receiver from the tv's built in tuner.
As above explanation, your VCR and DVD devices should be connected to your tv in the same manner - unless it is a combo unit (VCR & DVD in one), in which case this device can be tuned into your chosen tv channel (via the tv's tuner).
Note: if you have one of the latest SMART tv's, it should already have a built-in "Hi Definition" tuner which will allow you to watch free digital tv broadcast (DVB).
Hope this helps...
"Please rate this solution"
Aug 28, 2011 | Samsung Televison & Video
TEAC AG-V1200 receiver won't auto turn on when
No. It won't automatically turn on when power is present.
Aug 08, 2011 | Teac Audio Players & Recorders
Top Pyle Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Are you a Pyle Audio Player and Recorder Expert? Answer questions, earn points and help others
