Question about Garden
Hi, I am calling from New Zealand. I have a Crftsman LT2000 lawn tractor model 917.273780 serial #100103Coo1497. I need a a drive belt for the blades they seem to be hard to get down under an I would be grateful if you could give the size of the belt I think it is somewhere around 95" Thank you for any help you can give Regards John Lagan E john.lagan@xtra.co.nz
  • Garden Master
  • 16,181 Answers
Drive belt. Width: 1/2 " Length: 95 1/2 "
Genuine OEM Part - Manufacturer #532144959
Posted on Feb 17, 2014
SOURCE: Belt change on a hydrostatic 265 John Deere
Instructions for changing main drive belt on John Deere model 265
HELP !!!!!!!!!!!!!!!!!!
Posted on Aug 28, 2009
  • 73 Answers
SOURCE: my 1979 111 john deere lawn tractor deck blades shut off
If it has a clutch, that would be the problem. An electric clutch will kick on and off when it is hot if it is bad.
Posted on Oct 02, 2009
SOURCE: have a john deere lawn tractor. Blade will not
Check both belts on deck. Check if the clutch is clicking in. If not it will most likely need a new pto switch.
Sam
Posted on Jan 08, 2010
wireguy212
  • 1627 Answers
SOURCE: problem with John Deere L120 tractor
Park brake switch is the most likely culprit,any other would cause the tractor to not turn over in the crank position.
Posted on Jul 29, 2010
What size belt does my lawnmower take its a Craftsman lt2000 model# 917.275762
How would someone know that,
unless they had the same product ?
You have no owners manual or service
manual?
All you have to do, is remove the old belt,
& read the numbers on it
You can stop by any small equipment shop & give
them the old belt or the make & model numbers & they
will look up the new belt
Oct 03, 2014 | Garden
Belt on my craftsman LT2000 is stretched.is there a way to tighten the tensioner ? or is it automatic ?
tensioner will only work within a range- although the spring may be weak they do fatigue and go bad-sears should be able to get you a new spring -I would get a new belt at the same time-cheersDenny
Oct 26, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Need new right front tire. for my craftsman lt2000 model no. 917.28803
open a phone book, look in the yellow pages under lawn mowers and/or small engine repair. call a shop and/or take your wheel in and buy one of their new ones.
that wasn't so hard now was it?
Oct 17, 2010 | Craftsman Garden
Won't move
check drive belt and tension pulleys under machine if belt is stretched or damaged replace if popped off pulley check all to make sure one has not froze causing it to pop off also check rear pulley on axle sometimes pops off and just spins
May 15, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Changing the oil filter on a lawn tractor
If it is a screw on type oil filter, apply a film of oil on seal, then screw on. If you want to, go ahead and pour some oil in the filter, in my opinion the oil will circulate faster if there is some oil already in the filter.
Apr 11, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I need to know the route of the drive belt around the pulley syst
go to www.searspartsdirect.com and you can look up the diagram on their website.
Also you can download a free owners manual at www.managemyhome.com.
Jul 21, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Cratsman lt2000 lawn tractor will start but will not move forward or backward. I tried changing the drive belt, but that didn't work.
Is the transaxle pulley turning? If so have you removed the rear wheel recently and possibly lost the square key that fits on the axle?check those two items first.If ok it probably has a broken gear or shift key in transaxle.
Jul 14, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
