Question about Sony Xplod XM-1652Z Car Audio Amplifier
No sound when i hook speakers to amp - Sony Xplod XM-1652Z Car Audio Amplifier
Do i hook up speakers to amp or mixer
You hook them up to the last item in the chain.
If you are mixing instruments into the amp, then the speakers go to the amp.
If you are mixing amplified sound (unlikely), through a mixer, then speakers to the mixer.
Nov 22, 2016 | AMP Music
No sound out of my speakers model 5269480
on your amp under the back seat their are 2 plugs the one on the left which is the smaller of the 2 there is a Tan wire w/Orange stripe on it hook the remote wire from stereo plug which will be blue w/white stripe to that wire so it will power-up your amp...Bottom line, no amp = no sound,unless you figure what wires are the speaker wires and hook directly to your stereo plug............Its an easy fix
Oct 13, 2012 | 1994 Jeep Grand Cherokee
04 gmc yukon. Installed aftermarket radio. Installed a interface and no sound from speakers
It can be issue with Faulty radio AMP or the problem is with loose radio speaker wires.
There is a test procedure,you can do.Click the link below to follow the test procedure.
No sound from speakers on 04 gmc yukon
http://repairhelpcenter.blogspot.com/2012/10/no-sound-from-speakers-on-04-gmc-yukon.html
these will help.
Thanks.
Oct 13, 2012 | Cars & Trucks
How to hook up a gemini amplifier?
typically (unless your useing other gear besides mixer and amp) you'd come out of the L/R outs. ( Main outs ) to the Main inputs of the power amp then out to your speakers (outs of power amp). Now the amp could be in bridge mono or other factors but typically, like i said, just
Mixer Out- Amp In- Amp Out- Speakers.
Oct 22, 2011 | Gemini Sound Products GEMINI XGA 2000 2000...
When car is hooked up I get visuals, lights. etc. but no sound transmits from the stereo to speakers. I have checked all speaker connections and RCA jacks, along w/ amp and subwoofer and all are connected...
The illumination wires (orange, not yellow. Yellow is for 12 volt in) would not have an effect on sound. Either the internal amp is blown or you have a shorted speaker which is preventing the internal amp from turning on. Disconnect all speakers and hook a KNOWN GOOD one to an output. I f you get sound, the problem is in the car, if not, the problem is in the radio. If you accidentally crossed two of the speaker wires or let one touch a chassis ground, you blew the amp.
Jul 01, 2011 | Car Audio & Video
Only door speakers have sound on the cd mode
the amp requires a 12 volt power constant, and a 12 volt "on" signal. you prolly have the 12 v "on" hooked up to the car stereo's antennae remote, meaning your amp gets power when the radio is on, cuase the radio is sending a signal to the amp (thinking that it is sending a signal to the antennae to raise)
you do have one of those collapsable antennas, right?
Mar 12, 2009 | Clarion VRX745VD Car DVD Player
Speakers dropping out & engine sounds
sounds like your amp is bad
remove the amp and hook your speakers directly to the radio if the problem stops
then the amp might be messed up
if you got another radio try the amp with that radio to "double" check that it is the amp
if the problem is still there with the speakers hooked to the radio then you need to fix or get another radio
Sep 03, 2007 | Pioneer DEH-P690UB CD Player
Speaker Hook Up - Non-Technical (single) Female
bought the same amp second hand and had same problem as there are two seperate amp chips inside one for front speakers and one for the centre and rears it could be the actual amp chip that drives the front speakers has died as there is no built in speaker protection so over driving these speakers will result in the amp chip blowing . it may be something simple but it was not on mine had to buy new amp chip and solder in that sorted the problem for me !
Jun 02, 2007 | Technics SA-DX950 Receiver
Sony Xplod XM-1652Z Car Audio Amplifier Logo
21 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
