Question about Stanton C314 Tabletop CD and Mp3 Player
My stanton c314 Don't scratch any more
How Can I Fix The Problem
When i turn the cd player on its reading like a cd is in it but it not
reverse the pin of mains supply and try ,and open close cd tray switch,clean cd tray with smooth brush
Sep 03, 2012 | Stanton C314 Tabletop CD and Mp3 Player
My C314 turns on but none of the bottons work.
Hi, I have the same problem if you decide to ask her to tell how?
Aug 06, 2012 | Stanton C314 Tabletop CD and Mp3 Player
STANTON C324 NO DISK \r\nTHIS FIX THE PROBLEM AND COST YOU $25 NO LIKE IN STANTON $320 ;) http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=290406538324&ssPageName=STRK:MEWNX:IT
You need a new laser or laser mechanism. You can order one online no problem. The part number is: Sony KSS 213Q. make sure there is a Q at the end of it because sony makes a lot of different laser types and the one inside the Stanton C.324 is the Q. Yes the C.324 has Sony guts. You might also want to look into ordering a RF Signal Processor Chip. the part number is: CXA 2581N. Once again make sure the part number ends with a N. This part you might have a little more trouble finding online but it is possible. The laser mechanism you can find on Ebay for about 20$ to 30$ and if you order it from stanton magnetics it will run you about 200$. The signal processor I bought the other day from a Sony parts Dealer in my home town for 20$. Im having an Electronics Repair place do it for very cheap. If you send your stanton c.324 to stanton magnetics you will end up paying more than the turntable is worth brand new unless you have valid warranty still on it.
Hope I could help you with the problem. Cheers.
Jun 15, 2010 | Stanton C314 Tabletop CD and Mp3 Player
Stiff Platter
If the platter gets tipped, it MAY be dragging the case underneath. If it is tipping, investigate why that is happening. Could be the hub is cracked or shaft bent.
Apr 05, 2010 | Stanton C314 Tabletop CD and Mp3 Player
Not reading cds
There may be dust inside the unit on the laser. Try shoting some compressed air in the CD drive area to clean out. Also, ensure that the CD surface is clean, and try a different factory made audio CD. Sometimes CD players have problems reading "burned" CD's.
Mar 17, 2010 | Stanton C314 Tabletop CD and Mp3 Player
You have to tilt it to get cds out, and even that dont worksometimes
The ejection mechanism must have a problem. I would take it in for servicing as eventually further damage could be done or a CD damaged.
Feb 09, 2010 | Stanton C314 Tabletop CD and Mp3 Player
NO Disc
The first step is to clean the lens of the player using a cotton swab and alcohol. If that failes to resolve the problem, it is likely that the optics are starting to fail and need to be replaced.
Please clean the lens and update this with the results.
Thanks,
Dan
Aug 11, 2009 | Stanton C314 Tabletop CD and Mp3 Player
Stanton C314 Tabletop CD and Mp3 Player Logo
23 people viewed this question
Top Stanton Music Experts
Michial Gueffroy
Oloyede Monsuru
sreenivask
sreenivask
Are you a Stanton Music Expert? Answer questions, earn points and help others
