Question about Daewoo DLP3212 32 in. LCD Television
How do you open deawoo dsl-17d3
I want to open it up to see if i can solder it
Deawoo lano po113
code p 0113 refers to intake air temperature (IAT) sensor --circuit malfunction====causes --wiring open circuit / shorted to positive --wiring short to ground ---ground wire defective --IAT sensor ---ECM
Mar 25, 2017 | Cars & Trucks
How do you take the iac off a deawoo
It is bolted to the intake manifold near the throttle valve.
Jan 12, 2017 | Daewoo Lanos Cars & Trucks
Where is the fuel reset button on a nubria deawoo
Remove the passenger side front rocker trim panel. Remove the lower B--pillar trim panel. Reposition the carpet. There is the fuel cutoff inertia switch with reset button.
May 01, 2014 | 2001 Daewoo Nubira
No spark on my deawoo cielo coil fit new coil
check the main fuse box if there is power
Dec 28, 2013 | Cars & Trucks
Have daewoo tv model dsl-17d3 and need code for one for all remote control
028,081,072,091,095,099 are the codes to check. If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter."
Mar 31, 2013 | Televison & Video
I try to turn on my my Nintendo DS Lite but it wont come on, not even the light on the side of the console turns on.
There could be any number of reasons for this. You need to test a number of things.
First, remove any cartriges from the game slots and try to switch it on. Look inside the top slot and see if any pins are bent too far and possibly causing a short circuit to another pin or the metal casing. A small torch will help. If there are any overly bent pins then you can try to bend the pin back but remove the battery first (under the cover on the bottom).
If the On/Off switch feels loose and does not easily spring back then the switch could be faulty. The switch is cheap to buy from sellers on ebay but difficult to replace because it requires very good soldering skills and good vision due to the surface mount components.
The battery could be faulty. To check this you will need to remove the battery from the DSL. If you have access to a multimeter then check the voltage of the battery. If you have a second DSL then swap batteries.
There are also two surface mount fuses on the board inside the DSL which might have blown. These are also easy to buy but very difficult to replace unless you have very good soldering skills.
A special tri-wing screwdriver is required to open the DSL and it can be tricky to put back together. See Youtube for useful videos.
Note: If your DSL has suffered water (or other liquid) damage then the chances of fixing it very slim.
Feb 12, 2011 | Nintendo DS Lite
P0337 Code 2001 Deawoo Lanos
its a crank sensor no signal p0337.good luck,i hope this help pls dont forget to rate me thanks
Jun 05, 2009 | 2001 Daewoo Lanos
Lose DSL connection a lot!
Unplug you dsl and your router. Wait 20 seconds. Plug your modem back in. Wait until the DSL light turns green. Then turn your router on.
Jul 16, 2008 | 2wire 2700HG-B Router (2700HGB)
Is there anyway to do a remote reset of a dsl modem?
The answer "depends." If the DSL modem is in bridge mode, then NO. If you have opened up a WAN management port in the DSL modem, then YES. If the modem's management port is not open to WAN access, then do what I do. Remote into the site, past the DSL, then go backwards into the LAN portion of the DSL and reboot it. But..of course these answers are too easy and not what you are looking for, probably. The DSL provider can reboot the dsl modem. But there is no software or command I'm aware of that can reboot or resync a "fritzed out" modem. ZT3000 "Beta tester of "0"s and "1's"
Mar 27, 2007 | Paradyne BitStorm 4800
Daewoo DLP3212 32 in. LCD Television Logo
19 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
