Question about Nikon Coolpix L26 16 Megapixel Digital Camera - Red
Lens error Lens does not extend, motor grinds, gives lens error
  • 97 Answers
SOURCE: lens error/system error
I have successfully fixed the same error on a Nikon 2100 by dissasembling the camera and removing grit from the gears that drive the lens. However, if the camera has been dropped, I suspect that something has got dented or bent. It may be worth taking the camera apart to see if a gear has got dislodged.
I would warn you to be very careful not to get a shock off the flash capacitor inside the camera though. Also, it took me quite a while to put it all back together. It's not the easiest device to work on, a result of the very compact body (for its time!)
Posted on Nov 09, 2007
SOURCE: lens error
wheni go to turn on my camera it says"lens error"on the screen and wont turn on lens is "stuck"open.
Posted on Oct 19, 2008
SOURCE: Lens Error!
my cousin JUST got this error when she took her camera to the beach. (she thinks sand got into it) i brought it to my house and planned on taking it apart. (i'm pretty handy with these things) before i started anything, i tried to make the lens STAY out when it turned on.
1. i opened the bottom where the battery is.
2. i turned on the camera and quickly popped out the battery when it was at its furthest point. (the s210 has a battery latch that pops the battery out on its own. so i just pulled it back so the battery would come out)
3. from there i pulled out the lens as much as i could (pulled slightly, as it hardly moves when off)
4. from there i put the battery back in and powered it on
5. i lens stayed out after it turned on then back off (still giving me the "lens error" screen
6. i powered on 1 more time and the lens went back in. and the camera worked!
you can try this and hopefully it works. (sounds like the gears just got out of place and wouldn't let the lens come out properly)
and if it doesn't work, you always have nikon to call up! :D
hope this helps someone!
Posted on Sep 16, 2009
  • 11967 Answers
SOURCE: nikon coolpix s60 is giving lens error, pls i need
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Mar 29, 2010
  • 11967 Answers
SOURCE: Nikon l3 lens error
Posted on Jul 01, 2010
Canon Sx1IS lens error Hi My Canon Sx1 is is
sounds like the motor is cactus to me, have you checked to see if there is any drive (power) to the motor?
Sep 06, 2013 | Canon PowerShot SX1 IS Digital Camera
My PowerShote SD800IS lens will not retract and makes a grinding noise. Please help!
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Aug 15, 2011 | Canon PowerShot SD800 IS / IXUS 850 IS...
Lens error
There is a mechanical displacement. Lens has been shifted to side. That grinding sounds come because motor pushes lens to retract but something is stopping lens's way.......
So get it serviced. Don't turn it on or off, It increases pressure on motor.....
May 03, 2010 | Nikon Coolpix S210 Digital Camera
E18 error w/sound effects!
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Jul 18, 2009 | Canon PowerShot A95 Digital Camera
Canon g9 Camera was dropped. Now lens will open but not extend and motor to move lens makes a grinding noise. Is this repairable?
Yes it is the lens is exspencive but it canbe replaced. cost on the lens is about 150.00 for parts and labor. could be more or less at other digital camera repair shops.
Jun 26, 2009 | Canon PowerShot G9 Digital Camera
I need buy a motor that move the lens
Actually the motors are very tough, and unlikely to fail, especially at the voltage that they're operating. What you're more likely experiencing is a lens error.
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 06, 2009 | Canon IXUS V2 Digital Camera
When I turn my camera on, it will than read: "lens error, restart camera."
May 27, 2009 | Canon PowerShot SD1100 IS Digital Camera
Lens won't close
Apr 17, 2009 | Canon PowerShot SD1000 Digital Camera
My camera worked fine one day, then it was in my purse. When I went to use it the light was on and the screen said there was a lens error. Everytime I try to turn it on now it makes a grinding noise and...
Hope you purchased an extended warranty. I've had two Cannon's with the dreaded lens error. Probably what happened was that while it was in your purse, somehow the power button got pressed. The camera powered up, tried to extend the lens, then stripped the gears or broke whatever mechanism extends the lens. The sad part is that if it's not under warranty, it probably not worth dumping $100.00 + into fixing it. Too bad, it's a nice 8mp camera with some pretty good reviews. I feel your pain.
Feb 22, 2009 | Nikon COOLPIX S200 Digital Camera
Locked up
Try removing your memory card. I had the same problem and this worked. You might need a new card. Good luck.
Oct 01, 2008 | Gateway DC-M42 Digital Camera
Nikon Coolpix L26 16 Megapixel Digital Camera - Red Logo
115 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
